| Thread Tools |
| This thread is privately moderated by SkylineFlyer, who may elect to delete unwanted replies. |
http://www.sonicelectric.com/Merchan...roduct_Count=8
These are the struts I am talking about, Max. Are we talking about the same thing here? Jag |
High Orbit.....
Joined Jun 2009
Your link goes to struts not retract. These struts are 4mm and are intended for the Full RCL metal retract. Depending on you weight its my guess that to drilling out an additional mm from the RCL PZ312s is not going to kill you if you do so accurately.
Make certain that you take the trunnion out of the retract to drill. The metal shavings will likely short the board if you don't remove them to drill. Go over to the Warbird section and look at the FMS Corsair, P47 or Mustang threads. They have been using them. On the other hand if I were you I'd order a set of the PZ514s (5mm retract for those struts) from Hobby King for $13 ea. spec'd to 7.5Kg or 16lbs. You may have to wait in line though. everyone is starting to realize that etract, plastic based at least is very over priced and now HK is getting tonnes of orders. |
David,
I have a full set of the change sun, imho in the stock plastic condition I would recomend to use the as rotating type. The reason is the plastic trunion grub screw that locks the strut inline strips out most of the time when used as inward folding messing up the wheel alignment every flight. As rotaters the fixtures and ball links keep the alignment accurate. The stock wire struts are 3mm, e-flight axles work nicely but need the screw replaced with grub screws not cap screws. I sent a note to X-flight on getting a set of metal trunions and jack links to update the plastic fantastic set I have. As far as E-flight retract updates there is Larry in Orlando Fl that machines the parts for e-flight retract owners. He makes fans also |
Rochester, New York
Joined Jan 2006
Strut/Gear Leg Photos
These photos may aid in this electric retract forum. When I get all
the photos posted, I'll make a list of all these struts with prices. Any additions you guys may have are welcomed.
Rochester, New York
Joined Jan 2006
Strut/Gear Leg Photos (Cont.)
It's best to split up the photos in two posts, so here is Part 2.
Question.....
Regarding the ChangeSun electrics.
Where can one get the parts necessary to make these rotating sets? HK had the retracts, but the parts to make 'em rotate do not come with the gear. And, of course, HK is backordered on those parts. Anybody else out there have these parts? Thannks much. |
United States, TX, Kerrville
Joined Oct 2003
HKD-514 Retract.
Here's one from Hobby King. I just ordered a pair for a VQ C.205. Will report on 'em later.
http://www.hobbyking.com/hobbyking/s...dProduct=14838 CR |
High Orbit.....
Joined Jun 2009
Look forward to adding your comments. Some who like the Eflites infer that because they are only $8 they are cheap and is getting by their QC because the stop sensors had been broken on some. However, other have had no issues. What weight class or model do you plan on testing them on? |
| Thread Tools | |
| Data Comprehensive List of Batteries, Chargers, Motors, ESC, Gyros, etc. w/ Specifications | write2dgray | Batteries and Chargers | 381 | Today 02:28 AM |
| Discussion PLEASE HELP- Wher to list Dumas Star 45 for sale on Long Island | LCS | Sailboats | 1 | Jul 02, 2010 07:04 AM |
| Data What pack should I get? An updated comprehensive list | Vaffel | Batteries and Chargers | 20 | Feb 10, 2010 06:30 AM |
| Comprehensive Gearbox List | valkyrie83 | Power Systems | 0 | Sep 02, 2004 01:09 PM |
