My Club is 1 hour drive so I spend the day there and usually I put in about 20 flights including Helis too but today was only 2 heli flights , 1 EDF Jet (EVADER) 2 motor glider and the rest was 12 Wildcat flights.
It was extreamly windy until about 5pm so I didn't fly as much. It does look real and with a 3 blade it will look even better, I just hope to get the same performance.
I've been sticking with the 1300 size battery and I have been slowly moving it back. Today I had to dial in a lot of right aileron trim for level flight. I will check it out this weekend as to why I needed to do that. Too tired tonight. At 7:00 this morning the color of the sky with the sun at our back was an excellent match with the blue of the plane but I had no problem as I kept her fairly close to me. Very nice at slow speed. Mike H
Latest blog entry: New receiver packs and asking Castle for...
At first I had placed a piece of foam rubber in front of the 2100 Lipo but I then removed it and liked it better.
With the TP 2100 my CG is exactly at 1 7/8 like the book says. The only change I did in the building is were they mention to use the clear tape to hold the stab well I use clear adhesive silicone and its nice and snug. It still could be remove need be. The rest is by the book. Cant wait for tuesday, my next day off
Would you guys say this plane is as easy to fly as the T-28 or more like the P51?
how long are average flight times? |
Latest blog entry: Estes Rubber Band Condor gets powered...
F4F Maiden
Hi all,
I am a new Wildcat owner. Flew my first 4 flights yesterday afternoon with the following observations: 5-7 mph winds high broken clouds Did the first three flights on 3S 1300's. Flight times were 6-7 minutes and put anywhere from 840 to 875 mah back in each batt on charge. Very nice flying qualities. Not as much up elevator needed in a downwind or a steep turn as the P-51 BL. Faster roll rate on high rates than the '51. Loops can be as big as you want (within reason) or pretty tight. Did the last flight on a 3S 2100; flew for 9 minutes and put 1106 mah back in it. Just a little more nose heavy with the 2100 but not enough to make any real difference, didn't even need to trim it out. Both the 1300 and the 2100 were placed as far forward in the batt compartment as they would go. My biggest complaint thus far is it was hard to maintain orientation at times when the plane would go into patches of blue sky but only because it was farther away than I should have been. If you keep it in close it will be no problem. I might try those high vis decal sheets that someone put on their wings (sorry, don't remember who) that I read about many posts back. Overall I feel this plane is a winner and it has now become my go to flyer over the 'Stang...I know that is hard to swallow but I love the "feel" of the Wildcat. Nothing against the Mustang mind you, I'll still get plenty of flights on it and enjoy it as well. Oh yeah, one more thought. Kudos to the poster who put the little tab of tape on the back of the canopy to make it easier and less damaging to the fuselage sides to remove the canopy (hatch). I used your tip and wow! what a great idea, it works perfectly. My apologies for not recognizing you. This is a great place to share, observe and learn. Looking forward to reading about all your tricks, tips and flying experiences with the Wildcat. Ken |
Bavaria, Germany
Joined Nov 2008
That's why they used this color in WWII...this happened to me as well once, my Corsair was soo far out that I could hardly spot her and I had lost the orientation as too how she was positioned in the air. I almost lost her that day and I was really lucky that I got her back in one piece. It was a good range check for the DX6i though... cheers Uwe |
I see a noticable difference in the MAH taken between me and Diesel Nine, I have to say that I was flying mine at a scale speed so always under full power so with power management I know I could do a 15 min flight with ease on a 2100.
I also use the clear tape tap for the hatch, its real good thank you for the tip.
| Thread Tools | |
| Discussion Parkzone F4F Wildcat WOW!!!! | ilovejets1 | Parkflyers | 34 | Dec 09, 2010 09:29 PM |
| Build Log Dumas 17.5" F4F Wildcat | LoneRanger | Indoor and Micro Models | 53 | Jul 07, 2010 09:34 AM |
| Wanted TRADE MY NEW EFLITE P47 your ALFA F4F WILDCAT! | BRUTUS2238 | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 10, 2010 09:31 AM |
| Discussion The first OFFICIAL Parkzone Sukhoi SU-26XP BNF by ParkZone Owners thread | skyjet | Micro RTF | 2 | Mar 19, 2010 03:00 PM |
| Discussion Scratchbuilt F4F Wildcat | kylewoody | Parkflyers | 2 | Sep 01, 2009 08:18 PM |
