Old Jul 16, 2010, 07:52 AM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
Help!
F4 Phantom plans
I'm looking for plans for a F4 Phantom foamie profile. Something about 18-22" WS. I have a small EDF I'd like to try. Any help would be appreciated! Thanks, Marty
martys is offline Find More Posts by martys
Old Jul 16, 2010, 11:09 AM
jhaywood is offline
Find More Posts by jhaywood
jhaywood's Avatar
United States, VA, Suffolk
Joined Nov 2007
get a larger plastic model, then blow the three views or trace the parts on paper and blow them up for plans. with profile, very easy to do
jhaywood is offline Find More Posts by jhaywood
Old Jul 16, 2010, 12:43 PM
flashkick is offline
Find More Posts by flashkick
Flash, AAAAAAAAAAAHhhhhhhhhh
flashkick's Avatar
United States, UT, West Jordan
Joined Dec 2008
just google f-4 3 view and print it as a pdf. then size it however you want and then print it off on paper, cut out, enjoy.
flashkick is offline Find More Posts by flashkick
Old Jul 16, 2010, 03:36 PM
FliteMetal is offline
Find More Posts by FliteMetal
FliteMetal's Avatar
Joined Mar 2009
Everything You Need...F4
Everything you need to make a profile Phantom II is contained here free of charge. http://www.airwar.ru/other/draw/f4phantomatl.zip
There will also be excellent card stock models available in .pdf so you can scale them to whatever w/s and length you want.... You need only go to FedEx Office/Kinko's and have them print the images you select of the .pdf at the size you want..."in color".
Simply cut it out, be sure to not forget to use the polyhediral and have fun. With respect to the card stock resources you can actually use the scale up components for the fuselage and make a non-profile fuse with a polyhediral wing all made from Depron.
Enjoy...
Ed
FliteMetal is offline Find More Posts by FliteMetal
Old Jul 17, 2010, 07:44 AM
pulsery2k1 is online now
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
3 view drawing of F-4
pulsery2k1 is online now Find More Posts by pulsery2k1
Old Jul 20, 2010, 05:31 PM
jeffsch is offline
Find More Posts by jeffsch
Jer. 29:11
jeffsch's Avatar
United States, WA, Snohomish
Joined Oct 2009
You might try the Nick Cara design [1], offered as a kit by www.6mmflyrc.com [2]. It's for a slot-in-prop/captured-prop design, but I suspect you could easily modify it for ducted fan (after all TechOne is doing that these days [3, 4]).
[1] http://www.rcgroups.com/forums/showthread.php?t=1006628
[2] http://www.6mmflyrc.com/quick-build-series/
[3] http://techonehobby.com/proview.asp?id=188
[4] http://www3.towerhobbies.com/cgi-bin...?&I=LXZBN4&P=7
jeffsch is offline Find More Posts by jeffsch
Discussion F4 Phantom plans? Mayday~Mayday Scratchbuilt EDFs 3 Jun 06, 2010 07:10 PM
Discussion Yellow F4 Phantom build questions. jmalone1982 Electric Ducted Fan Jet Talk 3 Mar 23, 2010 12:35 PM
For Sale HET F4 Phantom 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Mar 09, 2010 12:11 PM
F4 E Phantom II ducted fan plans rboik Fuel Jet Talk 6 Nov 15, 2005 08:10 AM
Wanted LOOKING FOR AERC F4 Phantom Plans or similar..... punkindrublik Aircraft - Electric - Airplanes (FS/W) 13 Oct 05, 2005 04:06 PM
