Old Jul 18, 2012, 12:13 PM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Originally Posted by KillerCut View Post
we talked about that before. Its more trouble than its worth... the beacon works very well already, adding gps would make it bigger, shorter battery life, etc, etc....
I think that discussion was regarding using a data transmission, but what about simple morse code? Maybe it would only send out the morse code GPS position once per minute, or every 10 minutes. It would still send out the normal 3 beacon tones ever 4 secs, or however set. If you don't know morse code, you could record it and play it back slowly to decode it. There are online apps to translate as well. To make the morse code shorter, just the last digits (minutes and seconds) would be transmitted.
My DOSD has a GPS pass through so I wouldn't need to buy another GPS unit, they would share.
Peter, does this idea have any merit?
iskess is offline Find More Posts by iskess
Old Jul 18, 2012, 12:41 PM
fmkit is offline
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Originally Posted by kempo View Post
Hi Peter, i've just made a paypal payment for a no vox RF beacon(i specified that i will use binatone walkie talkies).
Can you please check your Paypal ?
Are you selling also 1s battery for the beacon ?
Thank you.
thanks ! will ship tomorrow
1s 300mAh included
the ebay radio you linked sure will work
fmkit is offline Find More Posts by fmkit
Old Jul 18, 2012, 12:42 PM
kempo is offline
Find More Posts by kempo
kempo's Avatar
United States, CO, Denver
Joined Nov 2008
1s 300mAh included
Thank you.
kempo is offline Find More Posts by kempo
Old Jul 22, 2012, 03:20 AM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
sure,
btw I have pair of exact same looking radios, Motorola with Uniden PCB inside
ebay has many radios w/ Li-Ion batteries and SMA
My saved search
I got my Motorola Walkabouts today, wow they are tiny!
How do I mod it to add an sma connector? The antenna is a single coiled wire. Where does the ground wire of the sma connector get soldered to?
Description: Name: ImageUploadedByTapatalk1342945096.395936.jpg
Description:
Old Jul 22, 2012, 07:38 AM
texasdrifters is online now
Find More Posts by texasdrifters
Joined Apr 2011
Attachment 5027437Attachment 5027438
An excellent question! I also am using these radios. If I can use a directional antenna to locate the beacon, that would be great!
Hector
texasdrifters is online now Find More Posts by texasdrifters
Old Jul 22, 2012, 08:16 AM
KillerCut is offline
Find More Posts by KillerCut
USA, NY, Brooklyn
Joined Jan 2002
They use 1 wire because the antenna is Supposed to be a lot longer than they can actually use (or that anyone would want to carry). Hence, they dont need to ground any part of the antenna. If you want to, you can just solder your active pin for the sma connector and secure the sma connector with epoxy or something. The
KillerCut is offline Find More Posts by KillerCut
Old Jul 22, 2012, 12:28 PM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
Your message got cut off, please complete. Are you saying that the sma ground doesn't need to be attached to any part of the circuitry? It seems like it wouldn't make a very good directional antenna this way.
Old Jul 22, 2012, 07:01 PM
slowjett is offline
Find More Posts by slowjett
-NEFPV-
United States, MA, Sturbridge
Joined Jun 2008
Just ground it to any ground on the unit near the signal wire. All the grounds should be common.
slowjett is offline Find More Posts by slowjett
Old Jul 22, 2012, 10:40 PM
USA, NY, Brooklyn
Joined Jan 2002
ohh if you will use a directional antenna then by all means ground it. There are a lot of ground points on the circuit boards... I thought you would use the stock rubber duckie or something similar...
Old Jul 23, 2012, 03:01 AM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
I'm not sure that the antenna ground is the same as the other grounds.
I remember Alex (IBCrazy) was recommending creating a dipole for a 72mhz RX by sending the RX antenna down one wing, and the a ground down the other wing. I asked him if I could just use a black servo wire for the antenna ground wire, and he said its not the same. I would have to find the antenna ground pin on one of the chips and harvest it from there. I didn't know how to find this, so abandoned the project. I find myself in a nearly identical predicament now.
Old Jul 23, 2012, 06:21 AM
USA, NY, Brooklyn
Joined Jan 2002
Thats because you would have a large piece of the active element exposed, and if you use servo wire as ground, your active element will still be exposed, you must use antenna cable.
Old Jul 23, 2012, 11:04 AM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
You misunderstand. The whole antenna was supposed to be exposed, as it always is with a 72 MHz RX. The plan was no different than a normal 72 MHz RX antenna attached to a wing, except there was to be an equal size ground antenna wire in the other wing. Just a giant dipole the size of the wingspan.
Anyway, back to the point, how does one find the antenna ground on the PCB.
Peter, chime in here oh master guru.
Old Jul 23, 2012, 12:26 PM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
I've read posts like some Australian guy pointed Yagi to beacon that was 7km away(he had to climb nearest mountain 1st) and such . After using the beacons for few years I'm sure no mods needed, compact walkie-talkie is all you need. In extreme situation place walkie-talkie onboard EZ* or SW and take it up 300m circle 2km radius - way more effective compared to pointing Yagi while at ground level.
I made digital long lasting beacon with LCD RX a year ago, turned out analog walkie-talkies atleast 20db better sensitivity, I had to put aside "advanced" system cause primitive 3 fading tones was practical and simple, keep your radios unmodified.Invest into video RX Yagi, they're smaller at GHz.and while searching at near range more useful than UHF beacon.
Old Jul 23, 2012, 02:17 PM
USA, NY, Brooklyn
Joined Jan 2002
ohh, I dont see a problem with that. Maybe Ibrazy didn't understand you. I think the only issue would be that you would probably need to keep the ground wire perfectly straight or something...
Old Jul 23, 2012, 05:37 PM
joel0407 is offline
Find More Posts by joel0407
joel0407's Avatar
Australia, NT, Lyons
Joined Oct 2010
Originally Posted by joel0407 View Post
This thing is awesome. I tested mine this weekend, just past. We put it a couple of feet of 30mm square, white conduit to partly look like a foam plane and then had a mates father hide it.
We out of town and he came back to tell us it was within 20km, good luck. He didn't have much faith in us or the beacon.
We went to the highest point and picked up 1 scratchy tone with a yagi antenna. We headed in the direction with the UHF radio on in the car (Trucker CB for those in the US). 1 tone turned to 2 and then 3. From this point we disconnected the antenna and kept going. We finally got down to about 10m and then we just searched around in the grass and found it. It took about 20 - 30 minutes in total.
GPS distance from the high point to the beacon was 6.64km.
I doubt I will loose a plane again.
Not quite 7 km but I was close and have no doubt it would make more than 7.
I'm going flying this morning but I can post pics of my Yagi and Radio when I get back.
Happy Days.
joel0407 is offline Find More Posts by joel0407
Discussion Airtronics RF radio module question on pins. TexasThermalKing Radios 3 Apr 30, 2010 04:27 PM
Question "Plug and play" locater beacon? Freakazoid FPV Talk 17 Mar 18, 2010 09:42 PM
Discussion question concerning shielding of rf signal in dlg pods soarluck Hand Launch 16 Jan 28, 2010 02:59 PM
Discussion Silly question, can wind affect RF video signals galaxiex FPV Talk 3 Oct 11, 2009 10:40 AM
Discussion Lost plane sound beacon question. TIMN Electric Sailplanes 3 Aug 06, 2007 01:36 PM
