Old Nov 07, 2012, 06:28 AM
jsxx is offline
Find More Posts by jsxx
jsxx's Avatar
Wielka Brytania, Anglia, Derbyshire
Joined Jan 2011
HI. want to buy fmkit bit im not sury what im buying and how it works...
FMkit - how the current verions looks and works ? can i still gey the one with microfone that its activated when there is no sound from moving air.propeller ?
how long it works,how to set it up is there any manual ? whats the range ?
If you dont want to loose customers you need to work on your webpage and propper manual...
jsxx is offline Find More Posts by jsxx
Old Nov 07, 2012, 06:32 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
He lives in ISRAEL give him a break! I hear they have missles being shot at them
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Nov 07, 2012, 07:43 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
+1
Extremely sad but true...
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Nov 08, 2012, 02:44 AM
Sitas is offline
Find More Posts by Sitas
Joined Jul 2011
FMkit can you ship this beacon with track number?
Sitas is offline Find More Posts by Sitas
Old Nov 08, 2012, 02:56 AM
fmkit is offline
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
all beacons shipped w/ tracking number (registered airmail),
new boards expected by Monday, there is mini-USB as well servo 3-pin connector to charge Li-Po cell, PWM reading is easy to implement but it will cost less presets or minus microphone mode - the chip ROM all used up.
fmkit is offline Find More Posts by fmkit
Old Nov 08, 2012, 03:14 AM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
I can live with less presets. You can always manually enter the frequency, right?
I would like it to monitor PWM so that it can trigger the beacon timer when RTH is selected. I want it to be adjustable to different PWM ranges, so it can share the channel with the RTH switch, and only trigger in the RTH switch position. This might be a 3 position switch, or it might be throttle under or over 100%. I think if you make it selectable to trigger at either +110% or -110%, it could be made to work with any OSD's using endpoint adjustments.
Once triggered, it should start the timer so it doesn't activate while likely to be airborne.
Is this feasible?
iskess is offline Find More Posts by iskess
Old Nov 12, 2012, 12:50 AM
Duschman is offline
Find More Posts by Duschman
Joined Mar 2012
Peter, when will send the promised beacon?
(Отправлено 05 Октябрь 2012 - 21:01
Вышлю замену в ближайшие дни, у нас тут серия празднков включая Новый Год.
Недавно убедился что новые мощные ЛЕДы (15,000мцд) действительно могут перегрузить драйвер, на моем самолете тоже перестал светится. Хорошо что на работу маяка это не влияет - можно настраивать режимы и пользоватся без ЛЕДа.)
Duschman is offline Find More Posts by Duschman
Old Nov 12, 2012, 11:14 AM
CheckSum is offline
Find More Posts by CheckSum
CheckSum's Avatar
Joined Jan 2011
fmkit-
I have an older beacon and wanted to make sure I have the jumper shown correctly in the photo. I took it off sometime ago, so I want to make sure I am putting it back together right. Also, the jumper delay is 45min???
-Thanks
**EDIT**
Also, do you have any new boards with USB available? If so, can you please post some photos and specs?
-Thanks again
CheckSum is offline Find More Posts by CheckSum
Old Nov 13, 2012, 03:40 AM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Duschman, check PM
CheckSum, I don't remember anything about jumper, these old beacons tuned using 2X16 LCD
anyway, if do install jumper the circuit will survive so just try.
I'm testing new beacons with USB and servo pins charger/PWM controlled
it works just need to add indication of charging, will updae in a day or two
here is a picture, other side of PCB is flat, one can heat-shrink Li-Po cell and beacon together
Old Nov 13, 2012, 01:08 PM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
Duschman, check PM
Peter, could you make a remote daughter board with the button and LEDs on it so I can bury the Beacon deep in the plane and have the button on the surface? I would like the LEDs on the outside of the fuselage so it lights up the night during a search. It would be very convenient to have the button on the surface too.
What do you think?
Old Nov 13, 2012, 01:27 PM
jsxx is offline
jsxx's Avatar
Joined Jan 2011
Duschman, check PM
when its going to be available ?
ps.
what king of handheld radio is good to use with that beacon ?
Old Nov 14, 2012, 02:00 PM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
ps.
The cheapo walkie talkie with the fewest channels usually work the best because their antennas are more tuned to a smaller spectrum. I started out with a police scanner with lots of channel thinking it would be better, but it was terrible. Then I got a set of Motorolas on Ebay for $15 for 2, and they work much better.
Old Nov 16, 2012, 10:12 PM
Duschman is offline
Joined Mar 2012
Peter, you got my PM​​?
Old Nov 19, 2012, 08:43 AM
martyester is offline
Find More Posts by martyester
Joined Jun 2012
Peter, If I place an order for a beacon, will I get the one with the USB charger? I would prefer that one with VOX capability.
martyester is offline Find More Posts by martyester
Old Nov 19, 2012, 08:46 AM
Joined Mar 2012
With all the missles falling over there I am suprised he is still makeing these!
Discussion Airtronics RF radio module question on pins. TexasThermalKing Radios 3 Apr 30, 2010 04:27 PM
Question "Plug and play" locater beacon? Freakazoid FPV Talk 17 Mar 18, 2010 09:42 PM
Discussion question concerning shielding of rf signal in dlg pods soarluck Hand Launch 16 Jan 28, 2010 02:59 PM
Discussion Silly question, can wind affect RF video signals galaxiex FPV Talk 3 Oct 11, 2009 10:40 AM
Discussion Lost plane sound beacon question. TIMN Electric Sailplanes 3 Aug 06, 2007 01:36 PM
