Old May 07, 2012, 09:37 PM
potxoli's Avatar
Joined Apr 2006
Originally Posted by windrnone View Post
Moving the COG helps, I only used a 1/4" foam spacer, low rates helped me, I also sleeved the control rods where they pushed thru the foam fuse, I feel that it made the elev action smoother.
Good tips! I'll give it a shot
potxoli is offline Find More Posts by potxoli
Old May 07, 2012, 10:51 PM
You Know What I Mean
LaserBeam's Avatar
Australia, NSW, Sydney
Joined Dec 2011
Camera Mounting
Whats the best way to mount a ccd camera onto the Wildcat please?
-Where did you mount camera?
-How did you secure camera to Wildcat?
-Did you face camera horizontally forward or pointing down a bit to face the cowling?
-etc
many thanks
LaserBeam is offline Find More Posts by LaserBeam
Old May 08, 2012, 12:05 AM
Sloper padawan
Boulder, CO
Joined Sep 2009
Originally Posted by Left Coast DJ View Post
Interesting. One of my stabilizer fin's texture is bubbly and different from the rest of the plane. The fin also has a slight curve up to it. Does this mean it's a warp?
The word "bubbly" caught my eye. Sounds like it's been exposed to heat.
Foams that are injection molded from beads will show bumpiness in areas that get much on the north side of 250F. This often happens when someone tries to use a heat gun to reshape foam and gets too close. Perhaps your bird got left against a hot water pipe or something. (Boiling water or steam is a better way to heat foam for repairs.)
Erasmas is offline Find More Posts by Erasmas
Old May 08, 2012, 06:35 AM
Wamp's Avatar
Joined Mar 2012
Originally Posted by headlessagain View Post
Nice Andy! Thanks Chris
Wamp is online now Find More Posts by Wamp
Old May 08, 2012, 06:54 AM
Wamp's Avatar
Joined Mar 2012
Did you use the "Thread tools", "Show attachments..." as this will just show photos etc. Once you find something of interest, just left click on the image and click on "(post/pic in the post" This should speed thing up.
I maidened my Wildcat yesterday evening. Put in some up trim and had a club member launch it for me. Climb out was near vertical so quickly took out the trim and trimmed her out. Happy with the flight characteristics but not as fast as I would have thought bearing mind my motor combo. Good vertical and plenty of thrust so was happy to do the 2nd launch myself. It's an awkward shape to hold being so bulbous. I ended up holding it in my right hand with my thumb on top of the wing & my fingers spread out underneath. A gentle shove and she was away. I don't know if my lipo was getting tired as the first flight ended with me landing dead stick in the outfield. At least it was into wind and no damage. I limited my 2nd flight to 4 mins which I think I can stretch to 5min with a bit of left stick restraint.
Can't post vid yet as WMM is on the blink. No video image in preview window!
Andy
Andy, I had to were my hand ends up for launch.
It is one of those things I do better when I do not think about it!
My purchase is pretty far back.
My thumb is just about on the elevator control rod, palm some what over
the last cooling hole. The fuse is a nice shape for me there.
Naturally some how a little arm motion levels the plane.
I really do not throw it, but some energy is imparted.
That energy has a little direction opposing motor torque.
Rarebear may be a flea on crack! Good luck Chris
Old May 08, 2012, 06:59 AM
Wamp's Avatar
Joined Mar 2012
Had to look! Da
Old May 08, 2012, 07:22 AM
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Wait till I put a 4 cell in her! :-)
headlessagain is offline Find More Posts by headlessagain
Old May 08, 2012, 10:49 AM
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
I don't think heat is the issue. It's the foam, from the factory. It's Z-foam but it looks and feels very different from the P51 BL or even the Spitfire Mk 9. The horz stab feels really soft and the foam beads are large and bumpy.
The warping is common. Even the pictures on the Horizon website show hints of it.
This is not an illusiion from the angle of the shot. For some reason, the horz stab foam on the Wildcat is just not very stable. The stab develops an upward warp all on its own. Add paint like me and it gets worse. lol
shunyata is offline Find More Posts by shunyata
Old May 08, 2012, 02:06 PM
Left Coast DJ's Avatar
Joined Jan 2012
While I don't coddle my planes, I also try not to abuse them... at least when not flying ( ). I take my Wildcat to work with me a few times a week so I can put a few batteries through it at the park on my way home from work. Though I take the radio and batteries inside to my work, I leave the Wildcat in the car covered by a sheet. So it does get exposed to Southern California daytime heat.
However, if so, the "bubbling" and warping, I think, should be more uniform throughout the plane. Mine are limited to the left stab and ends right at the connection to the right one. And the slight upward warping looks exactly like in the plane Shunyata posted.
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old May 08, 2012, 05:27 PM
X-37B
HapG's Avatar
United States, WV, Morgantown
Joined Jan 2012
Thanks very much for posting about the horizontal stab. I thought I was the only one with the problem. One side is ok, the other is flimsy, rough surface and warped.
I used Very hot water to fix the warp, which it did - but the material felt even weaker afterwards.
HapG is offline Find More Posts by HapG
Old May 08, 2012, 05:56 PM
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, Altadena
Joined Jul 2011
Reinforce it with some carbon fiber
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old May 08, 2012, 08:08 PM
Ελλάδα, Αττική, Αχαρναί
Joined Mar 2011
I got my wildcat in my hands a few hours ago. I also had a warped horizontal stab. Fixed it with some hot steam though. What bothers me is that I got one with the plastic bell(I got an apprentice with a plastic motor also,and Horizon Hobby sent me a new one),just my luck, I always get old stock... How easy is it to crack?Should I search for a replacement immediately? I will not ask Horizon to send me another one, they helped so much that I feel bad asking them(except if it breaks in the first few flights...eventhough I doubt they will send me a new one..AGAIN!), so without changing the esc,what would be a cheap replacement(something from hobbyking maybe?)?
Skropi is offline Find More Posts by Skropi
Old May 08, 2012, 08:36 PM
Joined May 2012
Wow, sorry to hear about all the warping guys. I got mine last year and it is STRAIGHT as an arrow. All surfaces. In fact, I was just comparing it to the HobbyKing P-51 Durafly model I received. Almost every surface on the Hobby King is warped. Very dissapointed when compared to the F4F.
Got some paint on her floats today. Thanks for all the paint recommendations!!! Worked out perfectly.
Pete48 is offline Find More Posts by Pete48
Old May 08, 2012, 08:57 PM
'tis nothing
shunyata's Avatar
Joined Dec 2011
Yeah, I'm going to do what quitcherbitchen suggested, CF. Seems strong enough otherwise.
Even with the little problems with this bird, she's still one of my favorites, even just sitting there, waiting for me to take her out - which has been a while.
edit: Those floats look AWESOME!
Old May 08, 2012, 10:00 PM
Joined Jun 2011
Originally Posted by Skropi View Post
A quick question guys. Is it needed to install skids so as to protect the aileron servos?How many of you went for that option? I am afraid my servos will not survive(I am getting the wildcat tomorrow!).
I had grass snag the control rod once and broke the servo arm. I made a small fin in front of each control rod to deflect the grass.
Ramblin is offline Find More Posts by Ramblin
Discussion Parkzone F4F Wildcat WOW!!!! ilovejets1 Parkflyers 34 Dec 09, 2010 09:29 PM
Build Log Dumas 17.5" F4F Wildcat LoneRanger Indoor and Micro Models 53 Jul 07, 2010 09:34 AM
Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! BRUTUS2238 Aircraft - Electric - Airplanes (FS/W) 0 Jun 10, 2010 09:31 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro RTF 2 Mar 19, 2010 03:00 PM
Discussion Scratchbuilt F4F Wildcat kylewoody Parkflyers 2 Sep 01, 2009 08:18 PM
