Old Jul 16, 2010, 01:54 PM
heliwill10 is online now
Find More Posts by heliwill10
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Smooth Genie Cord Span
Can someone measure the Cord on the SGP for me? My plans show the ribs being an inch longer and the spar webs are all too tall for the thinkness of the ribs. So, now I'm wondering if I have LTS ribs by mistake.
Thanks.
heliwill10 is online now Find More Posts by heliwill10
Old Jul 16, 2010, 03:07 PM
Wazmo is online now
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
Assuming it's the same as the composite wing, this has the panel measurements for all three Genie wings. 10" root for the SGP.
http://augiemckibben.tripod.com/site...oil_panels.pdf
Also see http://www.geniebuild.com/harleys_genie.html
Wazmo is online now Find More Posts by Wazmo
Old Jul 16, 2010, 07:47 PM
vintagesailplnr is offline
Find More Posts by vintagesailplnr
United States, PA, Nesquehoning
Joined Dec 2003
answer.....
heliwill10
The height of each rib is different - therefore for the kit to have each individual rib web cap (40 rib webs just in center section) cut to the appropriate height - would raise the cost of kit A LOT!
Many modern kits just supply a sheet(s) of balsa/ply for you to cut the webs and web caps 0R the kits are in the $500+ price range.
They are cut to the correct width.....
Jim
PS: Follow the building log and the rib length will work itself out - also all plans when printed tend to shrink or expand - not always the same in both directions.
Thanks.
vintagesailplnr is offline Find More Posts by vintagesailplnr
Old Jul 18, 2010, 11:24 PM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Thanks for the help, the wing is really coming along!
Build Log Smooth Genie Pro-wood version trident58 Thermal 180 May 06, 2013 02:53 PM
Sold Sold Pending - SGP Smooth Genie Pro All Wood Version jcstalls Aircraft - Sailplanes (FS/W) 3 Mar 10, 2010 09:25 AM
Discussion Has anyone built the Smooth Genie Pro kit by Vintagesailplanes Jack Hyde Thermal 17 Dec 31, 2009 04:39 PM
Discussion Smooth Genie Pro/Pike Perfect hybrid harleym Thermal 6 May 18, 2008 12:48 AM
