Old Jul 07, 2010, 08:27 PM
mkscott2 is offline
Find More Posts by mkscott2
Cincinnati
Joined May 2005
Question
Convert a U-control Nobler to electric?
In this, my first post in these forums, have a question for some of the experts here. Long story short: after taking the family to the Greater Cincinnati RC Club and watching some of the pilots there for a couple hours, I just couldn't resist getting back into building/flying, and decided to dust off an old Nobler kit. I have already decided to convert it to RC, and have done plenty of research (mostly here) for tips and tricks. I am not quite convinced that I should do one more conversion to this plane...glo to electric. I am concerned with weight/balance and cost. I don't want to totally throw off the flight characteristics beyond the ukie to RC conversion. I also don't want to spend more $ on motor, battery, ESC, charger, etc.; than I would otherwise spend on a glo motor and fuel tank. Suggestions? Thoughts? Advice?
mkscott2 is offline Find More Posts by mkscott2
Old Jul 07, 2010, 08:37 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Keep you U-Control plane and buy a RTF kit, your going to crash and its going to be much easier to repair a foam plane then it is your U-control unless its foam also.
A good plane to start with would be HH Super Cub.
freechip is offline Find More Posts by freechip
Old Jul 08, 2010, 07:39 AM
mkscott2 is offline
Cincinnati
Joined May 2005
Thank you for the advice freechip. While it's been some time since I last flew, I am willing to take the risk with this one. I still intend to build the Nobler as an RC, so I merely need to determine what power set-up to go with. I lean toward electric, but need some suggestions on a good set-up so that I can compare to the cost/hassle of a fuel set-up. BTW, started building last night...mostly got the wing punched out and made measurements for shortening the longer (port) side of the wing. I'll post pics once I figure out how...
Old Jul 08, 2010, 08:37 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
IIRC -- Fox .35?
A set-up based on E-Flite's Power 32 or 46; look at simialr sized planes they offer for guidence too: http://www.e-fliterc.com/Products/De...ProdID=EFL4800 .
And HH's: http://searchrc.horizonhobby.com/ind...d=129B2466AF4E .
jrb is offline Find More Posts by jrb
Old Jul 08, 2010, 11:26 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
You don't say how familiar you are with RC models and flying, but if you want to get your hand back in for both building and flying, do some research on Sig's Kadet range - especially the Seniorita, as the motor and so on looks to come closest to your aim of an RC Nobler. Unfortunately, you will spend more on electrics initially, though your fuel - a battery or two - will last you a lot longer than a gallon or two of glow fuel.
Have a feeling the Nobler concept got off the end of the usual wires, but you'd have to ask a local who's been aeromodelling in the US for some time - I'm a relative newcomer. Doubtful if someone who's into RC buying vice aeromodelling knows what a Nobler is
Advice at the usual internet rate - keep your Nobler kit intact for now. Start with a real RC trainer kit of decent size, learn to either fly or get back up to speed at your local club with an instructor who can spell 'RC' and some more. As you have a CL background, you might want to check up on Brodak manufacturing - www.brodak.com - who know about CL and are moving into electric CL. That would be a better 'fate' for a CL Nobler from a kit than wandering around line-less under RC
Hope that helps
Dereck
Dereck is offline Find More Posts by Dereck
Old Jul 08, 2010, 12:08 PM
mkscott2 is offline
Cincinnati
Joined May 2005
I guess my first post did not introduce much background on myself. I actually had the Nobler still in the box because I was flying more RC than CL several years ago. Since life happened with school-carrer-wife-kids-etc., I have limited myself to mostly to small choppers. I am quite familiar with flying (and crashing) RC...just haven't done it in a few years. In the mean-time the technology of electric has changed enough that I am considering this as an option for the Nobbler, but need advice for the best set-up. I have found info from those that have done the RC conversion, but nothing significant for the electric conversion I am interested in.
Old Jul 09, 2010, 03:46 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
The was, and still is a great design from the golden age of C/L. the is a few thread about electric conversions:
http://www.rcgroups.com/forums/showthread.php?t=1007707
Top flite used to have a r/c version of it in the 70's, I think you can still get the plan for it:
http://manuals.hobbico.com/top/rc14-nobler-manual.pdf
With today's computer radios it would be a lot easier to build:
http://www.top-flite.com/parts/discontinued.html
and for the ARF:
http://www.rcgroups.com/forums/showthread.php?t=878217
coriolan is offline Find More Posts by coriolan
Old Jul 13, 2010, 01:30 AM
1post is offline
Find More Posts by 1post
Joined Apr 2010
I guess that would be an EXTREMELY stand-off scale Corsair.
1post is offline Find More Posts by 1post
Old Jul 13, 2010, 07:56 AM
mkscott2 is offline
Cincinnati
Joined May 2005
Um, I guess it could be viewed as an stand-off scale Corsair...without the hinged wings?
Got both halves of the wing built last night. I chose to build them separately so that I could compare to two for equality, since the U-control version has a longer inboard wing. I'll post images tonight.
I start in on the tail feathers tonight, but first have to decide how I want to modify things- mobilize the rudder and give it clearance to move by modifying the elevator.
Still have not decided on an electric setup...or if I want to take that route for sure. I appreciated the suggestions so far, but am still hoping for some more suggestions for a good budget-friendly electric setup.
Old Jul 13, 2010, 11:04 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Keeping with the Navy theme; you might find some useful inof here too: http://www.rcgroups.com/forums/showp...postcount=4585 .
Old Jul 15, 2010, 12:25 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
-The Nobler is a typical ukie stunt model with a very short tail moment. This will make an R/C version that is very pitch sensitive but otherwise flyable similar to a lot of 3D-type R/C designs. It might be advisable to lengthen the rear fuselage to tame the pitch sensitivity. 40 sized electric powered models have become quite cost effective but buying the necessary power supply, lipoly balance charger, 3 high capacity Lipoly battery packs, motor, speed control, switching type BEC, and RC system will add up to a large initial investment. If you already have a suitable glow engine and glow engine support equipment, sticking with glow power will save you a lot of money. Seems I read about a previous Nobler RC conversion in a model magazine.
E-Challenged is offline Find More Posts by E-Challenged
Old Jul 15, 2010, 10:47 AM
mkscott2 is offline
Cincinnati
Joined May 2005
Good points on both fronts E-Challenged.
1. I was looking at how I might alter the rudder and rear of the fuse last night, and did not take the proportionally short distance into account. I think I will take your suggestion, and "lengthen" that distance by scooting the tail feathers back about 2". This will also allow for the rudder movement I need without modifying the structure of the fuselage.
2. Cost of electric: as I try to do my own research into a good electric set-up for this plane, I am finding that it may be worth-while to stick with fuel. I'm not completely set on that yet though, so please feel free to give suggestions on a good set-up. Chances are, there are options I have not considered in my own research, simply because I don't know what questons to ask.
still have to post pics of the progress...
Old Jul 15, 2010, 11:33 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Did you look at the motor & esc shown in my link above that is in my SNJ?
Old Jul 15, 2010, 12:26 PM
Mike Palko is offline
Find More Posts by Mike Palko
Mike Palko's Avatar
Telford Pa
Joined Aug 2002
[QUOTE=mkscott2;15530679]Um, I guess it could be viewed as an stand-off scale Corsair...without the hinged wings?
QUOTE]
I was under the impression that GMA designed it as a semi scale Caudron. That's the story I remember......
Mike Palko is offline Find More Posts by Mike Palko
Old Jul 15, 2010, 01:56 PM
mkscott2 is offline
Cincinnati
Joined May 2005
jrb-
I did take a look at the link you posted, but was completely distracted by the pictures of that plane- it's beautiful! Anyway, I clicked on it again to look at your motor/esc combo, and it seems quite reasonable.
Questions: what's the wingspan on that plane? Battery and prop? How does it fly with that combo?
Sorry I initally breezed past your motor/esc combo...but like I said, I was distracted by the pics of the plane!
Sold Top Flight Nobler Control Line Vintage Green Box flyingj Aircraft - Fuel - Airplanes (FS/W) 3 May 27, 2010 09:37 PM
Discussion Nobler ARF Control Line by Top Flite garyoehrle Control Line 8 Jun 17, 2008 02:22 AM
Convert u can do .60 to electric bach939 Sport Planes 1 Sep 12, 2004 02:21 AM
Convert u can do .60 to electric bach939 3D Flying 4 Sep 12, 2004 12:30 AM
