Old Jul 18, 2010, 01:41 AM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
RCTimer Style 2830-14 750KV - Prop adapter...
i received my motors and am not too happy w/ the propller mount - just seems a bit weak w/ a lot of the shaft exposed just waiting to get bent. i was wondering if i could flip the shaft and using a mount that mounts to the housing since it is drilled/threaded w/ something like the center, larger prop mount in this pic -
that is for the kda 20-XX series motor - would it be compatible w/ the mounting holes for the rctimer 2830-14 750? here are the mounting dims:
or if that mount doesn't work, can anybody point me in the direction of something that will work?
tia,
bob
bob4432 is offline Find More Posts by bob4432
Old Jul 18, 2010, 08:03 PM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
I felt the same way you do about the bullet style prop adapters until someone told me they are fine. I use the bullet style now without any issues. I ordered 12 of the adapters you pictured there. You can have them for $20 if you want.
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Discussion Where can I find a set-screw style 3mm prop adapter? PerfectStranger Electric Plane Talk 3 May 05, 2006 05:39 AM
Himax gearmotor 3 mm Collet Style Aluminum Prop Adapter Bat21 Power Systems 10 Sep 02, 2004 11:53 PM
Bullet nose collet style Prop Adapter for 4mm? Jim Miller Scale Kit/Scratch Built 6 Aug 13, 2003 03:41 PM
Collet Style Prop Adapter or Spinner SteveR Sport Planes 3 Mar 03, 2002 10:03 PM
Prop Adapter Style? ToddO Electric Plane Talk 3 Dec 07, 2001 09:41 PM
