Old Oct 13, 2012, 05:12 AM
GBLynden is online now
Find More Posts by GBLynden
I am GBLynden
GBLynden's Avatar
United States, WA, Lynden
Joined Mar 2011
Originally Posted by quitcherbitchen View Post
GBL, If you are just getting into the hobby forget the soldering iron and go straight for the Anderson power poles.http://www.powerwerx.com/anderson-po...owerpole-sets/. No soldering and will save you countless time and mistakes that other connectors have due to their bad design. When you don't own that many lipos or ESCs is the time to get power poles so you won't have to convert your whole fleet later once you realize how superior these things are to other connectors.
I am not sure I understand how these work. Do I use these on the connectors on the planes themselves and the batteries? Also, how does one select the right plugs? There are a lot of choices and I have no idea what guage wire is being used in this plane or my EDF jet that happens to also use a 1300 mah battery. The only difference is that it uses Deans connectors.
I will have two with the correct connectors for each plane for a total of 4 1300 mah batteries.
GBLynden is online now Find More Posts by GBLynden
Old Oct 13, 2012, 07:49 AM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Good question GBY. If you go to their website they explain the pole ends and size wire. What I can tell you is that the 15,30, and 45 (barrels) or metal connectors all fit the same plastic housing and all will connect with one another .In example, a 15 can connect to a 45. I use a little of each in most of my projects depending on the wire size. My 1300mah batteries use 15s, but the ESC uses 30. My higher 3300 mah batteries and 60 ESC use 45. They are all rated for double their number so a 15 can handle 30 amps and a 30 can handle 60 etc. One thing you must understand is that without the Power Pole Tool these are junk and will not be very reliable. Their tool is expensive at $39.99, but is the key. I find I use these things are useful for everything from work to around the house so I think the tool is worth every penny. Their tool is quite unique and nothing is easier then using it. If I were you I would buy the tool. a set of Power Pole 15s(housings and connectors in one bag0 and a loose bag of 30 metal connectors to start. The 45s are useful for thick 12 and 10 gauge wire, but most little foamies don't use these.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Oct 13, 2012, 02:52 PM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
Thank you for the explaination. That is something I will consider before my next battery purchase.
Old Oct 14, 2012, 09:04 AM
Wamp is offline
Find More Posts by Wamp
Wamp's Avatar
Joined Mar 2012
Gee just when I got the hang of soldering Dean's! Thanks Chris
Wamp is offline Find More Posts by Wamp
Old Oct 14, 2012, 09:43 AM
Sky_Captain is offline
Find More Posts by Sky_Captain
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
Deans are smaller and will serve you better in smaller planes.
I have fallen in love with EC3 plugs and have switched everything I have over to them.
Sky_Captain is offline Find More Posts by Sky_Captain
Old Oct 14, 2012, 09:55 AM
Bombs away!!!
Joined Jul 2011
EC3 are a pain to disconnect and connect. Plus it is possible to connect them backwards and short out your plane. Power Poles that would be impossible.
Old Oct 14, 2012, 09:57 AM
Flying is Freedom
Annandale, VA
Joined Jul 2007
I had a lot of problems with the Deans getting too hard to plug and unplug, I have been using the EC3 plugs for a year now and have never had a problem getting them together or apart. Also they holes are different so I don't know how any duffus could plug them in wrong. It's like trying to put a square peg in a round hole
Old Oct 14, 2012, 10:04 AM
Bombs away!!!
Joined Jul 2011
Their square can fit the round hole with enough force or if you every removed the cover in the past they get very loose. I added an SPC connector to an ESC and made the rookie mistake of trying to salvage the blue plastic cover. Trust me an EC3 cover cannot be used twice once taken off. I almost became a qualified duffus.
Old Oct 14, 2012, 01:33 PM
Flying is Freedom
Annandale, VA
Joined Jul 2007
That's a good tip, I won't have to worry about that since I never try to reuse a connector. They are very cheap from hobbyking and I keep plenty on hand. I like new stuff when I'm soldering connectors.
Here is a rookie mistake I made when I first started soldering.
I soldered a male deans plug to the battery and before I knew it, both post touched my wedding ring and it sparked, melted the gold just enough to grip it for a couple of seconds and my ring got pretty hot. I yanked the battery loose from my ring and stuck my hand under cold water quickly. Luckily I didn't get burned but my heart was pounding like there was no tomorrow
I don't have to worry about this with EC3 because there is no exposed connector on the male or female connectors.
Anymore and I think we should really take this to a connector thread
Old Oct 14, 2012, 09:44 PM
Bombs away!!!
Joined Jul 2011
There is a connector thread?
Old Oct 15, 2012, 07:55 AM
Flying is Freedom
Annandale, VA
Joined Jul 2007
Yes,in the Batteries and Chargers forum.
Old Oct 16, 2012, 01:03 AM
jdwolters is offline
Find More Posts by jdwolters
Fly, be free! (splat)
United States, CA, Danville
Joy! I've been flying micros too much recently. Just took the F4F out for a spin -- it flies sooo much better!
Ps: my vote for EC3 connectors too -- I've never, ever had a problem putting the square peg in the round hole -- it doesn't fit. I must say though, as I get more Turnigy batteries I'm stating to switch over to their XT60 connectors (with the triangle shape on one side).
jdwolters is offline Find More Posts by jdwolters
Old Oct 16, 2012, 03:18 PM
Flying is Freedom
Annandale, VA
Joined Jul 2007
I like the XT60 also, but I'm in deep with the EC3 connectors. I probably have more than 50 on batteries and esc. I really don't want to go through swapping them all out again.
Old Oct 16, 2012, 03:29 PM
Bombs away!!!
Joined Jul 2011
Yeah, you are definitely committed to that connector. I only switched from gas to electric about a year and half ago. If I had to convert now versus a year ago I might not consider it and I have less then half the batteries you have. Someone just getting into it like GBL now is the time.
Old Oct 16, 2012, 03:58 PM
Aphro is offline
Find More Posts by Aphro
ChuckTseeker Super Fan
Aphro's Avatar
Joined Jan 2012
I went way outside the box... I chose to go with Traxxas connectors
Excellent contact surface area and easier to plug and unplug compared to Deans. Soldering and assembly is also much easier than Deans...
Aphro is offline Find More Posts by Aphro
Discussion Parkzone F4F Wildcat WOW!!!! ilovejets1 Parkflyers 40 Dec 16, 2015 06:47 PM
Build Log Dumas 17.5" F4F Wildcat LoneRanger Scratchbuilt Indoor and Micro Models 53 Jul 07, 2010 09:34 AM
Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! BRUTUS2238 Aircraft - Electric - Airplanes (FS/W) 0 Jun 10, 2010 09:31 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Discussion Scratchbuilt F4F Wildcat kylewoody Parkflyers 2 Sep 01, 2009 08:18 PM
