Old Oct 24, 2012, 06:13 AM
Wamp is online now
Find More Posts by Wamp
Wamp's Avatar
Joined Mar 2012
Originally Posted by jdwolters View Post
Yes, that's the one!
The Mustang and F4F share the same prop and entire power system. The T-28 prop gives you more, but it taxes the 1300 bats. The corsair 3-blade prop looks the best, breaks regularly, and needs a different collet or some adapter rings. If you want to use a corsair prop, you might get a corsair collet along with it. The 3-blade gives tons of thrust but draws more current than the 1300's can provide; it also makes the motor run a bit hot.
The 3-blade is popular choice and I like it too, but I think the best all-around is the T-28 prop. Hey, try both.
I am running 40C 1300s in a number of planes. They do any thing a 2200mAh will do sans long flight times. I have been getting them from Heads Up Rc.
good luck. Chris
Wamp is online now Find More Posts by Wamp
Old Oct 24, 2012, 06:54 AM
g2tiger is offline
Find More Posts by g2tiger
g2tiger's Avatar
Joined May 2006
Thanks for the info.
I hope to see the model arrive today or tomorrow if all goes well. I did order a spare cowl (I will line the inside with some cuct tape for strength) and a corsair 3 blade to cover the base. I'll check into the T28 prop since it appears to work well with the stock power system from the info gathered here. It would be fun to get a bit more zip out of the stock system without having to buy a lot of electronics.
I will see what Headsuprc has in batts also. My next project is to convert the super cub over to brushless. I may just get a burshed ECS to save a few bucks but I'll still need a new Rx and servos. So there may be no savings there.
My priority is getting the F4F up and running.
g2tiger is offline Find More Posts by g2tiger
Old Oct 24, 2012, 08:52 AM
xfatdannx is offline
Find More Posts by xfatdannx
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
tiger i sent you you a pm, i can get you a 30amp esc for free if you are in the states...just needs shrink wrap. everything on it is fine.
xfatdannx is offline Find More Posts by xfatdannx
Old Oct 24, 2012, 10:27 AM
shepflyr is offline
Find More Posts by shepflyr
United States, SC, Charleston
Joined Aug 2011
Tiger,
I'm having a blast running my F4F stock...only upgrade is a Thunder Power 1350mAh battery. Since the C rating is higher, that adds plenty of zip without needing an ESC or prop upgrade. I just don't jam up to WOT...ease her up normally and she does fine. It's a great improvement over the stock battery.
Enjoy your Wildcat!
Tom
shepflyr is offline Find More Posts by shepflyr
Old Oct 24, 2012, 05:52 PM
Wamp is online now
Wamp's Avatar
Joined Mar 2012
Super Cubs are great!
Tundra tires rule.
Heads Up has been great. GTR C
Old Oct 24, 2012, 10:35 PM
Justwingit is online now
Find More Posts by Justwingit
We got some flyin' to do!
Justwingit's Avatar
United States, TX, Fort Bliss
Joined Apr 2012
Been running mine stock now for the last couple of months and must say I'm having a blast...
Learning how to coax every bit of overall performance out of the little Grumman
Overall, she's not bad stock, you just gotta get to know her
Justwingit is online now Find More Posts by Justwingit
Old Oct 25, 2012, 12:22 AM
jdwolters is offline
Find More Posts by jdwolters
Fly, be free! (splat)
United States, CA, Danville
good luck. Chris
You're right -- I was thinking of the stock 1300's, which are only 15C.
jdwolters is offline Find More Posts by jdwolters
Old Oct 25, 2012, 06:16 AM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Throw a Power 15 in her and that is when the fun begins! Actually stock the bird is a blast to fly. A real floater! I want UMX 2S brushless version!
IndyMatt is offline Find More Posts by IndyMatt
Old Oct 25, 2012, 09:20 AM
Wamp is online now
Wamp's Avatar
Joined Mar 2012
Yes! I will rip the back pocket to get the wallet out for a brushles um!!
Ran a 15 'till ripping the (already reinforced ) elevator control horn.
that crash took out the shaft.
Rebuilt with a power 10, yet to maiden.
Perhaps this week end.
Been flying #1 which is stock except for big esc and large throws on hi rates.
Been thikng a 'scratch build' to come up with a 21" ws Wildcat! Chris
Old Oct 25, 2012, 08:56 PM
IndyMatt is offline
Indianapolis, IN
Joined Oct 2010
Off to re-double check the elevator control horn. Man she hums through a shallow dive a high banking turn!
Old Oct 27, 2012, 10:41 AM
kw5368 is offline
Find More Posts by kw5368
United States, WV, Beverly
Joined Mar 2004
This has probably already been covered in this thread, but can someone tell me what else will be needed to complete an airframe only build? Are the pushrods included with the airframe? Motor mount? Control horns? I am aware that the motor, esc and servos are not included, but wanted to order any other small parts at the same time.
Thanks for your help
Ken
kw5368 is offline Find More Posts by kw5368
Old Oct 27, 2012, 01:17 PM
Yes, it comes with all the little stuff, even a prop & collet.
Old Oct 27, 2012, 02:51 PM
kw5368 is offline
Joined Mar 2004
Thanks jd.
Ordering now.
Old Oct 28, 2012, 08:17 AM
Wamp is online now
Wamp's Avatar
Joined Mar 2012
Originally Posted by kw5368 View Post
Thanks jd.
Ordering now.
Good luck!
It is a very easy build. My current solution to the E control horn 'trouble'
Has been to wick / milk canopy glue under it.
One I through bolted failed. Perhaps both with big washers?
I would do some thing there day one.
The thrust angle mod is helpfull as is reinforcement of the cowl.
It may be worth ordering a spare, take advantage of the free shipping.
Also the spare comes with out the number.
I used the spare and kept the original.
Any you have a great plane coming! Congratulations. Chris
Old Oct 29, 2012, 07:33 AM
kw5368 is offline
Joined Mar 2004
Thanks Chris. I am receiving this as a Christmas gift, so it will be a while before I see it.
Ken
Discussion Parkzone F4F Wildcat WOW!!!! ilovejets1 Parkflyers 40 Dec 16, 2015 06:47 PM
Build Log Dumas 17.5" F4F Wildcat LoneRanger Scratchbuilt Indoor and Micro Models 53 Jul 07, 2010 09:34 AM
Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! BRUTUS2238 Aircraft - Electric - Airplanes (FS/W) 0 Jun 10, 2010 09:31 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Discussion Scratchbuilt F4F Wildcat kylewoody Parkflyers 2 Sep 01, 2009 08:18 PM
