Old Jul 09, 2010, 09:07 PM
slashPRE-RUNNA is offline
Find More Posts by slashPRE-RUNNA
slashPRE-RUNNA
LBC
Joined Jul 2010
How do i charge my lipo?????
i have a pro peak sigma 2 lipo charger that i got at hobbypeople in lakewood california. i also have a hobby people 7.4volt 5000mah lipo battery. the guy at hobbypeople said,"this fucker here should last about 40 minutes." it only lasted about 10. and i think its because i dont know how to use my charger. right now i have a traxxas slash with a castle creations sidewinder 4600(motor and esc).
BTW: i lost my manual!
slashPRE-RUNNA is offline Find More Posts by slashPRE-RUNNA
Old Jul 09, 2010, 09:40 PM
Cleared2Engage is offline
Find More Posts by Cleared2Engage
Happiness is a belt fed weapon
Cleared2Engage's Avatar
Ventura, CA
Joined Oct 2009
Two things could be wrong. You might have inpropper gearing which would cause it to heat up and shut down or the battery isn't properly charged. Done properly that battery should last you at least 30 minutes.
You should be able to find the PDF manual online.
Cleared2Engage is offline Find More Posts by Cleared2Engage
Old Jul 09, 2010, 09:58 PM
rangamatchstic is offline
Find More Posts by rangamatchstic
Mt helena western australia
Joined May 2009
ahh, exspensive lipos, but what charger are you using, if the battery is brand new, you need to charge it at half its amperage, so it will take 2 hours, so for a 5000mah u charge at 2500mah or 2.5a, also you need to make sure that on your charger it says 2s lipo, if it says 3s 1s ect, you will be damaging the battery, also is you balancing plug in its socket? if not u could damage the battery when you drive it, the balancing plug is the white plug that for a 2s lipo has 3 wires going into it, but to help, please tell us what charger you have and possibly a pick =)
rangamatchstic is offline Find More Posts by rangamatchstic
Old Jul 10, 2010, 07:38 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Your charger looks exactly like the AC6 and similar chargers so what you are going to want to do is select LIPO charge by pressing the BATT type button. Then press enter and push the INC button to change the charging type to BALANCE then when you press enter select 2S and then increase the MAH to 5000mah and then hold enter to start the charge, if your pack is drained it will take 1 hour or so to charge.
freechip is offline Find More Posts by freechip
Old Jul 10, 2010, 03:17 PM
Duster_360 is offline
Find More Posts by Duster_360
Texas
Joined Aug 2006
Originally Posted by slashPRE-RUNNA View Post
..... right now i have a traxxas slash with a castle creations sidewinder 4600(motor and esc).
You can find the manual here - this is the 2wd version - all the other manuals are located here. Find your RC, then go to exploded view and that manual is there -
http://www.traxxas.com/PDF-Library/5805_manual.pdf
Duster_360 is offline Find More Posts by Duster_360
Old Jul 10, 2010, 03:30 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Since hes asking about HOW TO CHARGE I think it safe to assume he lost the CHARGER manual and not the trucks manual.
Old Jul 11, 2010, 03:28 PM
Texas
Joined Aug 2006
That charger manual is not online, others have looked. One said he contacted RpiMax and they sent him a copy -
http://www.ripmax.com/rm_contact.asp
This manual would prob do in a pinch, these appear to be the same charger -last line center panel -
http://www.hota-exp.com/product_info...2d5m20c0cbnah7
Old Dec 11, 2011, 04:45 PM
airfoxmedia is offline
Find More Posts by airfoxmedia
Joined Nov 2011
after the first run of the charge, can u set the charge current to 5.0a?
also, im assuming 3s = 3 cells??
also, also, how do u know when its done?
thanks!
airfoxmedia is offline Find More Posts by airfoxmedia
Old Dec 11, 2011, 07:32 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
It will stop automatically when it's done charging. If it's a 2s pack, it will be at 8.4v, if it's a 3s it will be at 12.6v. If you're pulling it off the charger before it finishes, that definitely explains why you aren't getting much run time.
wparsons is offline Find More Posts by wparsons
Old Dec 17, 2011, 05:20 PM
anr2442 is offline
Find More Posts by anr2442
Joined Feb 2010
Yes 3s is USUALLY 3 cells. A single cell is 4.2 volts when charged. Storage voltage is 3.85v per cell. After you get done running the voltage will likley be around 3.5 volts per cell.
Try to always use the balance charge if it has it.
anr2442 is offline Find More Posts by anr2442
Discussion How do I charge multiple LiPo's....walkera 4g3 nige838 Batteries and Chargers 5 Nov 10, 2009 10:15 AM
Question After how many charge cycles do you give a new lipo "full throttle" arukum17 Batteries and Chargers 1 Oct 31, 2009 09:11 AM
Help! How do I figure out how to charge my battery? *Pictures* tofor Electric Power Cars 17 Oct 04, 2009 03:44 PM
Help! how do a charge a lipo pack on a triton eq? First time! hacker002 Batteries and Chargers 5 Aug 27, 2009 03:01 PM
Question how to connect and charge a lipo battery park? my fist time! hacker002 Batteries and Chargers 4 Aug 27, 2009 11:47 AM
