Old Oct 15, 2010, 06:24 AM
ozgur is offline
Find More Posts by ozgur
ozgur's Avatar
Joined May 2009
Hello guys once again,
Really sorry for my late posts. Probably I solved my aileron problem. A couple days ago, probably the last sunny and warm Sunday here in Moscow we made the maiden flight of my beauty. It was great and did not have any trouble... Only the landing part was little bit rough but at the end everything was fine. You can watch the video from below link;
Dscf3720111.avi (6 min 17 sec)
Only I have one question and need your help; this baby is around 4.3 kg (~10 lbs) and I am using saito 125 engine. The nose of the plane is so heavy and thats why I put additional weight of 125gr to the tail and I am still around 1cm further towards to LE of CG. Last night I re-checked the CG with GP CG machine and find out additional 80gr more I need to reach advised CG point. I am sure all its because of the saito 125 due to its heavy weight. Is there anything I can do rather than adding extra lead weight to the tail section? (I already changed the place of the battery more back)
Best regards,
Ozgur
ozgur is offline Find More Posts by ozgur
Old Oct 15, 2010, 09:52 AM
ton2di is offline
Find More Posts by ton2di
United States, MD, Bowie
Joined Sep 2009
Ozgur. Hot landing over there. Do you have enough flaps for landing in that short field? I dialed in more flaps than the manual calls for so it would slow it down more on approach. The engine that you have (saito 125) is not that much heavier than the OS91FS that was recommended in the manual. A little nose heavy is ok. Mine balances at about 1/2" forward of the recommended 5 5/8". I have about an ounce of weight at the tail. By the way, I am using an OS 120FS III for power which is about 33oz. What prop are you using in that saito 125?
ton2di
ton2di is offline Find More Posts by ton2di
Old Oct 15, 2010, 02:51 PM
ozgur is offline
ozgur's Avatar
Joined May 2009
ton2di, to be honest there were no flaps... Due to maiden flight excitement, we forget to open the flaps! I was using Master Airscrew 16x6 K Series Propeller and Byron Fuel 10% nitro. What I don't understand Saito 125 is around 21.87oz, which means 11oz lighter than your OS 120FS III and still I have to add 2.82oz to the total of additional weight of 2.64oz just to catch the manuals CG 5 5/8". Because our current CGs are almost the same 1/2" forward to the recommended one!!! So strange?? We have so short and rough runway to land and I have to slow down that nose heavy baby as quickly as possible.
Ozgur
Old Oct 15, 2010, 04:26 PM
ton2di is offline
Joined Sep 2009
The flaps make a big difference in landing speed. I repeat... use it so it would not strain the main wheels when speed drops. I have my receiver battery all the way aft as well as the fuel tank almost in the middle of the plane to get to that c.g. setting. My engine has a pump so I could do that to the fuel tank. Good luck on your next flights. I will try to upload a video of my flight and landing in our field.
ton2di
Old Oct 16, 2010, 09:28 AM
ozgur is offline
ozgur's Avatar
Joined May 2009
Dear ton2di,
I am sure I will use flaps for the next flights. Thank you very much for the photo and the idea especially for the battery all the way aft. I am going to do that. Can you also give me little bit more info about shifting the fuel tank and using a pump, photo will be appreciated. What kind of pump is this? How can I install it to my plane?
I am using stock retract system, for this winter I decide to use skis and ordered from tower hobbies some ski for .60 size planes. I hope it will work.
For the following spring I am planning to order CJ pneumatic retract system special to our planes. What do you think? I read a lot from rcuniverse about the retract system and confused little bit, some advise robart, some CJ and some sierra.
Ozgur
Old Oct 16, 2010, 09:58 AM
ton2di is offline
Joined Sep 2009
Well, I will try to post some pics of the fuel tank set up. It's located under the tray that is supposed to be for the receiver and battery location on the manual. It makes the shift from a full to almost empty tank less noticeable on the trim of the plane. The pump is stock on the OS120FSIII, but I have successfully tried a perry vp-20 on my saito 125... just have to make some minor adjustments on the needle to make it work well.
Regarding the retracts, I have no problems with mine. What I added are the oleo struts from robarts that dampen landings so it wouldn't hurt the wings a lot on not so good touch downs. Air retracts just add weight and complexity to the set up. If you want to try it, some are switching to electric retracts that are plugged into one channel. I'm ok with the mechanical ones though.
On the prop selection, if you're gonna fly on a more open space, you could try a 15x8. It would give it more speed while having the same load as a 16x6. I personally use an apc 14x10 or 14x12N and it makes some wonders... take some time to get into momentum, but the speed is great... landings are another story.
Old Oct 22, 2010, 01:16 AM
ozgur is offline
ozgur's Avatar
Joined May 2009
Dear ton2di,
Yesterday I ordered "60-120 Class Offset Oleo Struts for P51 Mustang" from rcskylite. Forgive my ignorantness but; when they call it oleo struts, is that means a working, functional oleo struts?
So can we say that it has a real functional shock absorber which will reduce the bouncing and help my landings? Or, the only benefit is preventing the damage on retracts, and maybe makes the plane more bouncy?
Also in its specifications saying that "Total Length: 160mm", meanwhile the "Landing Gear Struts for the Top Flite P-51D Mustang" is 7-3/8" (187.3mm), will that be ok and how should I install oleo struts instead of the stock ones?
Beside I also order 3 1/4" low bouncy rubber scale tires from Dubro, but they are way too heavy comparing the stock ones (46gr vs. 125gr) even at present I am dealing with nose heavy problem. I hope i done the right thing.
Ozgur
Old Oct 29, 2010, 06:51 AM
paul timms is offline
Find More Posts by paul timms
paul timms's Avatar
Australia, VIC, Kyneton
Joined Apr 2008
Spinner fit
I'm also on the build of this model. I have one question to the fit of the spinner its not a good fit ,its able to be moved up and down on the crankshaft. The motor that I'm using is a 125 saito. are they all like that. Yours Paul T
paul timms is offline Find More Posts by paul timms
Old Oct 29, 2010, 09:01 AM
ton2di is offline
Joined Sep 2009
Ozgur
The oleo struts help those not so good landings absorb most of the shock. I can actually see my struts working even while taxiing. It moves up/down little bit so my plane does not bounce all over even on our grass field. The length of the new oleo will be shorter than the original strut because you have to cut the original strut to insert the new one so make sure it's the same length overall like the original when installed. I also have the heavier type tires on mine. Just make sure to add flaps on landing and it will slow the plane down on approach.
Paul timms,
The spinner comes with different types of adapter bushing for different engines. Make sure you insert it to the back plate of the spinner.
Old Oct 29, 2010, 05:53 PM
paul timms's Avatar
Joined Apr 2008
thanks
I found them. Thanks. ton2di
Old Nov 01, 2010, 11:29 AM
Jsutherland8 is offline
Find More Posts by Jsutherland8
ELECTRIC R/C
Jsutherland8's Avatar
Canada, ON, Woodstock
Joined Feb 2006
Top-Flite P-51 ARF with 1.08 nitro
Looks good....Nice to see a YOU-Tube Video of the TF P-51. Just got the Top-Flite ARF with a 1.08 nitro motor in it, some servoes in the wings, but still needs lots of work to get it in the air. I just got the LG servo in and hope to have it ready to fly by the end of November. It was -4*C last night, but the days may get up to 10*C for a bit yet. May have to wait for Spring to get in the Maiden flight.
I have been flying a Hangar 9 P-51 PTS all summer with 20+ flights, and only one dead stick landing in the corn field.(no damage) After 1/2 hour of searching, in thick 3 meter high corn, it was hung up on the LG, still 1 meter off the ground. (like the RED tail)
Jsutherland8 is offline Find More Posts by Jsutherland8
Old Dec 07, 2010, 08:02 AM
alienteabagger is offline
Find More Posts by alienteabagger
Gravity sucks ↓
alienteabagger's Avatar
USA, FL, Miami
Joined Nov 2008
Wow! Amazing what can happen in a few few months! I havent flown mine as much as I have wanted to but I have flown it. It's been an awesome plane!!
I got the bug a couple of weeks ago and converted it to electric. Haven't had a chance to fly it since then but its looking to be a beast!
alienteabagger is offline Find More Posts by alienteabagger
Old Dec 30, 2010, 01:28 PM
tracytown is offline
Find More Posts by tracytown
United States, TX, Houston
Joined Mar 2010
I had this one before, it flies and track very well. I am just finish building a hanger 9 P51 blue nose. I prefer a blue nose better.
tracytown is offline Find More Posts by tracytown
Old Jan 01, 2011, 11:38 PM
ton2di is offline
Joined Sep 2009
Well guys, I have jumped into the big size engine in order to turn this 4 blade 15.5x12 apc prop. It flies very well and has lots of speed. It's an OS200FS.
Old Mar 26, 2011, 06:45 PM
Rockin G is offline
Find More Posts by Rockin G
If It Aint Broke,I'll Break It
Rockin G's Avatar
United States, TX, Lockhart
Joined Dec 2008
Deleted---posted in wrong thread
Rockin G is offline Find More Posts by Rockin G
Sold Top Flite P-51D .60 size NIB collectors edition ch47dfe293 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 17, 2014 10:57 PM
Discussion Top Flite P-40 Warhawk ARF .60-.91,64.5" mike early Fuel Warbirds 12 Aug 27, 2010 06:35 AM
Discussion TOP FLITE P-51D Mustang .60 Retracts help rcflyer44 Fuel Warbirds 7 Jun 28, 2010 07:28 AM
Discussion Need muffler help w/.60 size top flite P-51D and OS.91 FSR sstewart1 Fuel Warbirds 1 May 03, 2010 05:25 PM
