This thread is privately moderated by SkylineFlyer, who may elect to delete unwanted replies.
Old Apr 06, 2011, 06:52 PM
TimJohnson is offline
Find More Posts by TimJohnson
Split S
TimJohnson's Avatar
United States, CA, Rancho Santa Margarita
Joined Jul 2006
I have video of them. When I can I will post.
TimJohnson is offline Find More Posts by TimJohnson
Old Apr 12, 2011, 07:51 PM
kmac is offline
Find More Posts by kmac
Abbotsford, BC, Canada
Joined Apr 2002
Changesun retracts V2
Hi guys,
I`m thinking of adding a set of these to a HL F4 Phantom. What is needed
other than the retract units themselves? I`m assuming instructions come in the packages. Is there any y harnesses needed? If so, Windrider has a
y harness with 3 leads that plug into the retracts, then the othet end goes into the receiver.
Thanks for your time,
Kerry
kmac is offline Find More Posts by kmac
Old Apr 20, 2011, 03:50 PM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Haven't seen these posted, but they look like they are just the Pingzheng PZ15090 and PZ15091 (I'm basing that on the Hobby Partz part numbers).
PZ15090:
http://www.hobbypartz.com/pz-15090-retract.html
PZ15091:
http://www.hobbypartz.com/77p-91-ere...-onepiece.html
Price is very close to HK on these.
SteveC68 is offline Find More Posts by SteveC68
Old Apr 20, 2011, 04:15 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
PZ15090:
PZ15091:
If the question are the HK PZs the same as the HPs PZs? Yes. HK had them first for less for a while, the started catching on and HP started suppling them.
PZ is pumping out the 15090 or 3mm dia strut 12mm trunnion width, the 15091 or 514 and now the 15094 which is a smallest of the three.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Apr 20, 2011, 09:48 PM
SteveC68 is offline
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
I ordered a set of the 15090s from HP. These will be going in an Exceed RC Mig-15 70mm from Nitroplanes. I also bought the ProDesign 25struts from x-flight for the same plane. I was planning on getting it all from HK but they are backordered along with the retracts. By the way HP has free shipping on orders over $25 right now. Do all of the parts required to do nose wheel steering come with the retracts other than the steering servo?
Old Apr 20, 2011, 10:02 PM
T-CAT is offline
Find More Posts by T-CAT
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
I thought it was a pull-pull nose steering system if I'm not mistaken. RC-Castle has the Mig15 retracts, as well as H1hobby.com http://www.h1hobby.com/electric-serv...ml?cPath=69_66
I believe they are both in stock as well.
T-CAT is offline Find More Posts by T-CAT
Old Apr 21, 2011, 02:57 PM
High Orbit.....
Joined Jun 2009
It is a pull pull setup hence the requirement for a steering servo. I'm just asking if the retracts from HP have the capability to be used as a steerable nose landing gear?
As far as seen, the only dedicated nose etract that I've noticed is the one by eflite. Otherwise you just pick one etract and add the pull pull arm mounted to the 3mm strut rod to steer. This is even true for the 4mm and 5mm metal gear also.
I just did a set on the 514 or 15091 using a 5mm bolt and 3mm machine nuts instead of set screws to create the pull pull arms in the Skylite strut.
To bad you didn't order the ChangeSun V2 from Xflight with the struts. The metal trunnion on the CS makes them more durable in the 2.5kg class.
Old Apr 21, 2011, 06:04 PM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
I normally buy my retract harnesses from:
International:
http://www.windrider.com.hk/product.asp?id=166
http://rc-castle.com/shop/product_in...oducts_id=1445
In the US:
http://skyartec-usa.com/advanced_sea...+cable&x=0&y=0
Old Apr 27, 2011, 09:42 PM
ciscovet is offline
Find More Posts by ciscovet
Joined Jan 2009
Hey guys,
Just recieved my Retracts from HK (Servoless Retractable Landing Gear Left & Right (1pair))
STTE-02 as well as the nose gear STTE-03.
In any case one of the main gear retracts stopped working. The other two work fine.
Does anyone know where I could buy one in the US?
ciscovet is offline Find More Posts by ciscovet
Old May 06, 2011, 02:20 PM
tweeter1 is offline
Find More Posts by tweeter1
Joined Feb 2011
Do you think that 15094 can rotate 90 degree? like the bigger one in the photo?
tweeter1 is offline Find More Posts by tweeter1
Reply With Quote  (Disabled)
Old May 12, 2011, 10:36 PM
High Orbit.....
Joined Jun 2009
Originally Posted by tomme21 View Post
who in the usa has these for sale??
DSR electric retracts with Titian trailing link struts
If you are talking EPF DSRs try SonicElectric.com.
Or you can can add some in your next HK order.
Old May 13, 2011, 03:31 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Originally Posted by yakhakker View Post
Rob Orrock and he goes by the handle of rorrock,he is a good guy to deal with, good luck
Thanks!
Tomme21, send them an e-mail with exactly what you want. He'll send you a price with shipping. I ordered my metal sides from him and replaced all them on my F86, essentially making them "Titans."
Pricing was much cheaper than buying direct from EPF. EPF has "vendor protected" pricing on their website.
chalmrast is offline Find More Posts by chalmrast
Old May 13, 2011, 09:53 PM
SteveC68 is offline
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
I ordered the Pingzheng PZ15090 retracts from HobbyPartz. They seem to be working fine after many cycles. These will be going in an Exceed 70mm Mig-15. What size screw is used to hold the landing gear in place? 3mm?
Steve
Old May 19, 2011, 05:54 PM
Ken Lilja is offline
Find More Posts by Ken Lilja
I'm slow but I'm expensive
Ken Lilja's Avatar
United States, GA, Snellville
Joined Nov 2003
Pingxheng PZ15094
To these have or need a metal trunnion?
Ken
Ken Lilja is offline Find More Posts by Ken Lilja
Old May 20, 2011, 11:29 AM
Ken Lilja's Avatar
Joined Nov 2003
trunion
The trunion is the part that connects the strut to the retract body. The trunion is the part that rotates.
Ken
Originally Posted by RogueTitan View Post
Trunion? do you mean struts?
Data Comprehensive List of Batteries, Chargers, Motors, ESC, Gyros, etc. w/ Specifications write2dgray Batteries and Chargers 408 May 15, 2014 11:56 AM
Discussion PLEASE HELP- Wher to list Dumas Star 45 for sale on Long Island LCS Sailboats 1 Jul 02, 2010 07:04 AM
Data What pack should I get? An updated comprehensive list Vaffel Batteries and Chargers 20 Feb 10, 2010 06:30 AM
Comprehensive Gearbox List valkyrie83 Power Systems 0 Sep 02, 2004 01:09 PM
