Old Jun 22, 2003, 10:10 AM
L.I.A. is offline
Find More Posts by L.I.A.
L.I.A.'s Avatar
Long Island, NY
Joined Mar 2003
Building Tiger Moth. How to attach foward struts w/o using screws?
Search yielded little help. I know there has got to be a better way. Thanks!
L.I.A. is offline Find More Posts by L.I.A.
Old Jun 22, 2003, 10:28 AM
goofup is offline
Find More Posts by goofup
goofup's Avatar
Yukon, OK
Joined Apr 2002
Drill (1/8"??) holes all the way through the struts and fuselage. Glue some balsa dowels through the fuselage so that they that stick out a bit (1/4"???) on each side of the fuselage. The struts then slip over the dowels and small rubber bands slip over the dowel ends (crossing over the fuselage) to hold the struts in place (sorta like the dowel/rubber band method of holding wings on). To remove the wings, just pop the rubberbands off and slide the struts off the pegs.
I haven't done it, but this is what it looks like people have done from the pictures I've seen.
If I'm wrong, or there's a better way, maybe somebody will chime in here...
goofup is offline Find More Posts by goofup
Old Jun 22, 2003, 10:35 AM
Buzz is online now
Find More Posts by Buzz
Forever WTTM Pilot #7
Buzz's Avatar
Daytona Beach, Florida, United States
Joined Aug 2002
I used bamboo BBQ skewers from the grocery store. They are the right diameter and very light. I don't drill through the fuselage with mine... just stick them in firmly and CA them into place. You can also keep your cowling on the same way by using one skewer on each side and looping a rubber band under the cowl. Works great....and no more screws to worry about.
Buzz
Buzz is online now Find More Posts by Buzz
Old Jun 22, 2003, 11:21 AM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
There's a couple pictures of them on the second page of this TM thread
The camo 'moth is Don's and uses the skewers, the red and white is mine and has cf rods instead.
BC
Basketcase is offline Find More Posts by Basketcase
Old Jun 23, 2003, 01:13 PM
Morb is offline
Find More Posts by Morb
Smooth Air
Morb's Avatar
Kelowna, British Columbia, Canada
Joined Apr 2003
Buzz
Hey Buzz,
Can I see some closeup pictures of your BBQ skewer idea? That's the route I want to go through. Going to be using magnets on the cowl, so not to worried about that.
Geof.
Morb is offline Find More Posts by Morb
Old Jun 23, 2003, 03:55 PM
DEPENDS is offline
Find More Posts by DEPENDS
Idaho
Joined May 2002
I used short pieces of CF rod epoxied in place. Slide the struts onto the rods and use a small piece of silicone fuel line pushed over the rod to hold the struts in place.
JT
DEPENDS is offline Find More Posts by DEPENDS
Old Jun 23, 2003, 09:14 PM
L.I.A. is offline
L.I.A.'s Avatar
Long Island, NY
Joined Mar 2003
thanks for the ideas!
Those dopey screws........Are they serious?!?!
I used the bamboo skewer idea. Worked better than i expected.
Maiden was great.
Old Jun 24, 2003, 12:24 AM
daveWCO is offline
Find More Posts by daveWCO
Silent Flight
daveWCO's Avatar
Tucson, AZ USA
Joined Oct 2002
I used toothpicks.
daveWCO
daveWCO is offline Find More Posts by daveWCO
Old Jun 24, 2003, 12:53 AM
Trikster is offline
Find More Posts by Trikster
Zoom, zoom...
Trikster's Avatar
Roseville, CA (Sacramento area)
Joined May 2003
Used the skewers also, much better than the screws. For the cowl, I used velcro. Helps keep the cowl in one piece if I mess up a landing.
Trikster is offline Find More Posts by Trikster
Old Jun 25, 2003, 07:38 AM
L.I.A. is offline
L.I.A.'s Avatar
Long Island, NY
Joined Mar 2003
so far i have only done a few "mods."
skewer mounts for the foward struts, velcro cowl, and glued the wing joints.
am i missing anything by not using the flying wires?
seems fine w/o 'em.
Old Jun 25, 2003, 09:20 AM
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
You'll know when it's time for wires when you see the wings fold during a loop. Even though the wings start out fine the foam must get fatigued after a while and eventually gives up. The wires seem to take some of the stress off of the foam.
Tiger Moth---how Much Wind???? claybuster Beginner Training Area (Aircraft-Electric) 7 Aug 18, 2005 01:43 AM
Rave Building the tiger moth 400. Got a ? JustFly Parkflyers 4 Mar 21, 2005 08:45 PM
Building Tiger Moth Wing Tor Parkflyers 11 Aug 16, 2002 12:13 AM
M100 in Tiger moth / How to mount?? harvey Parkflyers 0 Oct 02, 2001 04:58 PM
GWS Tiger Moth - How slow does it fly? mrebman Parkflyers 2 Jun 29, 2001 12:27 AM
