Old Jul 14, 2010, 11:45 PM
The Don is offline
Find More Posts by The Don
MA Indoor FreeFlight Columnist
Willoughby, Ohio
Joined Jan 2002
Build Log
Wicked Powered Great Planes Evader EDF
My Great Planes Evader kit arrived today so I am starting my build thread.
Don
The Don is offline Find More Posts by The Don
Old Jul 15, 2010, 12:04 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
First of all some observations and comments. The Wicked 60mm fan will fit inside with ease. I personally think the Wicked 4400 Plus and the Wicked 60mm 5 blade fan will be the best setup for this model. However, a few things need to be noted. The outlet cone is too small for a 60mm fan unit. It measures at a 75% FSA which is a little small for me but may be OK with 650-700 watts on this airframe. Because of the cheater inlet on the bottom, there will need to be some sort of fairing for the 60mm fan unit to get smooth airflow into it. Because of these issues for this build I will use the stock fan unit so all the parts in the kit can be used. I feel that if you are forking out $179.99 for the plane you should not be required to buy a new fan unit and do heavy mods to get more speed out of her.
I tested the wicked 4400 Plus in the stock fan and on 4S I get ~660 watts and 54,300 rpm which settled to 53,200 rpm and ~620 watts. According to the manual in the kit, the stock 4S setup produces 48,000 rpm at about 480 watts. So the extra 5k rpm should be a nice speed and thrust boost. The stock tailpipe is 85% FSA.
I also tried some various lipos in the cockpit and 4S2200 30C pack fit in just fine. Even some bigger ones do as well :-)
Don
Old Jul 15, 2010, 12:45 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Installing the motor into the fan unit was not difficult. I took a few photos showing it. The real issue came with the spinner. With no spinner the fan runs quite well and pretty smooth. So I added the spinner and tried to balance it. After 45 minutes I realized there was no way it will balance too much out of round so I hooked up a 2S lipo and ran the motor fan unit at partial throttle and used a grinding stone and pressed it against the spinner while turning to try to smooth it out./ You can see by the photos how out of round the spinner is. I kept on going until it I would get full marks around the whole OD. So then I used some 320 grit paper and smoothed it some then 600 grit to get it even smoother. i then ran it up and was much smoother on a 2S lio. So I went to the 4S lipo again and at half throttle the fan vibrated bad. So I worked some more to balance, and I got it to run silky smooth up to 50% throttle then suddenly it would always go way out of balance. I finally gave up after about 45 more minutes of messing around. So I balanced it with no spinner on. I then test fit the parts for the outlet and inlet and it fit just fine.
As far as the spinner, I think the trouble is the screw is way down low and the rest of the spinner is unsupported and can flex at higher rpm. So for the heck of it I mixed up some epoxy and filled the spinner with it. I am letting it cure over night and I will see if it can be balanced now as the spinner will be acting as one unit. Worth a test anyhow.
Don
Old Jul 15, 2010, 09:24 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Well the epoxy spinner idea worked. I was able to get it balanced in about 15 minutes. This is still a touchy setup, small changes make a huge difference but it runs nice now! By the way did a new Eagletree test and I gained 1000 rpm being balanced :-)
Don
Old Jul 16, 2010, 01:56 PM
mbigby is offline
Find More Posts by mbigby
San Jose, CA
Joined Mar 2007
Wow, great mods...
Wow this is fascinating - I have had a hell of a time getting the hyperflow fans to behave well at higher power levels. I'm going to definitely try this.
I have a few questions:
1. How did you get such a uniform convex surface to the epoxy? Does it do that on its own with surface tension?
2. It seems like epoxy with micro balloons would be good here too. My thinking is that less rotating mass = better. Any thoughts?
Thanks...
mbigby is offline Find More Posts by mbigby
Last edited by mbigby; Jul 16, 2010 at 01:56 PM. Reason: answer to one question was in the thread...
Old Jul 16, 2010, 04:41 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Thanks...
1) If you use finishing epoxy it is much thinner and watery so it settles on its own like that. I was pleased with the result.
2) I was afraid adding microballons would make it harder for the trapped air from mixing to get out when curing and maybe not bond as well to the spinner. Not sure really, it was a shot in the dark but it worked!
Old Jul 18, 2010, 12:11 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
IMO adding Micro balloons would make it more brittle,I think its better to be a little flexable.Watching this one Don.... Joe
fh64_lucky is offline Find More Posts by fh64_lucky
Old Jul 19, 2010, 07:51 AM
kremecheze is offline
Find More Posts by kremecheze
kremecheze's Avatar
United States, NY, Queens County
Joined Jun 2007
Nice build,i really wanted to see one with the wicked 60mm fan,i really hate the hyperflow units
kremecheze is offline Find More Posts by kremecheze
Old Jul 19, 2010, 12:12 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
it will be nice to hear what a hyperflow sounds like that accualy runs smooth....
corsair nut is offline Find More Posts by corsair nut
Old Jul 19, 2010, 12:28 PM
Bajora is offline
Find More Posts by Bajora
KA6KHM
Bajora's Avatar
Joined Sep 2004
My Hyperflow runs smooth, with the spinner removed. First time I have had one sound as good as it does. FWIW, I think the composite airframe of the Evader lends itself to the Hyperflow running quieter? I also have a Hyperflow installed in the new foamy F20, sans spinner, and it is quite a bit louder? Granted that a key variable between the two is also whether each fan is balanced or not. My buddy Don also has an Evader and without the spinner, his also sounds pretty smooth and quiet. Nice approach to balancing the spinner Don. Way to go!
Watching to see how your Evader does Don. I always enjoy your threads and your approach to squeezing more performance out of a model.
Bajora is offline Find More Posts by Bajora
Old Jul 20, 2010, 10:19 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
I know what you mean. I may still do a swap after I fly this way first.
Don
Old Jul 20, 2010, 10:20 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Mine ran well with no spinner also. I am contemplating designing an aluminum aftermarket spinner for this fan unit. I am going to see how it perfroms first though.
Don
Old Jul 21, 2010, 07:49 PM
mbigby is offline
San Jose, CA
Joined Mar 2007
How to balance the spinner...
Ok, I'm sorry for all the simple questions here, but my epoxy filler has dried. I've done the motor-as-a-lathe smooth-up of the exterior. Now, I am wondering how you balanced the spinner?
My magnetic balancer is 1/8"+ and too big for the hole. I was thinking of using 3mm drill bit (or something smaller that fits the hole closely). Is that what you did? Alternatively I can ream out the hole (yikes). Or did you just go straight to the dynamic balancer and then drill out the spinner instead of adding weight?
- balance-curious...
Old Jul 22, 2010, 05:55 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
I never balance statically. It has never worked for me. The only correlation I have found with static to dynamic is that there is no correlation :-) Go straight to dynamic balancing. Keep the spinner in one location and add about a 1/8" diameter ball of ballast to start with and move it and 1/8 of a turn until you home in on the correct location. Also pay attention to how tight you secure the screw, it will have an effect as well.
Don
Discussion Great Planes Evader realdeal Electric Ducted Fan Jet Talk 1244 Aug 10, 2015 05:06 AM
Sold Great Planes Evader RichR12 Aircraft - Electric - Airplanes (FS/W) 2 Jun 16, 2010 12:44 PM
