65 amp esc tucked in a Wildcat, vertical + fpv. May be I get it. It is not about filming, it is first person! What combat? I think you need a bigger air frame! There is the function over form thing. T-28 may be stop gap. A 1400mm Hellcat is some thing to behold. A Jug that size is amazing. Bet a 40 size ultra stick blows them off! The E-flight mini ultra stick, absolutely blows off the Wildcat in every preformance respect. Once again function or form. Have just about ripped wings off Wildcat with a power 15. MUS does not even shrug with a 15! Look pretty or fly? Want good photos? Chop the nose of a Multiplex Easystar II. Hard to know what you are after from here! Curious to see were ya go! Good luck! Chris |
Yeah.. I think you get it Chris.
It's not about filming smooth shots or slow flying high-altitude scenery footage. I think airborne-go-kart is probably a good way to explain it. Basically I plan to clear out the cockpit to make way for a pan-tilt camera since my goggles will have the headtracker, that way I can look around while I'm flying. The idea is pretty much as "VitaminJ" did in this video:
Only I want to do the same with the wildcat..if she can handle it. VitaminJ used a Dynam (1200mm i think?) p51. I like how warbirds look when they're up on my wall, that's why i'm hung up on them.. and their flying characteristics are good fun. If this project succeeds, i might build another for a friend so that we can fly in formation.. but that's way down the road.. first I gotta decide on my airframe. hehe. Cool thing about the wildcat is that it's got a big surface area where the cockpit is.. so plenty of room for the camera. |
I will watch the Mustan vid later. Formation, what a concept. I expect the fpv stuff that was state of the art, 2 years ago is klunky. I am thinking a big shallow pitch prop and may be even one of these new multi axis gyros will help. Ironic, in that my thinking has it, that the gyros would make up for the fact ones vestibular system in not in the plane and ones eyes are not in the plane. Please keep us posted on how you proceed! Chris |
Danville, CA
The speed won't matter as long as you don't slam on the controls too hard. You might add blenderm tape to all of the hinges and replace your elevator servo with one with metal gears. I recently got some replacement servos. I didn't want to wait so long so I got a parkzone metal gear (pkz1090) and some HS-55 plastic gear servos from HH.
Don't forget you get what you pay for.....just sayin' Don AMA 384859 |
![]() Try Heads up Rc! If you go digital, check to see if your bec is adequate. Good luck. Chris |
Joined Oct 2011
Bent motor shaft
Crashed my wildcat friday, broken cowel and I bent my motor shaft or prop adapter. Still have to prove if motor shaft or prop adapter is bent. Can the motor shaft be replaced without buying a new motor if the wobble proves to be the motor shaft?
I have done 2 shafts (same type of motor), one on my Stinson and one last week on my WildCat. If you have good quality hex keys the shaft change goes good. My Wildcat took 15min total. I stripped the grub screws on the Stinson motor, and had to grind the collar off and replace it.
Joined Oct 2011
Joined Aug 2012
Wildcat Noob
After learning to fly a Radian, I decided to go with the Wildcat as a first power plane. I'm learning a few things the hard way, but boy is that one tough plane! My worst crash broke the motor mount right off the fusalage. I glued it back together ( and a couple of times since) and it still flys. Unbelievable. This is great fun, and I am looking forward to reading more of this thread.
| Thread Tools | |
| Discussion Parkzone F4F Wildcat WOW!!!! | ilovejets1 | Parkflyers | 34 | Dec 09, 2010 09:29 PM |
| Build Log Dumas 17.5" F4F Wildcat | LoneRanger | Indoor and Micro Models | 53 | Jul 07, 2010 09:34 AM |
| Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! | BRUTUS2238 | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 10, 2010 09:31 AM |
| Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread | skyjet | Micro RTF | 2 | Mar 19, 2010 03:00 PM |
| Discussion Scratchbuilt F4F Wildcat | kylewoody | Parkflyers | 2 | Sep 01, 2009 08:18 PM |
