Old Jun 22, 2003, 01:00 PM
Takao Shimizu is offline
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
One hour CD_ROM motor construction
This is CD ROM motor easy construcion without rewinding.
Takao Shimizu is offline Find More Posts by Takao Shimizu
Old Jun 22, 2003, 01:05 PM
Tokyo, Japan
Joined Nov 2002
Change Y to Delta.
Old Jun 22, 2003, 01:07 PM
Tokyo, Japan
Joined Nov 2002
Just termination wiring change.
Old Jun 22, 2003, 01:11 PM
Tokyo, Japan
Joined Nov 2002
CA the prop shaft with PET 5mm nut for prop screw shaft.
Old Jun 22, 2003, 01:14 PM
Tokyo, Japan
Joined Nov 2002
Test result;
GWS 8043, 6V, 2.4A, Thrust 83g, 3720rpm
Old Jun 22, 2003, 01:56 PM
jmbig is offline
Find More Posts by jmbig
North Highland,ca
Joined Dec 2002
Delta does give a better torque range!!! CU
jmbig is offline Find More Posts by jmbig
Old Jun 23, 2003, 07:40 AM
Tokyo, Japan
Joined Nov 2002
This is the original Y termination.
Old Jun 23, 2003, 08:04 AM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
very informative
is there a one hour convert your speed control to brushless speed control????
Robbie d is offline Find More Posts by Robbie d
Old Jun 23, 2003, 07:21 PM
Tokyo, Japan
Joined Nov 2002
Robbie d,
Not yet.
Old Jun 27, 2003, 08:51 PM
Tokyo, Japan
Joined Nov 2002
More details
You may need motor mount cutting.
I use just hand powered cutter tool($7) and sand paper.
Old Jun 27, 2003, 08:54 PM
Tokyo, Japan
Joined Nov 2002
More details
De-solder and de-twist at the Y coil connection point.
De-paint is usefule to nude-off the coil wire paint.
Old Jun 27, 2003, 08:56 PM
Tokyo, Japan
Joined Nov 2002
Put on the plane.
Old Jun 27, 2003, 08:58 PM
Tokyo, Japan
Joined Nov 2002
Ready to test fly
You may need the timing adjust of ESC.
4A ESC is enough to drive this.
Old Jun 28, 2003, 08:12 AM
ssatoru is offline
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Another ready to fly
I am also modifying the same CDROM motor. Only different way to mount on the plane. Ready to fly tomorrow.
YG-F1G Delta wind
GWS 6x5SF 7.29V 2.25A 16.40W 5,520rpm
rewound with 0.4mm 20T
GWS 7x6SF 5.63V 5.86A 33.00W 4,010rpm
GWS 6x5SF 6.10V 4.92A 30.00W 6,720rpm
satoru
ssatoru is offline Find More Posts by ssatoru
Old Jun 28, 2003, 11:21 AM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
This is a great contribution. I can't wait to get started on a conversion myself.
bz1mcr is offline Find More Posts by bz1mcr
One hour CD ROM motor construction PART2 Takao Shimizu Power Systems 754 Sep 08, 2010 12:12 PM
One hour CD ROM construction part 7 rysium Power Systems 806 Dec 18, 2006 02:58 AM
One hour CD ROM construction part 6 arx_n_sparx Power Systems 1050 Mar 10, 2005 07:08 PM
One Hour CD ROM Construction Part 5 arx_n_sparx Power Systems 537 May 07, 2004 09:56 AM
One hour CD ROM motor construction PART3 rysium Power Systems 511 Mar 22, 2004 01:03 PM
