Old Jun 19, 2012, 01:16 AM
CodeJock is offline
Find More Posts by CodeJock
Builds better than he flies
Germany, BY, Munich
Joined May 2012
Originally Posted by ddog343 View Post
Yes, It sure is, all at once, and even in the field if you suspect somethings wacky....
Having that lug always gives you a consistent reference point! Have a few more pic in my blog showing some different airframes...and how they hang.
Oh, and by the way, welcome to the "Warbird" club!
Thanks!
CodeJock is offline Find More Posts by CodeJock
Old Jun 19, 2012, 09:30 AM
shepflyr is offline
Find More Posts by shepflyr
United States, SC, Charleston
Joined Aug 2011
Originally Posted by IFlyRCs View Post
shepflyr, I tell everyone that likes flying in the wind to try a 2200. So, Try a 2200...
Wretcho, Sounds fun, good luck with it.
2200? Got 'em. Can do!
It's not that I especially like flying in wind, although sometimes it is a lot of fun. It's just that at the grass field I fly at, there's often not any choice...fly in wind, or don't fly!
Thanks!
shepflyr is offline Find More Posts by shepflyr
Old Jun 19, 2012, 06:36 PM
emeraldc is offline
Find More Posts by emeraldc
west coast flyer
emeraldc's Avatar
Joined May 2012
I use 1 oz of lead strapped under those finger holes, for the 2200. Otherwise you will be nose heavy.
emeraldc is offline Find More Posts by emeraldc
Old Jun 19, 2012, 08:54 PM
shepflyr is offline
Joined Aug 2011
That's why a number of pilots on this thread report using a 1/4" + styrofoam spacer in front of the batt in the batt box. Shifts the CG back to compensate without adding additional weight. Either way, getting the CG right is really important on this plane!
I have added small lead weights to several UM's, especially when they're tail heavy, and that's helped a lot. Will do it to this one if the spacer doesn't fix it.
Old Jun 19, 2012, 11:43 PM
Wretcho is offline
Find More Posts by Wretcho
Wretcho's Avatar
Australia, WA, Osborne Park
Joined Jul 2011
I use a 1/4 inch block of foam in front of my lipos for CG, both with 2200's and my 1800's 3s. I do have a heavier motor also which affects the cg. I hate adding dead weight to planes
Have played around with moving the weight further back, harriers like a bawse!
Wretcho is offline Find More Posts by Wretcho
Old Jun 20, 2012, 06:33 AM
msdumo is offline
Find More Posts by msdumo
Canada, ON, Calabogie
Joined May 2011
It took a 5/8 inch spacer on my 2200 2S to get it right.
msdumo is offline Find More Posts by msdumo
Old Jun 20, 2012, 07:52 AM
winndaddy is offline
Find More Posts by winndaddy
My poor poor planes.
winndaddy's Avatar
United States, LA, Lake Charles
Joined May 2012
I added so much spacer I went and got a longer strap.
I use 40c batterys with the power 10 though. She buggies!
winndaddy is offline Find More Posts by winndaddy
Old Jun 20, 2012, 08:08 AM
shepflyr is offline
Joined Aug 2011
I changed to the longer batt strap when I added the 1/4" spacer even with the Thunder Power 1350. That short strap and the way they designed the upper slot it goes in is a real pain to work with...unless you're a kid with tiny fingers!
Old Jun 20, 2012, 09:08 AM
emeraldc is offline
west coast flyer
emeraldc's Avatar
Joined May 2012
That's what I carry a small pair of needle nose plyers for. Otherwise ya, threading the strap is an excersize in frustration
Old Jun 20, 2012, 10:15 AM
msdumo is offline
Joined May 2011
I use a foam wedge that I made up between the carbon wing spar/rod and the rear of the battery. The magnetic cockpit holds it in place. Works well and is much easier than the strap.
Old Jun 20, 2012, 10:16 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
You should never have to thread the strap.
And never unhook the velcro at all.
Leave it just a touch loose and just slide it off the side of the battery.
You can easily slide it on and off.
The battery will be plenty secure.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Jun 20, 2012, 10:24 AM
emeraldc is offline
west coast flyer
emeraldc's Avatar
Joined May 2012
When you switch from back & forth from 1300-2200 battery, you have to change straps.
Old Jun 20, 2012, 10:53 AM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Good point, I only run 2200's...
Old Jun 20, 2012, 05:51 PM
msdumo is offline
Joined May 2011
I'm tired of replacing props and cowls on my Wildcat.
Where I fly the landing is in a slightly grassy gravelly area. On landing I usually break the cowl; sometimes break a prop; and inhale gravel into the motor and have to blow it out. I'm on my 3rd cowl and second prop.
Time for a landing gear
I used the LG from a Extra 300.
Main Landing gear $1.99
Landing gear plate $3.99
I cut thru the skid plate and foam to fit the Extra 300 landing gear plate in the belly of the plane. With gorilla glue and epoxy it's solid.
For ~$6 I now have a LG that I can take off or keep on. I'm hoping the LG will mean fewer cowls at $6.99 and props at $3.99
Old Jun 20, 2012, 06:11 PM
Leo L is offline
Find More Posts by Leo L
United States, NY, Queens
Joined Oct 2005
Nice set up!!! You will love flying the Wildcat with landing gear. I've had landing gear on my Wildcat since the day I first put it together, I guess three to four years ago.
Leo L is offline Find More Posts by Leo L
Discussion Parkzone F4F Wildcat WOW!!!! ilovejets1 Parkflyers 40 Dec 16, 2015 06:47 PM
Build Log Dumas 17.5" F4F Wildcat LoneRanger Scratchbuilt Indoor and Micro Models 53 Jul 07, 2010 09:34 AM
Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! BRUTUS2238 Aircraft - Electric - Airplanes (FS/W) 0 Jun 10, 2010 09:31 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Discussion Scratchbuilt F4F Wildcat kylewoody Parkflyers 2 Sep 01, 2009 08:18 PM
