Old Aug 27, 2012, 05:20 AM
xlcrlee is offline
Find More Posts by xlcrlee
Joined Apr 2006
I am not sure what you describe .... but everything is clearly shown on the box photos!
And everything has a small bolt or screw holding it in a proper place: these screws/bolts can become loose or unscrewed/unbolted. If they are untightenable with worn-out threads .... tighten with CA gel ...
Lee
xlcrlee is offline Find More Posts by xlcrlee
Old Aug 27, 2012, 10:42 AM
fred2048 is offline
Find More Posts by fred2048
Joined Jul 2009
Hi is there a place to get all the screws and allens for a cx2.trying to put all the exra parts together got all to build another but the screws and hex heads?
fred2048 is offline Find More Posts by fred2048
Old Aug 27, 2012, 11:57 AM
fred2048 is offline
Joined Jul 2009
Sorry wrong forum
Old Aug 28, 2012, 04:20 AM
xlcrlee is offline
Joined Apr 2006
Originally Posted by fred2048 View Post
Sorry wrong forum
Correct forum, just wrong thread ....
Old Sep 15, 2012, 08:19 AM
xlcrlee is offline
Joined Apr 2006
Has everyone broken theirs? [all of my 5888's still fly SUPER!! .... far beyond the capabilities of anything similar on the market!]
Lee
Old Sep 17, 2012, 08:22 AM
diegogonz76 is offline
Find More Posts by diegogonz76
Joined Jul 2012
Hi Lee, I have a lot of work to do these days and I don't have any time to finish the mods on my heli. I got a pair of motors a set of gears and some blades. I am still waiting for the inner shaft and the old blades with the screws and the bushings. I wll try to heat the plastic hinges or replace them with the alu ones if I get the parts before I have free time. I will let you know how it goes. Regarding the motors I have one with black plastic and the other with withe. But the white one is not as white as the wire. I don't know if this is the grey plastic you said wasn't as good as the white ones.
diegogonz76 is offline Find More Posts by diegogonz76
Old Sep 17, 2012, 10:27 AM
xlcrlee is offline
Joined Apr 2006
I have to take that back: further experience indicates that it seems to vary with the production date!
Happy [upright] Landings!,
Lee
Old Sep 17, 2012, 12:16 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Lee
My red one is still flying, my blue one is down, but that's the one with the better servo (larger range of movement); time permitting I will do a board transplant.
stonecutter is offline Find More Posts by stonecutter
Old Sep 18, 2012, 10:27 AM
xlcrlee is offline
Joined Apr 2006
Note that the servo range is determined here by the PCB .... not the servo! Only when a servo's motor wears out and slows does it make sense to swap it. Since it's tricky to solder the left-servo wires, I always first secure the PCB-ends of the servo wires with a glob of CA gel, and once cured, clip the wires and solder the new servo wires to them, sometimes shortening the latter first.
Lee
Old Sep 29, 2012, 02:07 PM
Joined Jul 2012
I received all the parts! I hope I have some time to work on the heli soon. One question. I accelerated the heli without the blades. Only the bar. And it vibrates a lot. Is there anything I can do to cancel this vibration before assembling the blades? The arms of the bar in my heli are metalic. Only the center part with the ball links is plastic. I have a replacement bar, I will try with that one and let you know how it works.
Old Oct 01, 2012, 07:29 AM
xlcrlee is offline
Joined Apr 2006
Yep > remove the bar and carefully balance it!
[use a small pin to push out the pivot pin]
Lee
Old Oct 02, 2012, 09:07 AM
Joined Jul 2012
Hi Lee. I replaced the lower gear and vibrations were reduced a lot. The balance bar is slightly bent. So I will have to work on it. But the heli is flying again! It still has some problems but I think I can solve them. The inner shaft I bought that belongs to the model with alu hinges is shorter than the one I had. So I had to sand the plastic middle part of the upper hinges to fit in the old inner shaft. The tracking needs a lot of work, almost 2 mm difference between the blade tips. The heli is turning clockwise even with trimming at full. Can it be the tracking causing this? If there is someone out there with a 5888 with plastic hinges, I think applying heat and tracking will be easier than trying to change to alu hinges. It has been a lot of work and I don't know if I will be able to make it fly perfect yet. I have to tell you that in my case trying to make this heli fly perfectly is perhaps more fun than flying itself! But that's just me.
Old Oct 02, 2012, 09:27 AM
xlcrlee is offline
Joined Apr 2006
Optimal tracking is to within the thickness of clear plastic office/household tape!
2mm is outrageously bad ....!!!!
The original plastic flybars are easily corrected with the heat of a hairdrier [bend them slightly up so that they don't droop from gravity].
Unfortunately, the newer metal flybars are terrible and quickly wear out the hinge parts because the stiff metal wire doesn't damp normal vibration!
Lee
Old Oct 02, 2012, 11:17 AM
Joined Jul 2012
I know the tracking is really bad. I just didn't know if that was a possible reason for the clockwise turning or if I have another problem I don't know about yet. I will improve the tracking and let you know how it goes.
Old Oct 03, 2012, 10:37 AM
xlcrlee is offline
Joined Apr 2006
Good/ Good Luck!
when the leading edges of the spinning blades appear RAZOR-sharp, viewed edge on, and the trailing edges appear as ONE clear line ... you will hear a jump in RPM and notice a great improvement in power, maneuverabilty, stability and general performance ....!
Lee
Discussion 4 CH Catalina Radio Remote Control Electric Twin Power RC Sea Plane butrflyblade Batteries and Chargers 4 Dec 27, 2009 03:49 PM
Discussion Opinions on Banana Hobby 4 CH Easy Fly 3D Aerobatic Radio Remote Control Electric RC 7rider Beginner Training Area (Aircraft-Electric) 14 Jun 01, 2009 10:46 AM
Discussion 2009 4 CH F-16 Fighter Jet 3D Remote Control Electric Ducted Fan RC RTF w/ 70mm EDF! rcheli146 Foamy EDFs 2 May 16, 2009 10:23 PM
