Old Jul 11, 2010, 08:10 PM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Build Log
And for my next trick....Tucker P63
Well, after a break from Scale for a while so I can play with bright colors and stuff, I've settled on the next scale project...
The C. Tucker P63 Clipped-wing racer.
This thing was chopped from 38' span to 25.8'! The model will most likely be retract equipped, and full span P63 plan will be around 50" (chopped, I believe will be about 32" or so)
What can I say, I like a challenge!
Working on the drawings, prolly start building when the weather turns ugly in the fall, it's just too nice to sit in the basement and build for the next couple months...
If anyone has any more info on RACE 28, or on the '63 in general, please , by all means , post it
Mark
mrittinger is offline Find More Posts by mrittinger
Old Jul 12, 2010, 05:48 AM
Zephyr41 is offline
Find More Posts by Zephyr41
Zephyr41's Avatar
Malanda, QLD Australia
Joined Jul 2004
Nice! I can't wait to see the finished model.
From what I can recall (don't take this as gospel) Tucker had a pair of P-63s. NX62995 #28 'Tucker Special', later 'Flying Red Horse', painted white and N63231 #30 'Easter Egg', painted a very fetching pale purple. #30 was practically a sailplane with the wing only clipped to 28'6" for the cross-country Bendix race. The name Easter Egg was possibly only used as a joke, I haven't seen a photo with the name painted on the plane.
I think I have some drawings, will PM you when I dig them up...
Rich
edit: A couple of pix of #28 and a colour pic of #30 at http://www.airrace.com/1949%20NAR%20.htm
Zephyr41 is offline Find More Posts by Zephyr41
Old Jul 12, 2010, 07:36 AM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
RACE 30 was a gross pale purple color ...I've seen a few color shots and you can lose your lunch if your not careful!
Tucker had two, you are correct. I like the White one
Had a pretty good discussion with Keith Shaw about wing sections, design, tip plates, etc. Should be a very interesting project. I know I can make one fly, but can it be controlled? lol
Keith was saying his Crosby racer had issues with air over the fin, and ended up with quite a bit of right thrust to reduce it's effect, so I am for sure keeping this in mind...that's why I find it good to talk with other modelers about neat projects.
Think about this.....11'4" prop on a 25'8" span airplane!
Old Jul 12, 2010, 01:26 PM
Ojimy is offline
Find More Posts by Ojimy
Ojimy's Avatar
Cincinnati, OH
Joined Mar 2003
I don't know if that airplane was successful as a racer, but if it wasn't, it was probably because there wasn't enough wing area to loft the B***S of the guy flying it...
Ojimy is offline Find More Posts by Ojimy
Old Jul 12, 2010, 02:22 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
It got off the ground, but was a BEAR to turn. Certainly , a very large pair needed to fly that thing!
I think I can do it. Keiths little Crosby has very small wings for its fuse size, and it flies well,but it's a handfull...
Mark
Old Jul 12, 2010, 07:27 PM
Zephyr41 is offline
Zephyr41's Avatar
Joined Jul 2004
P-63 #55 (I can't remember the registration- it was black with yellow lettering) had a pretty short wing, maybe not as short as #28, and it apparently handled quite well. Mind you, the team had half of Bell's aerodynamicists and test pilots working on it so it should have been OK!
Old Jul 12, 2010, 09:04 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Good luck! Better approach the project with the view that it's got a lot of fuselage for the wing area, not it's not got much wing area for the fuselage size.
Should keep you quiet for a day or two this winter
Regards
Dereck
Dereck is offline Find More Posts by Dereck
Old Jul 12, 2010, 09:07 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
I was looking at it as a very big fuselage for its wing size.
Keith suggests tip plates, even if not scale.Apparently, his research has shown the all the drag returns that was lost in the wing clip, but it WILL help provide a bit more lift.
No, I do not plan on flaps. That, sir, would be cheating
Old Jul 12, 2010, 09:16 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
There were several, Tucker's #28 having the shortest wing at 25'8". Another had 28'.
Pics from Airrace.com....
Old Jul 15, 2010, 06:25 AM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
At 1.25"=1'
41" long
48" full span
32.25" clipped span
13.75" scale prop
At 1.5"=1'
49.2" long
57.6" full span
38.6" clipped span
16.5" scale prop
Might go for the bigger one, could handle the grass better, yet still fit in the car in one piece so I do not have to take it apart all the time.
Old Jul 15, 2010, 12:33 PM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
"RACE 30 was a gross pale purple color..."
Back in 1955 there was a control-line flying field in Berea, OH, adjacent to Cleveland Hopkins Airport. Near the C-L field was a small dump. In that dump was the cockpit section of a P-63 or P-39 that had a pink-purple color, much faded. At the time, I didn't have (or know how to use) a camera.
Also near that dump was a shabby-looking hulk of a Grumman S2F Tracker Navy twin.
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old Jul 16, 2010, 10:49 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
At 1.5"=1', I get 583 sq in full span , and 426 clipped.
If I get to about 5 lbs RTF, that would get me 19.8 oz loading full span, 27.11 clipped.
If I get to about 6 lbs RTF, that would get me 23.76 oz loading full span, 32.53 clipped.
At 100 watt/s lb, 5 lbs would net 500 watts and 6 lbs would get me 600 watts.
Old Jul 17, 2010, 10:03 AM
sgtdirt is offline
Find More Posts by sgtdirt
Mentor, OH
Joined Dec 2004
Mark,
regarding the power plant, you may want to think about a gear box to spin that huge prop. in the long run, it may save weight (smaller motor, smaller lipo...).
without seeing the plan, but knowing your build style, i would think you could get this way lighter.
sgtdirt is offline Find More Posts by sgtdirt
Reply With Quote  (Disabled)
Old Jul 17, 2010, 10:11 AM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
Jim R.
when i was a young boy, i remember seeing those rings. IIRC, there where 3 in a row. they are long gone now
Build Log My next trick ...Graupner Neptun more coffee Scale Boats 93 Oct 20, 2010 07:37 AM
Help! My next plane -- suggestions? Looking for something in particular :D Garret H Electric Plane Talk 5 Jun 08, 2010 10:14 PM
Discussion Mastered my first plane, Hawk Sky, what next for aournd $150? dhake Parkflyers 5 May 27, 2010 04:29 PM
Cool My trick MSR landing! Balr14 Micro Helis 8 Apr 13, 2010 06:59 PM
Discussion Building Techniques for my next Mig-21 Old Man Pusher Prop Jet Models 3 Sep 05, 2009 11:46 PM
