Old Jun 23, 2003, 03:01 AM
Dan Obermeyer
Dan Obermeyer
Guest
n/a Posts
[RCSE] V tail differential
How do I program differential for my V tail HLG using a Jr x388s transmitter? (I have already programmed the differential for the ailerons using the built in capability of the xmitter).
__________________________________________________ ___________
Get Free Email at http://mail.danworld.com
Select your own custom email address for FREE! Get you@yourchoice.com, No Ads, 6MB, IMAP, POP, SMTP & more! http://www.everyone.net/selectmail?campaign=tag
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off.
Rick Eckel
Rick Eckel
Guest
n/a Posts
Re: [RCSE] V tail differential
Dan,
For the long version check out http://www.orlandobuzzards.org/tips.htm.
For the short of it - use T.Adj to give the ruddervators a little more down
than up. Or use the E or F free mix to mix a little down elevator into
each rudder direction.
Hope this helps
Rick
>Thanks
>_________________________________________________ ____________
Michael Lachowski
Michael Lachowski
Guest
n/a Posts
Take a mixer and mix rudder into elevator. You just need to get the
signs of the percentage the correct amount in left and right directions.
The mix curve looks like a V with 0 in the middle and increasing the
amount of down (or up) in both directions.
The other option is to set the maximum travels of the surfaces to that
they move more in one direction than the other.
> Thanks
Support the USA F3b Soaring Team
http://www.usaf3b.com
Question 9303 V-tail Differential Wing-span Sailplane Talk 6 Jul 26, 2010 02:27 AM
V-Tail Differential Question checkenbach Slope 4 Jul 07, 2005 07:02 AM
V-tail differential bfretless Thermal 10 Jul 31, 2004 11:30 PM
Help - Prism 7x and V-Tail Mixing with aileron differential (channel 1 and 6) Cash Traylor Electric Plane Talk 9 May 20, 2001 10:31 PM
