Old Oct 11, 2012, 07:00 AM
Leo L is offline
Find More Posts by Leo L
United States, NY, Queens
Joined Oct 2005
Look at my post # 263 very early in this tread for a detail of a steerable tail wheel for the Wildcat.
Leo L is offline Find More Posts by Leo L
Old Oct 11, 2012, 07:48 AM
Hink64 is offline
Find More Posts by Hink64
Hink64's Avatar
Cape Coral, Fl
Joined Jan 2010
Tail wheel
See my post 3897 - page 260. I used and modified the original tail wheel plastic.
Hink64 is offline Find More Posts by Hink64
Old Oct 11, 2012, 11:01 AM
tengarang is offline
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
thanks Leo L and Hink64
tengarang is offline Find More Posts by tengarang
Old Oct 11, 2012, 11:03 AM
tengarang's Avatar
Joined Aug 2010
Originally Posted by Hink64 View Post
I always thought the tail wheel caster configuration was unique - so, why not try to work with the components provided and give it a little more scale appeal. Was no that hard since the uncarriage plastic is only held with a screw and it is not glued. Hopefully the pics tell the story - and yes it will be steerable.
That is very innovative thank you
Old Oct 11, 2012, 11:07 AM
tengarang's Avatar
Joined Aug 2010
Originally Posted by Leo L View Post
Yesterday i posted photos of landing gear that I made for the F4F. Today it's the tail wheel. After cutting off the dummy wheel, i first tried to use the tail wheel assembly from the Corsair. But after drilling the plate, I found that there is just too much foam in the tail to use the Corsair wheel. So I used the DuBro kit, but needed a longer rod, which I picked up at the local hobby shop. The key is to make sure the pivot of the tail wheel lines up perfectly with the hinge line of the rudder.
Another great Idea Leo L .
Thank you...as a matter of fact, I picked up these Dubro's for the same purpose to implement on my dogfighter...
nice job!
Old Oct 11, 2012, 03:18 PM
Roy G Biv is offline
Find More Posts by Roy G Biv
Semper fera cattus
Roy G Biv's Avatar
Joined Jul 2012
Wildcat 3 blade prop, hop-ups, and paint
Hi Joey,
- Park Zone CORSAIR/TROJAN 3 blade prop (PKZ1015)
http://www.horizonhobby.com/products...-x-7-5-PKZ1015
- E-flite Prop Adapter with Collet, 5mm (EFLM1925)
http://www.horizonhobby.com/products...t-5mm-EFLM1925
- E-flite Power 10 motor (EFLM4010A)
http://www.horizonhobby.com/products...00kv-EFLM4010A
- Hobbywing SkyWalker-40A ESC (SKU: HWG-SC-0893)
http://www.valuehobby.com/power-syst...alker-40a.html
For more on the silver paint scheme see:
http://www.rcgroups.com/forums/showt...2#post22582206
- Roy
Originally Posted by JM66
Hey roy, looking at one of your posts of your wildcats, What prop and prop adapter are you running on them? Is the motor stock?and did you have to upgrade the esc?
I would like to go to a 3 blade prop for more scale looks on my stock wildcat.
Thanks for any info,
regards, Joey
Roy G Biv is offline Find More Posts by Roy G Biv
Old Oct 11, 2012, 03:42 PM
Hink64 is offline
Hink64's Avatar
Cape Coral, Fl
Joined Jan 2010
Originally Posted by Roy G Biv View Post
Hi Joey,
- Roy
Good looker right there!
Old Oct 12, 2012, 02:06 AM
GBLynden is offline
Find More Posts by GBLynden
I am GBLynden
GBLynden's Avatar
United States, WA, Lynden
Joined Mar 2011
Hi Joey,
- Roy
That looks cool!!!
GBLynden is offline Find More Posts by GBLynden
Old Oct 12, 2012, 07:48 AM
Sky_Captain is offline
Find More Posts by Sky_Captain
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
Originally Posted by GBLynden View Post
Tape may ultimately be the way I go for something to help it stand out in the sky. Maybe some red or black racing stripes on the wings.
I wil check out hobbyparts.com, thank you. HK doesn't have any with the connector I need for this plane in their USA warehouse.
At some point you may need to consider getting a soldering iron. HK has a great deal on a very decent soldering iron with adjustable temps for lile $16 plus shipping. It's easier than you think, it just takes some practice.
Sky_Captain is offline Find More Posts by Sky_Captain
Old Oct 12, 2012, 08:04 AM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
GBL, If you are just getting into the hobby forget the soldering iron and go straight for the Anderson power poles.http://www.powerwerx.com/anderson-po...owerpole-sets/. No soldering and will save you countless time and mistakes that other connectors have due to their bad design. When you don't own that many lipos or ESCs is the time to get power poles so you won't have to convert your whole fleet later once you realize how superior these things are to other connectors.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Oct 12, 2012, 02:00 PM
Flying is Freedom
Annandale, VA
Joined Jul 2007
Sorry, but if it's not soldered, its inferior.
They will work for medium amp draw applications like the Wildcat fine. But the least resistance you can get is by soldering.
When I raced electric cars we soldered the battery to the esc for every race and un-soldered it, charged it, and re-soldered for the next race.
Old Oct 12, 2012, 02:23 PM
Tom Moody is offline
Find More Posts by Tom Moody
Rockford, IL
Joined Oct 2003
Sorry, but a properly crimped connection is superior to a soldered connection. Notice I said properly crimped connection.
I worked on full size aircraft for many years and they did NOT allow soldered connectors. They only used crimped connectors.
That is why I use Power Poles for my planes.
Tom Moody
Tom Moody is offline Find More Posts by Tom Moody
Old Oct 12, 2012, 03:26 PM
Flying is Freedom
Annandale, VA
Joined Jul 2007
Yeh, I guess all the RACERS pulling very high amps were all wrong
Here's what I say, do what you want. I'll stick with soldering, it has done well for me so far and that's been a long time.
Old Oct 12, 2012, 07:19 PM
Semper fera cattus
Roy G Biv's Avatar
Joined Jul 2012
What does NASA use?
I read somewhere that there are no solder connections on the
Space Shuttle, only crimped connections. Can that be true?
Old Oct 12, 2012, 07:48 PM
lebl468 is offline
Find More Posts by lebl468
lebl468's Avatar
Cold Lake, Alberta
Joined May 2010
The only place we use soldering on our CF-18's is to bond EMI shielding wrap on our wiring bundles. Every connection is a crimped pin and socket. I do not take this to mean that soldering is inferior, just maybe a little bit of a PITA when you have 1000 connections to make. Just my opinion.
lebl468 is offline Find More Posts by lebl468
Discussion Parkzone F4F Wildcat WOW!!!! ilovejets1 Parkflyers 40 Dec 16, 2015 06:47 PM
Build Log Dumas 17.5" F4F Wildcat LoneRanger Scratchbuilt Indoor and Micro Models 53 Jul 07, 2010 09:34 AM
Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! BRUTUS2238 Aircraft - Electric - Airplanes (FS/W) 0 Jun 10, 2010 09:31 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Discussion Scratchbuilt F4F Wildcat kylewoody Parkflyers 2 Sep 01, 2009 08:18 PM
