Old Jun 24, 2012, 09:03 AM
Sky_Captain is online now
Find More Posts by Sky_Captain
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
Originally Posted by Left Coast DJ View Post
Next time I go fly my Wildcat, I'm going to try an underhanded toss. Anyone chuck their F4F underhanded?
It would work just as well. I toss my F-86 underhanded, but I have to toss it a little harder.
Sky_Captain is online now Find More Posts by Sky_Captain
Old Jun 24, 2012, 09:17 AM
msdumo is offline
Find More Posts by msdumo
Canada, ON, Calabogie
Joined May 2011
Originally Posted by CodeJock View Post
So, back to the stock prop and an order placed for a replacement cowl (there was no hope of repairing the original one - it was too far gone).
I got tired of breaking cowls and props.
My landing gear works well. http://www.rcgroups.com/forums/showp...postcount=8159
After 10 landings I had 1 damaged prop. Going to use SF E-9x6 props that cost 1/6 the price of a Parkzone prop.
msdumo is offline Find More Posts by msdumo
Old Jun 24, 2012, 10:56 AM
Colbyntx is offline
Find More Posts by Colbyntx
Carthage, TX
United States, TX, Tenaha
Joined Mar 2012
I have to underhand toss everything! Old football injuries have taken most of my overhand options away. The F4F launches great underhand. I even underhand my 55" P-40 with easy. Being 6'2" has its advantages and glad I have big hands!!!
Colbyntx is offline Find More Posts by Colbyntx
CodeJock is offline
Find More Posts by CodeJock
Builds better than he flies
Germany, BY, Munich
Joined May 2012
Yeah, I saw that a few days ago. I quite like the look of a couple of the retractable solutions that some people have been working on too.
Depending on how many more props/cowls I may lose, it could be worth the investment.
CodeJock is offline Find More Posts by CodeJock
Old Jun 24, 2012, 10:58 AM
CodeJock is offline
Germany, BY, Munich
Joined May 2012
Originally Posted by quitcherbitchen View Post
Perhaps, O'Hare's radio was not working and he was reporting a mechanical mission abort. Obviously, things got a little complicated at his workstation. I think the CO is going to chew out the mechanic. Multiple "Unsats"--Voice radio, Cosmic dampener, and Vibration issues.
Could be
Given that I am the CO, pilot and mechanic I should be giving myselves a really stern talking-to!
Old Jun 24, 2012, 11:22 AM
dav3uk is offline
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
So took my tubby out to the field and two three-bladed props and one cowl later I returned home down-hearted.
I fitted the PZ three-bladed props 'cause I wanted to compare the performance. Well, first launch and dunno what happened (I suspect cosmic rays ) she just nose-dived hard into the ground, cracked the cowl and bust a blade off the prop.
The damage wasn't actually that bad - although one of the wings got unseated in the crash. I re-glued that with my emergency glue and let it cure whilst I flew something more appropriate for my apparent (lack-of) skill today.
All fixed (notwithstanding the cracked cowl), I fitted a replacement prop. and tried again. This time (no cosmic rays) she took off beautifully and soared and swooped as graceful as you like. The cowling was rattling a little - but actually sounded pretty good; like the real thing! Anyhoo at some point something was clearly wrong because for no reason at all that I can fathom (except perhaps excessive vibration due to the cowl) Pilot Pete (aka Lt. O'Hare) "ejected"!
The cockpit flew off the fuselage and floated sedately to the ground whilst I struggled (quite a bit) to keep control of her (the drag effect caused by an open fuselage is phenomenal) and tried to bring her down as effectively as I could (which wasn't easy given she was handling like a brick). Result - another ding as I hit the ground too hard, another broken blade on my prop and a shattered cowl.
The PZ 3 blade prop is made of a very brittle plastic, it takes nothing to lose a blade. I loved the 3 blade on my Corsair, so quiet but alas one nose over and it was gone. I use MAS or GWS 3blade props now and APC and HL 4 bladers and not lost a blade since.
Dave
dav3uk is offline Find More Posts by dav3uk
Old Jun 24, 2012, 12:26 PM
CodeJock is offline
Germany, BY, Munich
Joined May 2012
Yeah, I noticed that. I use them on other planes, but they have landing gear so it's never been a problem (unless I go arse over nose with the motor running).
I don't have a problem with the stock prop, so I'll just go back to using that.
Old Jun 24, 2012, 06:57 PM
yellerchief is offline
Find More Posts by yellerchief
yellerchief's Avatar
United States, IL, Oakland
Joined Aug 2006
Got 2 flights on the wildcat, flew really nice had a friend launch it no trim added, flew formation with a hangar nine at-6, looked cool, landed it no issue's, I have already had 1 shoulder surgery not sure if I can launch it myself
yellerchief is offline Find More Posts by yellerchief
Old Jun 25, 2012, 01:09 AM
CodeJock is offline
Germany, BY, Munich
Joined May 2012
Dual Aileron Output
So is anybody using the second aileron channel on the ARS500 stock receiver?
As my bird is laid up until the new cowl arrives I have been looking at fine-tuning the rates, expos and throws and have struggled with the differential in the ailerons. Then I noticed that there is a second connection on the receiver for the aileron (which works 'cause I plugged in a bare servo).
Old Jun 25, 2012, 01:27 AM
LunaRendezvous is offline
Find More Posts by LunaRendezvous
Registered Drug Free
LunaRendezvous's Avatar
Joined Jan 2009
Is not a separate channel, simply functions as an internal Y-connector.
LunaRendezvous is offline Find More Posts by LunaRendezvous
Old Jun 25, 2012, 01:42 AM
CodeJock is offline
Germany, BY, Munich
Joined May 2012
Ah, Ok. Thanks Luna. That probably means I won't be able to set up the differentials then.
Old Jun 25, 2012, 02:39 AM
Joined Jan 2009
I'm not a 100% certain but depending on your radio you may be able to reprogram the gear channel to enable differential aileron control, try searching in the radio forum or starting a new topic there.
Old Jun 25, 2012, 07:19 AM
bostomper is offline
Find More Posts by bostomper
Joined Aug 2010
Found a new way to launch it. Did my usual hand toss but was slow getting to the elevator and it nosed into the ground at 3/4 throttle. Must have hit the elevator just in time to flair it, as it hit the ground and bounced about 2' into the air. Hit throttle and away it went. Would not recommend this technique however(lol). Wind was 12-15mph and it handled pretty well, thrown around a little bit. Did alot of loops and rolls. It is really responsive to control inputs, so even when I screw up it can be corrected quickly. What a great little plane.--Bo
bostomper is offline Find More Posts by bostomper
Old Jun 25, 2012, 07:32 AM
CodeJock is offline
Germany, BY, Munich
Joined May 2012
That's pretty much what happened to me, but I think it must've been those Cosmic Rays again (moving West I would imagine).
Mind you, my "landing" was a little less forgiving.
Old Jun 25, 2012, 09:23 AM
oscarlovel is offline
Find More Posts by oscarlovel
Joined Aug 2007
Maidened my new F4F this yesterday. It turned out to be a handfull. The aircraft is definitely tail heavy with the stock 1300 li-po, or at least mine is, causing it to be highly unstable. I'm going to add some weight to the nose. It also wants to roll right in certain throttle settings. I've read here that others have taped quarters to the left wing to counteract this. The plane is definitely weighted right-wing heavy from the box. Like the plane, but need to get this straight before I try any more flights. Flew it for four flights with various trim settings, and was lucky to get it safely on the ground a couple of times. Would appreciate any advice from those more familiar with this plane. BTW, I've owned and flown a PZ Spitfire MKII for a few years now since they came out and have flown RC off and on for nearly 40 years. Have never progressed beyond intermediate though.
oscarlovel is offline Find More Posts by oscarlovel
Discussion Parkzone F4F Wildcat WOW!!!! ilovejets1 Parkflyers 40 Dec 16, 2015 06:47 PM
Build Log Dumas 17.5" F4F Wildcat LoneRanger Scratchbuilt Indoor and Micro Models 53 Jul 07, 2010 09:34 AM
Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! BRUTUS2238 Aircraft - Electric - Airplanes (FS/W) 0 Jun 10, 2010 09:31 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Discussion Scratchbuilt F4F Wildcat kylewoody Parkflyers 2 Sep 01, 2009 08:18 PM
