Old Jul 07, 2010, 10:14 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Hobby King Spektrum-like RX
Got my $15 inline Rx (RA61A) today and surprise, surprise, no covering, no pin ID or +/- markings.
Called a friend who has already flown with his and here is the layout.
With the PC board lying on it's flat side with the pins facing you,
the AUX channel is to the right. The ground lead is on the bottom and the signal lead is the top pin.
I put shrink wrap around it and taped on an ID label.
For those that would like the ID label, here it is.
hoppy is offline Find More Posts by hoppy
Old Jul 08, 2010, 12:19 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
A picture of the wrapped Rx with the label taped on.
Range test with the DX6i showed 85 paces before signal loss.
As mentioned in the other thread, fail safe on loss of signal only applies to the throttle. Other channels remained in the postion they were at on signal loss. Signal recapture seemed fast.
Old Jul 08, 2010, 08:26 PM
dhoyt7141 is offline
Find More Posts by dhoyt7141
United States, CA, San Diego
Joined Apr 2008
Is 85 paces comparable to a Spektrum receiver?
dhoyt7141 is offline Find More Posts by dhoyt7141
Old Jul 08, 2010, 10:23 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Depends what you mean by paces. Even Spektrum has stopped using this silly unit -- they now say 25 to 30 m. So even if you take very small paces, 85 of them are likely to be in excess of Spektrum range. Note however, that it makes a big difference whether you have the model on the ground (which is what Spektrum assumes) or raised 2-3 feet on a non-conductive surface (as many other manufacturers advise). Note also that various people have reported less range than Spektrum.
I now have one of the HK pseudo-AR6100s and will compare it with the real thing as soon as I can.
Daedalus66 is offline Find More Posts by Daedalus66
Old Jul 08, 2010, 10:32 PM
swede-rcgroups is offline
Find More Posts by swede-rcgroups
United States, IA, Grinnell
Joined Mar 2005
I used my HK clone today(the one pictured on HK site with the black shrink tube)and it worked great, binded right away to my DX7,solid performance in the air on a 6 oz parkflyer. I did a short range check, maybe 10-15 yards.
I'm happy with it.
S
swede-rcgroups is offline Find More Posts by swede-rcgroups
Old Jul 08, 2010, 10:36 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
85 paces for me is about 250' .....
The Tx and Rx were at waist level.
I was very surprised and at the 200' mark shouted out to my wife to keep the trainer switch on thinking she had let it go off..... she hollered back that it was on the whole time.
As I recall, 100' min is recommended for the Spektrum RX.
Old Jul 09, 2010, 01:55 AM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
Chinese Spektrum clones are spreading like wildfire. The price barrier finally broke down as we all hoped for.
Spektrum is moving ahead with new system which will make old DSM2 obsolete and uncompatible.
JR is breaking away from Spektrum by introducing their own system which is not compatibile with Spektrum.
Old Spektrum users are left holding bag.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Jul 09, 2010, 05:46 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
No I am not holding a bag but I am holding my Spektrum unit and luving it.
freechip is offline Find More Posts by freechip
Old Jul 09, 2010, 06:48 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Spektrum used to say 30 paces but now say 25-30m (they vary a bit from one place to another). So 250 feet is more than twice this. Given that you had the RX and Tx off the ground, your observation probably represents roughly similar performance to a genuine Spektrum Rx.
Old Jul 09, 2010, 08:19 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
My DX6i manual says to have plane on ground and the TX in the position that is used for flying.
Range should be at least 30 paces (about 90').
I'll recheck it in that configuration.
Old Jul 09, 2010, 09:28 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
The manual also says if it fails the range check to call HH/Spektrum for help BUT do not follow this recommendation if it fails.
Old Jul 09, 2010, 12:06 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
RANGE TEST #2
RA61A
Airplane on ground - antenna about 5" above ground level in vertical position.
TX about 3' above ground
Range Check switch "On"
Both Rx and Tx antennas in a vertical orientation.
Test Result:
Control OK out to 105'.
Old Jul 11, 2010, 10:24 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Flying Report on range.
On a 28" wing span foamy, I took it to the limits of my eyesight as far as recognizing the planes orientation and had no control problems. That's probably 3X farther away than I would normally fly the plane. Flew about 10 min.
Old Jul 11, 2010, 12:00 PM
Joined Mar 2005
Then why is Spektrum coming out with the DX8? I think DMS2 will be around for a long time to come. Thousands of pilots are using DSM2 with no problems what-so-ever.
S
Old Sep 19, 2010, 07:29 AM
AirmanAirhead is offline
Find More Posts by AirmanAirhead
AirmanAirhead's Avatar
Novato, CA
Joined Dec 2008
Subscribed
AirmanAirhead is offline Find More Posts by AirmanAirhead
Alert Quem tem Tx e Rx da Hobby King...Experiencias, Referencias e Testimoniais Guga Brazil 20 Jan 21, 2011 06:20 AM
For Sale Hobby King 6 channel tx and rx parts losikid Aircraft - General - Radio Equipment (FS/W) 2 Dec 27, 2009 11:14 PM
Wanted Hobby king tx, or other compatible brands with its rx losikid Aircraft - General - Radio Equipment (FS/W) 1 Nov 05, 2009 10:21 AM
Discussion Car ESC and 2.4 Hobby King RX NX-687 Radios 4 Oct 01, 2009 10:23 AM
Discussion Would Like To By A E Motor Equivalent Of An E-flite 46 In Hobby King FedericoA Power Systems 4 Sep 21, 2009 05:50 AM
