Old Dec 27, 2010, 04:03 PM
mojo57 is offline
Find More Posts by mojo57
Joined Dec 2010
Anyone know of a source for the landing gear? Broke ours on both of copters. Also, have one that has the main blade grip that the screw appears to be stripped. It will fall out anytime the blade touches something. Anyone experience this?
mojo57 is offline Find More Posts by mojo57
Old Dec 27, 2010, 04:17 PM
SC10 is offline
Find More Posts by SC10
Joined Dec 2010
more pixs
Bought the 5888 last week from local toy shop.
Here are some pictures of the insides of the 5888.
Description: Canopy LED soldered to top left edge of board, tail lights supplied by thin enamelled wire (behind frame) by same two pads, hidden by thicker plastic insulated wires. Name: RightSide.jpg
Description:
Receiver board:
Description: Battery is 180 mAH, soldered to clearly labelled pads (B+ and B-). Name: ReceiverBack.jpg
Description: PCB dated 2010-7-16 labelled QS-MR900 V16
Transmitter board:
Description: Main PCB dated 2010-7-16 labelled T424 V16
RF module dated 2010/5/18 with built-in antenna (short trace at top) Name: TransmitterBack.jpg
Description:
Some alternatives for lost parts:
Lost the screws for the top blades after first few crashes, replaced with #14 copper wire, they now stay in place after crashes better than the screws.
Description: Screws replaced with short lengths of #14 copper wire, bent 90 degrees.
Also replaced lost sleeve bearing inside blades with 2-3 turns of #24 copper wire formed around the larger #14 wire.
Vibration is not noticeably worse than brand new, out-of-the-box.
Can hover hands-off in place for a 2-3 seconds after trimming.
Flies for about 5 minutes on a 20-25 min. charge by AC adapter, LiPo cell is cool to touch at end of charge.
Motors remain cool to touch after first minute and at end of 5 min. flight.
Transmitter charge circuit seems defective, has anyone tried it? Would be nice to have when away from home, if it can be made to work.
SC10 is offline Find More Posts by SC10
Old Dec 27, 2010, 10:02 PM
Kurpal is offline
Find More Posts by Kurpal
Joined Nov 2006
Tagging for later.
Kurpal is offline Find More Posts by Kurpal
Old Dec 28, 2010, 09:00 AM
bowman11 is offline
Find More Posts by bowman11
Joined Dec 2010
Bought the 5888 for my boy for Christmas, great success, but now he has broken the on/off switch on the bottom of the helo.(The moving part has fallen out). Any suggestions on how to repair would be gratefully received.
bowman11 is offline Find More Posts by bowman11
Old Dec 28, 2010, 09:04 AM
scotsoft is offline
Find More Posts by scotsoft
Master Of My Universe
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
This might sound crazy but if the moving part of the switch "fell" out then you should be able to get it back in.
You may need a magnifying glass to do it but it should work.
scotsoft is offline Find More Posts by scotsoft
Old Dec 28, 2010, 09:21 AM
bowman11 is offline
Joined Dec 2010
I would need a magnifying glass to find the missing piece, long before I tried to reinstall it!
Old Dec 28, 2010, 12:18 PM
gbjbasdw is offline
Find More Posts by gbjbasdw
Joined Dec 2010
Thanks for the photos, SC10. Really useful to have some idea of where the components are located and how to get to them.
gbjbasdw is offline Find More Posts by gbjbasdw
Old Dec 28, 2010, 12:20 PM
gbjbasdw is offline
Joined Dec 2010
Forgot to ask SC10...
Where are you based and what toy store did you get your heli from ?
Steve
Old Dec 29, 2010, 08:37 AM
xlcrlee is offline
Find More Posts by xlcrlee
Joined Apr 2006
Source: my supplier lives just outside Zürich/CH >
Marcel Hauser <marcelhauser@bluewin.ch>
Stripped hub blade-holder bolt-holes: remove blade (CAREFUL not to lose tiny essential brass bushing in blade!), put tiny amount ot CA gel in stripped hole, let slightly harden, reassemble, don't fully tighten screw. When CA is cured, then tighten for correct blade looseness!, and build up small fillet of CA gel around penetrated bolt end. Will last until hard crash .... just as original alu! Then simply re-do! Safety design feature (else many unfixable parts, incl. PCB-burnout!!).
I like to fly wildly around the room, making fast tightly-banked figure-8's, fast banked circles in reverse. and almost approach 3-D flt > in well over 10 hours of flt times with my several 5888's have I never broken a blade or had anything other than a bump-"crash", and never crash-broken a part. That is because I was careful as I developed my flt skills with these. I only mention this to indicate that it is possible not to crash these!
Happy non-crash Landings!
Lee
xlcrlee is offline Find More Posts by xlcrlee
Old Dec 30, 2010, 06:53 AM
xlcrlee is offline
Joined Apr 2006
re: the rest of your post,SC10 > Cool!
Other users, pls note that screws popping out is a very important safety feature, esp. to preserve PCB.
See my above post re: how to use CA gel to repair permanently stripped alu threads.
Also, mine will rermain in hover almost indefinitely once painstakingly trimmed & tuned
(even with mild hot-water heat radiator air circulation [no fans]).
Lee
Old Dec 30, 2010, 08:09 AM
bulesz is offline
Find More Posts by bulesz
bulesz's Avatar
Hungary EU
Joined May 2007
I have just found the origin of this heli:
http://www.gt-model.cn/Eng/Product_Show.asp?id=173
This is the G.T. Model factory website.
bulesz is offline Find More Posts by bulesz
Old Dec 30, 2010, 08:10 AM
bulesz is offline
bulesz's Avatar
Hungary EU
Joined May 2007
To tell you the truth I am still sceptical about its quality...
Old Dec 30, 2010, 08:44 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
You should be. Lots of stamped aluminum body parts and LEDs are a big red flag. They are selling bling, not quality.
Balr14 is offline Find More Posts by Balr14
Old Dec 30, 2010, 08:55 AM
xlcrlee is offline
Joined Apr 2006
It is extremely well engineered. There have been some typical early prdn, QC and assembly problems, which the factory has told me they are working on to make this puppy perfect out-of-the-box. As it is, with some effort, it becomes a SUPER performer. If you want a higher guarantee of instant results (some 5888's I've bought were factory-PERFECT! ..... and I am a hard judge), requiring no expert work on your part at this point in time, you can buy a better-known brand for MANY times the price, and get slightly inferior performance to the 5888 when expertly tuned. With that noted, it is absolutely the BEST-performing (and I think it looks like a scaled-down larger R/C heli) low-cost tiny 4-ch coax on the market. Period.
"You get nothing for nothing", it's been often said .... [caveat emptor]
Lee
Old Dec 30, 2010, 09:10 AM
bulesz is offline
bulesz's Avatar
Hungary EU
Joined May 2007
Yes you are right...but I'm still in patience and if you dont mind waiting for the others experiences too!
Discussion 4 CH Catalina Radio Remote Control Electric Twin Power RC Sea Plane butrflyblade Batteries and Chargers 4 Dec 27, 2009 02:49 PM
Discussion Opinions on Banana Hobby 4 CH Easy Fly 3D Aerobatic Radio Remote Control Electric RC 7rider Beginner Training Area (Aircraft-Electric) 14 Jun 01, 2009 09:46 AM
Discussion 2009 4 CH F-16 Fighter Jet 3D Remote Control Electric Ducted Fan RC RTF w/ 70mm EDF! rcheli146 Foamy EDFs 2 May 16, 2009 09:23 PM
