This thread is privately moderated by SkylineFlyer, who may elect to delete unwanted replies.
Old Sep 25, 2011, 04:41 AM
AJ5000 is offline
Find More Posts by AJ5000
Foamy Pilot
AJ5000's Avatar
United States, CA
Joined Jun 2011
A problem that I am having with my changesun retracts is that one retract (main) will extend and retract (one cycle), but if i try to do it back-to-back it wont move. The other main and nose will work fine. I have to toggle the switch 3 or 4 times before it will cycle again. I cant figure out why its doing that
AJ5000 is offline Find More Posts by AJ5000
Old Sep 25, 2011, 09:49 AM
bsoder is offline
Find More Posts by bsoder
bsoder's Avatar
Mesa, AZ
Joined Aug 2004
does it matter how long you want between cycles? If you wait 30 seconds between flipping the switch does it work every time?
bsoder is offline Find More Posts by bsoder
Old Sep 25, 2011, 10:43 AM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Transition issues as you describe is often related to the set tavel points of the gear switch. Increase your travel end points. You may even need to rebind, gear down, with the new fail safe travel settings.
Only other concern is they seem to be adjusting the transition points of a number of the various makes.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Sep 25, 2011, 11:46 AM
AJ5000 is offline
Foamy Pilot
AJ5000's Avatar
United States, CA
Joined Jun 2011
It doesnt matter how long I wait between cycles, it still does it. I have a DX5, so I dont think thats the problem. I do have long extensions, so I'm not sure if thats an issue.
Old Sep 25, 2011, 01:01 PM
High Orbit.....
Joined Jun 2009
Not sure what a DX5 has to do with it. This is applicable to setup for any TX. Did you set your travel end points to max?
The gear tansitions at a set usec or %. They don't transition at exactly the same usec generally set from the factory, so as reported, you need to find the transition point for all 3 and set your travel point accordingly.
Old Sep 25, 2011, 01:10 PM
AJ5000 is offline
Foamy Pilot
AJ5000's Avatar
United States, CA
Joined Jun 2011
Travel point in the retract itself? I thought your were suggesting travel point settings in the TX. The DX5 is not a computer radio.
Old Sep 25, 2011, 02:23 PM
High Orbit.....
Joined Jun 2009
Do they make analogue radios still. You may not have figured out the travel control but it would have to be a computer radio to be a 2.4.
But you may be stuck if you can adjust the travel range. Travel range in usecs is commonly 899-2200 usec. Most TXs set this via tavel in a % value. +/-100% is generally 1350 and 1650. The etracts transition around and at times beyond this. So most just set the travel to 150%.
The etract is triggered to retract at a certain % or usec and open at a different % or usec which is set at the factory and is not exact having measured several myself. If your TX can't properly reach past the trigger point, it doesn't transition properly. With one it may with several the pulse position varies with Volt/amps during transition.
Try a different TX if you have or try one retract at a time to isolate a wire issue or a retract set beyond your DX5 range.
Old Sep 26, 2011, 01:47 AM
FieldofDreamsFlyer is online now
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
These are also nice http://www.wingspanretracts.com/Retracts
FieldofDreamsFlyer is online now Find More Posts by FieldofDreamsFlyer
Old Sep 26, 2011, 01:58 AM
AJ5000 is offline
Foamy Pilot
AJ5000's Avatar
United States, CA
Joined Jun 2011
Where can I buy the struts similar to the ones that come with the changesuns? I want some backups.
Old Oct 15, 2011, 01:08 AM
GourmetSaint is offline
Find More Posts by GourmetSaint
Australia, ACT, Bonner
Joined Dec 2006
I need to add retracts to a large scale plane. The wing thickness at the mounting point is only 28mm thick so I am looking for a solution with a very low profile. The main wheels themselves retract into a wing-mounted nacelle so only need to "hide" the struts in the wing. Mechanism suggestions? Need to keep weight down. It's an EDF scale UAV - 3.3m span. 1:12 scale.
GourmetSaint is offline Find More Posts by GourmetSaint
Old Oct 23, 2011, 08:20 AM
dawhale is online now
Find More Posts by dawhale
USA, CA, Valencia
Joined Mar 2011
Anyone heard when HH will have 60-120 E-Flite 100 degree rotating retracts available? Sure would like to replace the junky mechanical retracts in my H-9 aircraft.
dawhale is online now Find More Posts by dawhale
Old Oct 31, 2011, 06:18 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Also, how in general are the eflites holding up? Nice to know before blowing $150 on 2 mains.
TTRotary is offline Find More Posts by TTRotary
Old Nov 07, 2011, 07:14 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Just got the changesun retracts in. I know how to remove a e-flite strut, but cant figure out how to remove the changesun strut!!!!!!!!!
capt soap is offline Find More Posts by capt soap
Old Nov 07, 2011, 10:49 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
Just found a c clip at the top of the strut.
Old Nov 08, 2011, 12:28 PM
mike2663 is online now
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
I've had the 25-46 tri gear in my A-10 for some time with no issues to date. I just installed the 25-46 100 degree rotating in my Skyraider and so far they holding up very well also. I did receive a bad one right out of the box which was replaced by the LHS. I'm really pleased with the quality and performance so far.
mike2663 is online now Find More Posts by mike2663
Data Comprehensive List of Batteries, Chargers, Motors, ESC, Gyros, etc. w/ Specifications write2dgray Batteries and Chargers 408 May 15, 2014 12:56 PM
Discussion PLEASE HELP- Wher to list Dumas Star 45 for sale on Long Island LCS Sailboats 1 Jul 02, 2010 08:04 AM
Data What pack should I get? An updated comprehensive list Vaffel Batteries and Chargers 20 Feb 10, 2010 07:30 AM
Comprehensive Gearbox List valkyrie83 Power Systems 0 Sep 02, 2004 02:09 PM
