Old Jul 12, 2010, 01:17 AM
SGTalon is offline
Find More Posts by SGTalon
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
Cool
Enterprise-A - 1:300 Scale =) - Kit and plans now available!
So i have been seeing a lot of people trying out the Constitution Class Enterprise and not having a lot of luck getting it to fly. I thought it would be worth a shot to see what i can do.... Not that i don't have enough to do!
Doing basically the same controls i have on the Enterprise-D. Aileron and Elevator on the lower hull. I put a nice long - 3" elevator on there.
Saucer is 22" Dia, 46" Long. Should weigh in the neighborhood of 15-17 oz. Probably use the Towerpro 2409-12T like i did on the D. Now it is the Turnigy L2210-1650
Anyhow. Just spent a couple hours putting together a design. I will try to get to the build sometime soon.
Check it out!
Kits and Plans are now available!
Here is the link to the Build Instructions
http://www.sg-ideas.com/linked/enter...structions.pdf
*******Recommended Hardware********
• 2.6oz 250w Motor and Speed Control with 8x6 prop – Turnigy L2210-1650 - http://www.hobbyking.com/hobbyking/s...tor_250w_.html
• Going to need some connectors for the motor and esc - http://www.hobbyking.com/hobbyking/s...irs_20pc_.html
• Servos - Hextronic 9g and 5g servo (1 of each) - http://www.hobbyking.com/hobbyking/s...cro_Servo.html
• Battery - 2200 Mah 3s 11.1v LiPo –http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
• Radio Hardware - Any 3 channel or higher radio will work
*********Build Materials*********
• Carbon Tube for foam Reinforcement - 4mm OD x 3mm ID x 750mm long - http://www.hobbyking.com/hobbyking/s...w_4x750mm.html
• Carbon Tube for nacelle support – 3mm x 2mm Tube - http://www.hobbyking.com/hobbyking/s...3x2x750mm.html
• Carbon Flat for Saucer Reinforcement - 1mm x 6mm or so. http://www.hobbyking.com/hobbyking/s...5pcs_set_.html
• Gorilla Glue
• Razor Knife / Single Edge Safety Razor Blades
• Pushrod Wire - i usually use .037 but you can use any size you like
• Control Horns - I usually make my own from old credit cards.
• Hinge Tape - I use 3m Fiber tape 1/2" wide and make overlapping hinge strips. http://www.rcgroups.com/forums/showp...1&postcount=16
SGTalon is offline Find More Posts by SGTalon
Old Jul 12, 2010, 08:52 AM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Ok, a wierd idea: What if you hinged the leading edge of the saucer and did kind of a canard thing?
springer is offline Find More Posts by springer
Old Jul 12, 2010, 09:41 AM
SGTalon is offline
Lenox, Michigan
Joined Nov 2005
I have found with these planes that it is really just a Nutball that has a tail.
The saucer is the whole wing, the stuf hanging off the back just acts like the feathers of an arrow. They just keep it going straight. I can alter the trajectory of the plane a bit by moving some control surfaces in the back but the main stuff happens with the saucer.
At least i think so!
A lot of people seem to be having trouble with controlling the Old Enterprise. I just want to see if i can solve some of those problems. The D seems to work great! You saw it. It just flies like a regular plane.
I am not sure when i am going to get a chance to build this guy with how busy i am but i am going to try.
Old Jul 12, 2010, 12:23 PM
rcshirt is offline
Find More Posts by rcshirt
miniture aircraft pilot
rcshirt's Avatar
United States, FL, Tampa
Joined Oct 2007
rcshirt is offline Find More Posts by rcshirt
Old Jul 12, 2010, 12:28 PM
PaulDaniel is offline
Find More Posts by PaulDaniel
Joined Sep 2007
Like this:
Star Trek Enterprise RC plane (2 min 0 sec)
PaulDaniel is offline Find More Posts by PaulDaniel
Old Jul 12, 2010, 12:44 PM
SGTalon is offline
Lenox, Michigan
Joined Nov 2005
I've seen that one. I hate that the engine nacelles are attached to the saucer! It totally takes away the realistic look of it.
It does fly nice through. I think adding the extra horizontal to the lower hull along with the nacelles and pylons will help keep the level flight going. By adding the ailerons it will be very controllable.... at least that is my theory
Old Jul 12, 2010, 01:39 PM
zedz is offline
Find More Posts by zedz
zedz's Avatar
San Tan Valley, AZ
Joined Apr 2010
SG, I don't know if it's been tried or not but what if you make the lower body a tube and put a edf in it vs the prop?
zedz is offline Find More Posts by zedz
Old Jul 12, 2010, 02:43 PM
SGTalon is offline
Lenox, Michigan
Joined Nov 2005
Hey Zedz!
It would never work for a few reasons. #1 is the balance! The CG on this guy is gong to be right behind the prop slot or maybe a little farther forward!
The other reason is i think i am going to need the flat surface there to help with lift. That is also where i am putting my elevator.
After building the first Enterprise-D i found that the CG is much farther forward than i thought.
Old Sep 19, 2010, 09:23 AM
mastrsn is offline
Find More Posts by mastrsn
Procrashtinating Builder
mastrsn's Avatar
about 12" from my computer in Jacksonville Fl.
Joined May 2004
TOS Version
Here are some plans that I dug up on the web of the TOS Version. When printed, they will give you a 12" saucer. A Tower Pro 21 should be ample power for it and the size comparison to SGTalon's Enterpise-D should be real close to "scale". Whit some cleaning up, they should be good for skins as well.
mastrsn is offline Find More Posts by mastrsn
Old Sep 19, 2010, 11:42 AM
mastrsn is offline
mastrsn's Avatar
Joined May 2004
Using model rocket body tubes for the engines, this is how I'm planning to build it.
Old Sep 19, 2010, 04:18 PM
SGTalon is offline
Lenox, Michigan
Joined Nov 2005
Looks scary Mastrsn! Rockets? 2? Holy crap that is going to be insane!
Make sure you do glide tests before you let it fly. You want to be sure you can at least control it a little!
Old Sep 19, 2010, 05:12 PM
mastrsn is offline
mastrsn's Avatar
Joined May 2004
You've said that once before about this design. NO ROCKETS! You can buy the Body Tubes the Estes rockets are made of. They come in different sizes. I figure a hollow body tube about the same size as the TOS' warp engines might be aerodynamic enough to help with flight. I.E.- my "Hoopster Stick"
Hoopster Stick pt 2 (4 min 9 sec)
Old Sep 19, 2010, 07:38 PM
SumthinsFishy is offline
Find More Posts by SumthinsFishy
Airplane Killer
SumthinsFishy's Avatar
Orange County, CA
Joined Oct 2009
Looks like a fun plane to me!
SumthinsFishy is offline Find More Posts by SumthinsFishy
Old Mar 22, 2012, 12:26 PM
SGTalon is offline
Lenox, Michigan
Joined Nov 2005
Construction of NCC-1701-A Commencing
With the arrival of my Model Plane Foam, I now have a large supply of pure white foam to build planes!
Well this is just dying for me to build my Enterprise-A.
So here goes.
I tweaked the design a little. I increased the size of the non-saucer horizontal surfaces by about 20% to help with lift in the tail.
Here are the templates ready to go. It is pretty big! Nacelles are much bigger than the -D or Voyager.
I will be cutting it out tonight!
Stevo! How about a decal kit?
Pretty excited about this one.
Old Mar 22, 2012, 12:49 PM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Should work perfectly fine the Enterprise glider on youtube uses the same control method and that flies very nicely in the vid
scousethief is offline Find More Posts by scousethief
Reply With Quote  (Disabled)
Yet Another Slowstick... The XL... This is one rock solid AP platform! BGarrison Aerial Photography 105 Feb 19, 2013 02:29 PM
Question Yet another this one or that one question. GT Power A6 vs. Turnigy Accucel ugly john Batteries and Chargers 5 Sep 08, 2008 03:52 PM
Build Log Yet another SA Stella....But this one is different! P-38J-Lightning 3D Flying 4 May 10, 2006 05:14 PM
Discussion Balancing Question, Yet Another One bnflyn Batteries and Chargers 6 Feb 24, 2006 06:24 PM
CC25 cutoff problem - (yet another one!) bhenry Castle Creations 5 Oct 26, 2005 01:46 PM
