Old Jun 21, 2003, 10:35 AM
SACS is offline
Find More Posts by SACS
Oklahoma
Joined May 2003
Foam Safe Glue
Does anyone know of a glue that is safe to use on EPS foam and still allowyou to hotwire it. I have CNC foam cutter and would like to be able to cut panels that are thicker then I can purchase foam in. As such I am looking for a way to join the sheets. I have been able to use hot glue, but this requires me to know where the wire will not cut on both sides. While this is not a major problem, it would be nice to be able to just 'blindly' join the sheets together as a whole and then cut them at a later date. I am going to trya few more idea and see how they work.
SACS is offline Find More Posts by SACS
Old Jun 21, 2003, 11:47 AM
Napolean B. is offline
Find More Posts by Napolean B.
Fairport, NY
Joined Jun 2003
Try ProBond.
Napolean B. is offline Find More Posts by Napolean B.
Old Jun 21, 2003, 12:02 PM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
Any glue line will alter the melting characteristics of the foam at least a little.
A very light spraying with 3M77 (the old foam compatible formula) will probably have the least effect.
If you can determine the places where the wire cut will pass through the joint before joining the panels, you can mask off a thin strip on each panel before applying the adhesive so that the wire doesn't actually pass through glue. This method will allow the use of any foam compatible glue.
Ollie is offline Find More Posts by Ollie
Old Jun 22, 2003, 11:29 PM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
pica gluit. similar to elmers white glue.........
gregg f is offline Find More Posts by gregg f
Old Sep 06, 2004, 08:35 PM
JamesBullough is offline
Find More Posts by JamesBullough
Joined Sep 2004
Use green enviromently friendly contact cement
JamesBullough is offline Find More Posts by JamesBullough
Old Sep 09, 2004, 09:29 AM
Bako is offline
Find More Posts by Bako
BAKO
Bako's Avatar
Tbilisi, Georgia
Joined Jul 2004
epoxy
Bako is offline Find More Posts by Bako
foam safe glue? paul747 Beginner Training Area (Aircraft-Electric) 20 Dec 05, 2008 05:57 PM
Question About foam safe glue item Magrat HobbyKing 11 Jun 01, 2007 08:00 AM
New Product New Foam Safe Glue! racer78bu Foamies (Scratchbuilt) 7 Sep 19, 2006 04:52 PM
Foam Safe Glue cruisefor2 Foamies (Kits) 8 Oct 17, 2005 06:57 PM
Where to find a value on Foam Safe Glue -=SLaPPiE=- Foamies (Kits) 22 Feb 13, 2005 10:36 AM
