Old Jul 18, 2010, 01:34 AM
Twmaster is offline
Find More Posts by Twmaster
Angering mobs since 1980.
Twmaster's Avatar
United States, TX, Dallas
Joined Sep 2001
Art-Tech EC135/MD500 controller board issue (I think)
I've got one of the A-T EC-135 Speed 370 coax helis. It will not trim out for yaw. It wants to keep doing piros no matter how much trim I try. Holding the stick full opposite will almost tame it into not spinning.
I suspect I have a damaged 3-in-1 controller board. Ideas? Confirmation?
Thanks!
Mike N
Orbiting in OK.
Twmaster is offline Find More Posts by Twmaster
Old Nov 07, 2010, 12:41 AM
Twmaster is offline
Twmaster's Avatar
Joined Sep 2001
Chirp...
Chirp..
Nobody?
Mike N
Old Nov 07, 2010, 07:10 AM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
its probably the motors, when it usually does that i replace both motors and it works fine again.
http://www.xheli.com/at-44171.html
jombo is offline Find More Posts by jombo
Old Nov 07, 2010, 10:31 PM
Twmaster is offline
Twmaster's Avatar
Joined Sep 2001
That would be grand if it's just the motors. I'll have to try that next weekend when I have some spare time.
Thank you.
Mike N
Old Nov 07, 2010, 10:45 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
I had a coaxial that did this. It could be because the lash between one of the pinion gears and main gears is wrong, namely, too tight or too loose. optimally, your gear lash should beset by just making contact, if it's too little on one of your motors, that would create too much turning resistance.
Doubletap is offline Find More Posts by Doubletap
Old Nov 09, 2010, 11:57 PM
Twmaster is offline
Twmaster's Avatar
Joined Sep 2001
Yea, I've been through the drive system looking for binding. That was the first line of trouble shooting. I bought this used and it has never flown correctly. I have the MD500 and it flies just fine. I just hate to go through the heartburn of swapping parts until I find the culprit.
I'll tinker with it over the weekend as I'm pretty busy with work during the week.
Mike N
Old Mar 02, 2011, 09:06 AM
Virginia Jim is offline
Find More Posts by Virginia Jim
Virginia Jim's Avatar
United States, NC, Durham
Joined Mar 2011
Yours is an old post, but I just joined this forum, and thought I would chime in.
I hope this suggestion is not exposing my own naivete. Have you tried adjusting the tiny potentiometer that is accessible through a hole in the left side of the cabin to the printed circuit board?
Mine was spinning at first too, but I was able to correct it by careful adjustment of this pot.
Please indicate in your post which version you have. I believe it has sold in both 72mHz and a 2.4ghz versions. Mine is the 2.4ghz version (ArtTech-11044-MD500-24Ghz-GreenHeli), purchased in Jan 2011 from Xheli.
http://www.xheli.com/arttech-2-4ghz-md500-hughes.html
Virginia Jim is offline Find More Posts by Virginia Jim
Old Mar 02, 2011, 05:50 PM
Twmaster is offline
Twmaster's Avatar
Joined Sep 2001
72 MHz.
I should have made it clear when I said 'trimmed' I meant the pot on the circuit board. Thanks for the suggestion. Never hurts to point out all options.
Old Mar 02, 2011, 06:20 PM
Joined Mar 2011
Twnmaster:
Thanks for your quick reply. Did you ever resolve your problem? Do you still have your MD500?
Has the consensus opinion on this heli improved at all?
New Product Art-Tech MD500 & Eagle Eye deadduck Coaxial Helicopters 27 Aug 20, 2011 02:08 PM
Discussion Art-Tech MD500 Spycopter - flying badly - tx problems - ESC? r00x Coaxial Helicopters 1 Jan 27, 2010 10:39 PM
Sold Art-Tech MD500 visatrade Aircraft - Electric - Helis (FS/W) 4 Mar 21, 2009 07:25 PM
Question MD500 & EC135 JHawk19 Hobby Express (Formerly Hobby Lobby) 2 Nov 20, 2008 06:39 AM
Discussion Art-Tech MD500 Racer57 Coaxial Helicopters 5 Aug 12, 2008 05:47 AM
