This thread is privately moderated by SkylineFlyer, who may elect to delete unwanted replies.
Old Apr 29, 2013, 09:30 PM
superjon is offline
Find More Posts by superjon
superjon's Avatar
United States, PA, Shippensburg
Joined Feb 2011
You can reverse the two end wires on the potentiometer and also flip the power wires on the motor. I do this with servos so I don't have to use a reverser.
Its not really too hard if you can solder well.
superjon is offline Find More Posts by superjon
Old Apr 30, 2013, 04:56 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
There's no pot on the retracts, just two SMD push buttons that the bar pushes on at the limits.
You could cut the traces and green-wire them to achieve the same result (and reverse the motor of course).
Odysis is offline Find More Posts by Odysis
Old Apr 30, 2013, 05:08 AM
superjon is offline
superjon's Avatar
Joined Feb 2011
...understood.
Old May 16, 2013, 07:35 PM
hole digger is offline
Find More Posts by hole digger
hole digger
hole digger's Avatar
USA, CA, Los Angeles
Joined Aug 2002
Anybody have any experience of info on these?
http://highendrc.com/index_eproduct_...roducts_id=234
Pete
hole digger is offline Find More Posts by hole digger
Old May 21, 2013, 07:49 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Pete
I am pretty sure they are designed for the HET F-16, and could probably be adapted to any 1/12 ish F-16 or similar.
Jetnfast is offline Find More Posts by Jetnfast
Old Jun 02, 2013, 10:43 PM
jl449 is offline
Find More Posts by jl449
Salinas, CA
Joined Dec 2007
I bought the HK Turnigy retracts for 70mm F-16
My first set - all 3 units heated up after several cycles and stopped working. I returned them and just got my second set. 2 of the 3 stopped working. At first they worked pretty good. But just stopped working after the 4th cycle. I have my endpoint adj. to +/-150% . This time around the units didn't heat up just stopped working.
Are these units junk? Any recommendation on comparable unit? This will be going on the Blitzwork banana hobby F-16 70mm.
jl449 is offline Find More Posts by jl449
Old Jun 03, 2013, 08:38 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Check your BEC voltage at the servo plug in end with a digital voltage meter
Regards
erh7771 is offline Find More Posts by erh7771
Old Jun 03, 2013, 10:28 PM
jl449 is offline
Salinas, CA
Joined Dec 2007
Regards
Ok got the fluke and measured the voltage on the receiver (servo plug in) - 5.4volts. Esc is dynam 50amp with built in BEC 4 amp running a 4cell lipo.
Old Jun 03, 2013, 11:30 PM
erh7771 is offline
Joined Nov 2005
Hmmmm, the PZs had issues over a year ago with over amping but not lately....
Do you have another ESC?
tia
Old Jun 03, 2013, 11:51 PM
jl449 is offline
Salinas, CA
Joined Dec 2007
tia
Tried another esc and same thing. 2 of the 3 don't work. As a matter of fact when I connect all 3 on the 3 way connector - the one that does work stopped working. I connected directly to the receiver and now the one that worked is working. Are the units from HK are PZs?
James
Old Jun 04, 2013, 08:51 AM
erh7771 is offline
Joined Nov 2005
James
HK has multiple types, the one in the link are PZs with lander gear on them.
Did you use the 3 way connector on all of the ones that didn't work?
Make sure end points are at 100% (or +) both ways
tia
Old Jun 04, 2013, 04:21 PM
jl449 is offline
Salinas, CA
Joined Dec 2007
tia
Initially I used the 3 way connector and all three worked for a few times. After that only 1 of the 3 worked. I connected each one directly to the reciever and still only 1 of 3 works.
I tried endpoints at 100% and at 150% +/- - I'm going to just give up and order a new set from toysonic since they are located in the US. I hate wating 3 weeks for parts. I'll just eat the 52 bucks because I need the landing gear.
Dont know to go with PZs or Changesun. Any recommendations?
James
Old Jun 09, 2013, 09:24 PM
jl449 is offline
Salinas, CA
Joined Dec 2007
Well, I ordered some PZs from Toysonic and came in within a few day. Tested the 3 units.... they work GREAT! I had bad luck with HK. I'm going to eat the 48 bucks from HK retracts because I need the landing gear and wheels.
Thanks Tia for your help.
James
Old Jun 11, 2013, 07:25 PM
erh7771 is offline
Joined Nov 2005
James
lol...tia means thx in advance....I think one of my neices told me this
Also, you'll need the trunions and tracks later on for those "aggressive" touchdowns....
I've had that happen too many time
Old Jun 12, 2013, 12:24 AM
jl449 is offline
Salinas, CA
Joined Dec 2007
LMAO... I thought it was weird your name was Aunt... Tia in Spanish means aunt.
I'm going to order some pc board and motors from pw-rc to repair the other set of retracts. That will be my backups.
Thanks Aunt. LOL
Data Comprehensive List of Batteries, Chargers, Motors, ESC, Gyros, etc. w/ Specifications write2dgray Batteries and Chargers 408 May 15, 2014 11:56 AM
Discussion PLEASE HELP- Wher to list Dumas Star 45 for sale on Long Island LCS Sailboats 1 Jul 02, 2010 07:04 AM
Data What pack should I get? An updated comprehensive list Vaffel Batteries and Chargers 20 Feb 10, 2010 06:30 AM
Comprehensive Gearbox List valkyrie83 Power Systems 0 Sep 02, 2004 01:09 PM
