Old Feb 04, 2013, 07:40 AM
mdg76 is offline
Find More Posts by mdg76
Fly? Yes. Land? Not so much.
United States, NY, Cortland
Joined Aug 2011
Originally Posted by Wamp View Post
With the 7.5 pitch you should get great flight times useing the 1300.
If you do not have the Corsair motor on hand, at their price
you can do better.
Park 480 (either kv) Park power ten both work.
I would like to try an Omega 72 gram. (Nice price at 3D Hobby)
The power ten or $25.00 Turnigy 3536 will give vertical
power! Chris
Thank you so much for the info. It's appreciated!!
mdg76 is offline Find More Posts by mdg76
Old Feb 04, 2013, 12:03 PM
dlt2859 is online now
Find More Posts by dlt2859
Go Fly Something!!
dlt2859's Avatar
USA, VA, Charlottesville
Joined Jan 2009
Originally Posted by g2tiger View Post
I didn't fly but I did clean out the work shed a tad and got in a bit of customization on my as of yet to be flown f4f. That's a stock canopy which I cut by scoring with a sharp Xacto knife.
Damn!
Now I have to add rivets!!! Completely forgot that when I weathered mine.....did you freehand them or??
Don
AMA 384859
dlt2859 is online now Find More Posts by dlt2859
Old Feb 04, 2013, 12:19 PM
Hink64 is online now
Find More Posts by Hink64
Hink64's Avatar
Cape Coral, Fl
Joined Jan 2010
Originally Posted by dlt2859 View Post
Damn!
Don
AMA 384859
Don - have you every used a pounce wheel? Works great on foam and is quick.
Hink
Hink64 is online now Find More Posts by Hink64
Old Feb 04, 2013, 01:00 PM
Justwingit is offline
Find More Posts by Justwingit
We got some flyin' to do!
Justwingit's Avatar
United States, TX, Fort Bliss
Joined Apr 2012
Excellent detail work!
Could you post more pics of the whole aircraft?
Justwingit is offline Find More Posts by Justwingit
Old Feb 04, 2013, 01:58 PM
g2tiger is offline
Find More Posts by g2tiger
g2tiger's Avatar
Joined May 2006
I can take a few more shots of the model for everyone. The rivets were free handed. They are not very good but do give the model a neat look in my opinion. I used a super or ultra fine sharpie marker. Actually, I used a hobby saw with a fine blade on the top of the canopy. I did this because it would be too hard to try and score the top around the top curve. I sawed about a 1/4 inch down then used the hobby knife and scored the area I wanted to cut. After about ten or so score markes the canopy began to come loose. I used Loctite hobby cement (dries clear) to hold the canopy on after all was done.
this does take a bit away fro the rigidness of the upper section. Not much but a bit. More photos later when I get a chance.
g2tiger is offline Find More Posts by g2tiger
Old Feb 04, 2013, 02:14 PM
RcAirplaneNoob is offline
Find More Posts by RcAirplaneNoob
I live on LiPos
RcAirplaneNoob's Avatar
United States, DE
Joined Jul 2012
Ok thanka!
RcAirplaneNoob is offline Find More Posts by RcAirplaneNoob
Old Feb 04, 2013, 04:00 PM
Go Fly Something!!
dlt2859's Avatar
Joined Jan 2009
Hink
Hink,
Yep I know what your talking about....I don't own but can certainly acquire! I know there were "layout" guides available from some cottage industry guys a while back but the wheel makes more sense!
Thanks!!
Don
AMA 384859
Old Feb 05, 2013, 03:51 PM
Go Fly Something!!
dlt2859's Avatar
Joined Jan 2009
Hink
Hink,
Do you use the pounce wheel wet? In other words dipped in paint or do you use it for layout and go back with a Razor Point Sharpie and hit each indentation?
Don
AMA 384859
Old Feb 05, 2013, 04:01 PM
Hink64's Avatar
Cape Coral, Fl
Joined Jan 2010
Hink,
Don
AMA 384859
Don,
The pounce wheel I have was from my Dads medical bag. It was used to measure skin sensitivity or what ever he used it for. The prongs on the wheel are needle sharp. Basically I would run this tool along each side of a panel line and would slightly puncture the foam leaving a small dimple. The effect closely simulated a rivet pattern. I would do this before painting - I dont think you want the rivet pattern to be too obvious - but it certainly does show.
Hink
Old Feb 05, 2013, 04:33 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
God Bless you OCD types..........
pugsam is offline Find More Posts by pugsam
Old Feb 05, 2013, 04:55 PM
Wamp is online now
Find More Posts by Wamp
Wamp's Avatar
Joined Mar 2012
Were is Rosie when ya need her!? Chris
Wamp is online now Find More Posts by Wamp
Old Feb 05, 2013, 05:18 PM
Hink64's Avatar
Cape Coral, Fl
Joined Jan 2010
LOL - dont you mean ORD - obsessive rivet disorder?
Old Feb 06, 2013, 05:49 AM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
Enough of rivets for now please, I have a motor question. First flight I managed to introduce the nose to the sidewalk and the motor has been noisy since. Amps seem OK and the noise is the only symptom of a problem. Bearings feel OK after taking the motor apart. No observable cracks either.
Any suggestions appreciated.
Back to the riveting now.
Rickflaguy is offline Find More Posts by Rickflaguy
Old Feb 06, 2013, 07:15 AM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
I would check the motorshaft (if you haven't yet), doesn't take much of a bend in it to really cause issues. I am assuming you are using a different prop?
IndyMatt is offline Find More Posts by IndyMatt
Old Feb 06, 2013, 08:19 AM
Joined May 2011
Prop was in pieces but I will check the shaft. Doesn't act or look bent at all. Balanced too. It is more of a mechanical noise which could still be bearings. I think I can get bearings and shaft at Hobby Town.
Discussion Parkzone F4F Wildcat WOW!!!! ilovejets1 Parkflyers 40 Dec 16, 2015 06:47 PM
Build Log Dumas 17.5" F4F Wildcat LoneRanger Scratchbuilt Indoor and Micro Models 53 Jul 07, 2010 09:34 AM
Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! BRUTUS2238 Aircraft - Electric - Airplanes (FS/W) 0 Jun 10, 2010 09:31 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Discussion Scratchbuilt F4F Wildcat kylewoody Parkflyers 2 Sep 01, 2009 08:18 PM
