| Thread Tools |
| This thread is privately moderated by SkylineFlyer, who may elect to delete unwanted replies. |
High Orbit.....
Joined Jun 2009
Are they anything like the ones to be coming from smartmodel? They are converting theirs to electric. Kin says they are to be out shortly. http://www.rcgroups.com/forums/showthread.php?t=1244905
High Orbit.....
Joined Jun 2009
or http://www.rcskylite.com/categories/Struts/ |
High Orbit.....
Joined Jun 2009
Freewing Electric Retract
Freewing electric Retracts (See pitcure Sample below).
Weight per retract w/o strut: 40g (1.4oz) Height bottom of mount to top: 24mm (.95") Width of Retract: 18mm (0.71") Length: 67mm (2.64") Strut Mount Rod Dia: 4mm Mount Holes; Width:29mm (1.14") Length: 24mm (.95") Already available via RC-Castle or Hobby lobby. Opinions: These appear to be a unique retract different from RCLanders and Eflite. The design is like RCLanders in that the strut rod is mounted and locked in place via two grub screws thru the brass alloy trunnion axle. Also the motor, gear, electrics and overall size is the same. Freewing improved on the Trunnion design, a larger metal lock block and thinker heavier worm gear. The Freewing Trunnion (almost identical to the RCLander) has been improved on in that in the down and locked position there is a flat surface on the tip of the trunnion that rests on top of the metal lock block (which on the Freewing is made of thinker metal). On the RCLander the thin lock block was designed to push the sharp pointed trunnion tip and hold it; it was not designed to lock the trunnion in place other than by the worm gear. The Freewing I find is superior in that even if there is a failure the trunnion can not rotate because the metal block holds it in place and can not move since the worm gear hold the block in place. The Lander the Trunnion slipped off the tip of the thinner metal block. The Lander is distinguishable by it brass mount hole option to be used to mount the retract or by bolting the retract to a mount plate made of metal or plastic. These plates can be mounted either from the top or the bottom. The Freewing mounts and retract body are one piece and can only be mounted conventionally from the bottom. Based on observations of Eflite 15-25 with the 4mm strut rod (though the Eflite trunnion is of the similar design to the Freewing but is wider) and the fact that both Eflite and RCLanders rate there at 3.5kg or 7.5lbs, these being of similar construction will likely rate the same. It increase the load range heavier 5mm struts could be accommodated with a 1mm sleeve. The Trunnion axle is 6mm thus drilling it out to fit a 5mm rod may weaken the strength of the metal axle mount. Cheers.
High Orbit.....
Joined Jun 2009
Not sure what the hold up on Hobby Lobby's order for their EF2K v3. I pointed out to them that these RClander copies were 23mm tall but the mount area in the Euro Wing was onl 19mm. Not sure if they were reworking a shim or recutting the wings or just delayed which is often the case. Or RC Castle has the Euro Version. Its just the struts that are differently between them. |
High Orbit.....
Joined Jun 2009
I think they are better as rotating gear. Locking the strut with the grub screw in plastic is their weekness if the model is getting above 5 lbs. Otherwise if you go to the DSR thread some have added a metal sleeves to go over the end of the trunnion with couplers to hold it in place. The ChangeSuns have a lower profile which make them a good fit in thinner wing or low profile apps. |
High Orbit.....
Joined Jun 2009
These are a good mid range 4.7Kg or 10lb PZ 514 (RCLander) Etracts.
Don't let the $8.00 price tag fool you. These are the heavy version of the PZ 312s sold as RCLanders. Of similar design the worm gear and trunnion are heavier. Working voltage: 4.8~6V Angle limit: 90 degree when retracted Operating temp: -10~50C Dimensions: 73.5x44x28mm Weight: 54g Shaft size: 5mm Not suitable for a plane heavier than 4.7kg PZ 514 |
| Thread Tools | |
| Data Comprehensive List of Batteries, Chargers, Motors, ESC, Gyros, etc. w/ Specifications | write2dgray | Batteries and Chargers | 377 | May 19, 2013 01:50 PM |
| Discussion PLEASE HELP- Wher to list Dumas Star 45 for sale on Long Island | LCS | Sailboats | 1 | Jul 02, 2010 07:04 AM |
| Data What pack should I get? An updated comprehensive list | Vaffel | Batteries and Chargers | 20 | Feb 10, 2010 06:30 AM |
| Comprehensive Gearbox List | valkyrie83 | Power Systems | 0 | Sep 02, 2004 01:09 PM |
