Old Apr 02, 2012, 05:54 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Originally Posted by Dr.Crashenburn View Post
Another good bit of info, thanks.
Do you know if he strengthened the firewall at all?
Just getting as much info as i can.
I don't recall. But I would probably make a plywood adapter between the Fuselage and the glow motor mount.
TripleW is offline Find More Posts by TripleW
Old Apr 03, 2012, 07:07 AM
Wamp is offline
Find More Posts by Wamp
Wamp's Avatar
Joined Mar 2012
Originally Posted by tengarang View Post
understand the failsafe now... will research more thanks fellas
Rebinding after trimming helps. I agree not much could help except a T cut.
As a kid I put an 0.49 on a foam glider, only to see the foam disapear!
A priest build a kit plane which was the end of him when fule got behind paint.
It went un seen, until structural failure.
Scratch that itch! Chris
Wamp is offline Find More Posts by Wamp
Old Apr 03, 2012, 09:09 AM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
Any of you Wildcatters also own an E-Flite Sea Fury 400/480? If so a build and flight characteristic comparison?
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Apr 03, 2012, 03:47 PM
Gotahaavet is offline
Find More Posts by Gotahaavet
Joined Mar 2012
HELP
Can I get a eflite power 10 and use a 30amp speed controller or do I need to upgrade that as well again?
If I don't what prop can I use I don't have a amp meter
Gotahaavet is offline Find More Posts by Gotahaavet
Old Apr 03, 2012, 04:04 PM
btflycrazy is offline
Find More Posts by btflycrazy
btflycrazy's Avatar
United States, WI, Wausau
Joined Sep 2010
If you want the most out your power 10 i would up the speed controller to 40amps or more, but if you cant try a 9x8 or even a 10x8 prop and keep full throttle between 5 and 10 seconds and a good 30 seconds to cool back down
btflycrazy is offline Find More Posts by btflycrazy
Old Apr 03, 2012, 04:26 PM
Joined Mar 2012
Will the power 10 bolt right up to the factory motor mount ?
How about if I run a 10x7 apc prop?
Old Apr 03, 2012, 04:40 PM
Alpha_Geist is offline
Find More Posts by Alpha_Geist
Alpha_Geist's Avatar
United States, CA, Elk Grove
Joined Dec 2011
Power 10 is a direct bolt on. So no worries there.
The 10x7 looks to be about 35A max with 45C Lipos.
Alpha_Geist is offline Find More Posts by Alpha_Geist
Old Apr 03, 2012, 06:57 PM
Joined Mar 2012
Thank you so much for the help I will try a Trojan prop and the power 10 unless you think wise
Old Apr 03, 2012, 07:15 PM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
Funny you bring this up. I've been looking at this plane lately, too. I have all the bits to build one.
Shorter wing span, 5-6 more ounces than the Wildcat or the P51BL, my guess is it will have an edge over the other two, more stable, better in the wind. Might land a bit faster?
shunyata is offline Find More Posts by shunyata
Old Apr 03, 2012, 07:54 PM
ands is offline
Find More Posts by ands
wottree
United Kingdom, England, Exeter
Joined Nov 2011
Anybody able to get to lake vyrnwy for a photo shoot and shin dig; end off May?
UK, north Wales
http://maps.google.co.uk/maps?um=1&i...e&ved=0CCsQtgM
ands is offline Find More Posts by ands
Old Apr 03, 2012, 07:58 PM
Joined Dec 2011
With the Power 10 and the T-28 prop, you will be at +31A. I would think about picking up a larger ESC.
A few people here, me included, use the Castle Creations Thunderbird 54A ESC without any issues whatsoever. However, at least pick up at minimum a +40A ESC.
Cheers!
Old Apr 03, 2012, 08:05 PM
mondo1948 is offline
Find More Posts by mondo1948
mondo1948
mondo1948's Avatar
Rocky Hill, Connecticut
Joined Dec 2007
A few people here, me included, use the Castle Creations Thunderbird 54A ESC without and issues whatsoever. However, at least pick up at minimum a +40A ESC.
Cheers!
I agree....when I upgrade my Parkzone Warbirds to an E-Flite Power 10 motor, I always use a Castle Creations Thunderbird 54amp ESC also....of course, it can only be used with 3-cell batteries....NOT 4-cell. Here's a link to a guy I've bought several from on Ebay....the price is fabulous.
http://www.ebay.com/itm/Brand-New-Ca...item43ae7003ff
If you buy more than one, he will combine the shipping, but even $37.00, shipped for one is a good deal.
Since the Power 10 has a 5mm shaft, you can't use the T-28 prop adapter. Rather, just order the prop adapter made for the Parkzone P-47, whose motor has a 5mm shaft. Here's a link to the prop adapter....
http://www.horizonhobby.com/webapp/w...pe=productgrid
With this adapter, you can still use the T-28 9.5x7.5 prop, which gives a great speed/amp ratio.
I hope this helps,
Mondo
mondo1948 is offline Find More Posts by mondo1948
Old Apr 03, 2012, 08:21 PM
Joined Dec 2011
Great Scott! What a sweet deal on the CC TB 54A esc there mondo. You are 100% correct about those ESC's being up to 3S ONLY.
Good find!
Old Apr 03, 2012, 09:08 PM
johrich is offline
Find More Posts by johrich
johrich's Avatar
United States, GA, Kathleen
Joined Dec 2007
Well, I've been flying helis for about 4 years and about 3 months ago, I got the plane bug. Flew a PZ micro T-28 for a month and last week bought a PZ Wildcat. Maidened it tonight. Bought the PNP version and put a Spektrum recvr I had in it along with one of my 450 Heli batteries, a 2200 mah. Flight was great. A little more faster and responsive than what I was used too, but it turned out OK. I really like this plane.
johrich
johrich is offline Find More Posts by johrich
Old Apr 03, 2012, 11:07 PM
tberg44 is offline
Find More Posts by tberg44
United States, SC, Beaufort
Joined Mar 2012
Finally took my Wildcat to the skies, now I am curious if anybody else has mounted a GoPro to their Cat? If so, where you think is the best place to mount it? I posted this question in the Corsair forum as I also got one last weekend but would assume there might be different mounting locations for different planes... Feel free to post pictures, I'd greatly appreciate your help!
tberg44 is offline Find More Posts by tberg44
Discussion Parkzone F4F Wildcat WOW!!!! ilovejets1 Parkflyers 40 Dec 16, 2015 06:47 PM
Build Log Dumas 17.5" F4F Wildcat LoneRanger Scratchbuilt Indoor and Micro Models 53 Jul 07, 2010 09:34 AM
Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! BRUTUS2238 Aircraft - Electric - Airplanes (FS/W) 0 Jun 10, 2010 09:31 AM
Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread skyjet Micro Ready-to-Fly 2 Mar 19, 2010 03:00 PM
Discussion Scratchbuilt F4F Wildcat kylewoody Parkflyers 2 Sep 01, 2009 08:18 PM
