Big sigh....
![]() This thing ain't a micro.... ![]() I'm sorry to hear about your maiden; it was/is one of my easiest to fly. You gotta fly this thing. It's not a trainer. Just make sure your controls are all centered and try it again. Are you using 1300's? And are they secured and not sliding back and forth? What's the C/G? If it's nose heavy...that's okay. Tail heavy = bad, very baaaaad. What throttle setting did you use? Mine (and I suspect most of the pilots on this thread) will fly off straight and level at 60% throttle using the stock prop and 1300 mAh battery. Unless I'm watching a video or standing right there, everything is pure speculation. Try using less thumbs. These birds fly differently than micros; I have a Carbon Cub and I have to fly it differently than I do my "full size" models. I dunno; just a bunch of random thoughts. Throw her up in the air and try again. Patiently awaiting the results...
Latest blog entry: 1st Annual Warbirds over Las Vegas - 4-6...
What do you mean by elevator throws? I am not up on 100% of the lingo. I don't just fly micros, I also have three helis and a parkflyer size EDF foamy jet. I obviously don't have it calibrated properly (my fault), but I am not sure how to correct it. I am planning on changing my D/R's to 60% and see what happens when the weather should be good enough to fly in two days from now. I am using the stock 1300mah battery and not aware of a throttle setting. I have a DX6i. I have only learned when I have had issues like this in the past, so I feel some RC growth coming on. Any help is appreciated. |
Joined Dec 2010
Sorry to hear about the mishap, at least it sounds like plane didn't suffer too badly.
Hard to determine what happened without being there or seeing the plane. One thing that comes to mind... is the DX6i the radio that you have to program expo in "reverse" from the other Spektrum transmitters? (negative instead of positive, or something?). How did it respond immediately after launch (while you were still getting your hand back on the transmitter)? With no inputs, I'd expect her to start a roll to the left, and probably dip the nose. |
![]() You get my point; it's not a heli and it's not an EDF...this thing is different and I'd recommend some help from someone who is experienced with this sorta thing to help you out. Once you learn how to fly this model, you'll find it's one sweet flying warbird. Due to it's dihedral and the fact that it's a mid-wing, it'll balance just as easy right-side up as it will up-side down. Just my .02 |
The expo is +30 for all three settings. I may bump it up another +5 just to ensure I smooth things out as much as possible. It did a little porpoising right after the launch. My question for any of you can you post a picture of how you have the elevator trimmed? Is it perfectly level or is it slightly one way or the other using the stock battery? |
I have been CGing up side down with the bat.
Like other warbirds tail heavy is risky. There is not much clearance between the prop adapter and cowl. I also opened the carb intake and cleaned between the pistons for air flow. If the prop adapter rubs on the cowl it could influence torque roll. Did you center servos then adjust surfaces? Not sure I understand what you did to line up the surfaces. Going to the inner holes on the control hornes will give you exciting amounts of throw! Futaba and JR/Spektrum have reversed values for expo. I think the 6i is the same as the DX7 or 8. Positive expo softens the center. I do not use any on helicopters. But then I lost interest in them. The Wildcat really helped my learning curve. After underpowered high wing Cubs and the like. I finally stopped reacting to what the plane was doing and started telling it what to do! Wildcat is a fine stable plane. Not perfect tho. Yes check that elevator control horn. Especially if you went for more throws. It looks fine in flight checks, but it can be lose. I have had trouble with the control rod sleeves. At one point, after a nose in, the E sleeve moved forward all the way to the control arm on the servo. This would bind. At first I thought it was my flying skills, so it took time to sort out. Wildcat will stall. Get a few mistakes high and practice stalling. It recoveres quicker than ducted fan planes! Good luck out there! Chris |
Raleigh, NC
Joined Jan 2010
Your crash sounds a bit like the first one I had with my Wildcat, on flight 72 or so. I pitched it, only to have it circle hard right and roll in--something it had never done before. I was mystified until, looking at it post-crash, I realized that in sliding the battery in I had managed to pull one of the aileron servo leads loose and hadn't realized it. The involved aileron jammed, hence the roll and drop. Fortunately all I did was break the prop--sometimes it's the simple (and embarassing!) things.
Flew 2 more 1250's and 4 more 1350's this morning for a total of 50 more minutes of flight time logged on the little 'cat
!Abundant sunshine, 72 degrees and little to no wind...just perfect ![]() GBL, I snapped a couple of pics for you as per your request for elevator pics. Mine is basically level; maybe just a smidge of up elevator induced through mechanical trim. I always trim my models to fly hands-off at 50-60% throttle. As trimmed, at roughly 50% throttle, my Wildcat will fly straight and level hands-off for at least 250 yards before she starts to gently bank into the direction the wind is taking her. I just tested her again this morning and with little to no wind, at about 100-150 feet altitude, she just sails on by looking as cool as ever ![]() Also, look down the long axis of the model and ensure the elevators are level, using the main wing as a guide...mine were a bit "wonky" as the Brits would say, and needed some light tweaking to get them straight. Hope you get your bugs worked out...remember, gentle on the thumbs, easy does it
Danville, CA
My ailerons are pretty straight but my elevator is warped downward at the edges. What's with that do you suppose? This is z-foam just like other pkzone models and I haven't seen wierd warping like this in others. I got everything mechanically close to straight and it flies like a dream.
A few days ago I blew an aileron servo -- it deflected and stayed there! If I had a few more seconds to think about it I think I could have brought her back with opposite aileron (one was still working) and rudder, but she was pretty close to the ground by the hillside so when I got her stabilized I let her crash gently into the weeds... cracked the cowling. (I always keep a spare cowling handy.) Upon further examination, that servo was just dead. I've had broken teeth but never this. Well, little harm done and it was pretty easy to replace. For you guys getting ariframes only, you can use the pkzone part, but an HS-55 fits nicely too. We had strangely warm weather today (75F) and I tested the repairs in a light wind -- what a nice time. She's back. |
Danville, CA
| Thread Tools | |
| Discussion Parkzone F4F Wildcat WOW!!!! | ilovejets1 | Parkflyers | 34 | Dec 09, 2010 09:29 PM |
| Build Log Dumas 17.5" F4F Wildcat | LoneRanger | Indoor and Micro Models | 53 | Jul 07, 2010 09:34 AM |
| Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! | BRUTUS2238 | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 10, 2010 09:31 AM |
| Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread | skyjet | Micro RTF | 2 | Mar 19, 2010 03:00 PM |
| Discussion Scratchbuilt F4F Wildcat | kylewoody | Parkflyers | 2 | Sep 01, 2009 08:18 PM |
