USA
Joined May 2010
Is there any pan/tilt systems where the the servo doesn't stick out the bottom?
hello,
are there any pan/tilt systems where the base doesn't have the Panning servo sticking out at the bottom? I want to lay the complete setup on a flat surface..... can anyone give me links or chime in .... ie....http://globe-flight.com/EasyStar-Canopy-GFK. the servo isn't below the base..... I like to buy this one but, I prefer a USA vendor..... |
Build your own http://rcspotlight.com/guides/easypad-build/
Romania, Dolj, Craiova
Joined Sep 2007
I built a reversed variant of pan mechanism, for the same reason as you.
Not handy to make pictures, but I'll try to explain. I am using a 4 arms cross servo arm, mounted on the canopy base, and camera mount was built around the servo case. So, the arm is fixed and the servo is the one who moves. The tilt servo was glued to the pan servo, and tilt done using a rod. Something close can be found here: http://fpvhobby.com/36-pan-tilt-modelh.html but mine is smaller, no trasnmitter mount, tilt servo is glued to pan servo. |
Latest blog entry: JRSky - birth of a dream radio
| Thread Tools | |
| Discussion Are there any Head Tracker that doesn't drift? | rclab1 | Video Piloting (FPV/RPV) | 16 | Aug 03, 2010 09:42 AM |
| Discussion Pan and Tilt on a GWS Servo | Cralis | Video Piloting (FPV/RPV) | 24 | Jul 01, 2010 02:55 PM |
| Discussion Eagle Eyes Pan/Tilt servo supply | Peter Seddon | Eagle Tree Systems | 9 | Jun 24, 2010 10:54 PM |
| Discussion Best Pan Tilt, Best pan tilt servos??? | justind123 | Video Piloting (FPV/RPV) | 19 | Feb 26, 2010 08:42 AM |
| Discussion smoothing out the pan / tilt servo | lupy | Video Piloting (FPV/RPV) | 4 | Sep 09, 2007 09:18 PM |
