Old Jun 20, 2003, 07:58 AM
StahlmanGC is offline
Find More Posts by StahlmanGC
Nashville, TN
Joined Jun 2003
Newbie - Frying my Batt with Endoplasma. Help?
I'm new at the electric game, and am trying to build a PBF using an Endoplasma motor, geared 3:1 (GD-600) with a 12x8 APC. Currently using 8 cell 1350 NiMH pack. Here's the rub. When testing this setup, running the motor full out, the battery pack became very hot, very quickly. Seems I may be trying to pull too much current (I guess). Too much prop? Perhaps go to an 11x7? Not enough cells? Change gearing? (I do realize that prop unloading in air might help with load)
Can someone give me a quick tutorial? I'll be looking into getting Motocalc to learn, but I just don't want to fry things.
Thanks for any help.
Gray
StahlmanGC is offline Find More Posts by StahlmanGC
Old Jun 20, 2003, 08:26 AM
Jim Walker is offline
Find More Posts by Jim Walker
Fixed Wing Fanatic
Jim Walker's Avatar
United States, TX, McKinney
Joined Jul 2001
You need to see how many amps you are pulling. They sell some reasonably priced clamp on amp meters or the best way would be with an Astro Flight super watt meter. Another way would be to simulate your setup in motocalc. That should give you a ball park idea on your amp draw and what your cells are capable of.
Off the top of my head, I would say you are wayyy under geared/over propped with that setup. I was swinging an 11-7 on ten sub C cells and pulling 30 amps with 3.8:1 gearing. How many cells are you running? What are the physical dimensions of your cells? I'm not familiar with your 1350 nimh's, but I'm pretty sure that the smallest cell that will handle an endoplasma's current needs are the CP1700 nicads or the 5/4FAUP 1950 nimh's. If your cells are not equal to these cells I've mentioned then for sure you are pushing them way past their limits and toasting the poor things. Once again, at least download motocalc for a free trial and get an idea of what's happening.
Jim Walker is offline Find More Posts by Jim Walker
Old Jun 20, 2003, 10:34 AM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
Those nimh batts you have won't be able to handle the amps that the endo will pull. You need to run SC or SCR batts. The endo likes 10 cells. So, I would run 1900 or 1700 SC or SCR batt packs. The 12x8 prop is fine as I have (3) models running with 3 to 1 gearing and 12x8 folding props.
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Jun 20, 2003, 02:51 PM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
You can't just use any old rechargeable cell and expect it to work. Every cell has a limit as to how much current it can produce. In general, the larger the cell, the more current it can produce. Be wary of AA NiMH cells intended for digital cameras and children's toys. These are designed for maximum CAPACITY, not power, and have extremely low current producing capability.
In other words, don't use crap cells then ask why they're getting really hot...
At 3:1 gearing on 8 cells with a 12x8 prop, Motocalc says 48 Amps. That's too high. The motor will burn up in a few minutes.
mkirsch1 is offline Find More Posts by mkirsch1
Old Jun 20, 2003, 04:28 PM
Nashville, TN
Joined Jun 2003
Thanks to all for your assist. Clearly I need to put my head in a book and learn something!!!
Gray
Old Jun 21, 2003, 07:05 AM
Greg Covey is online now
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
Hi Gray,
Check out the Endoplasma setup on my Graupner Monsun Trainer at the bottom of my Trainers page.
Notice that my gear ratio is higher than yours for even an 11x7 prop and I am drawing 35amps on 10 cells. This will be less for 8 cells but the Endoplasma can handle short bursts up to 40amps.
To spin a 12x8 prop, you need the so-called "E3D" setup from Gary Wright and the 10T pinion gear. Do a search here for E3D for more information.
Finally, pick a cell that can deliver 40amps like the CP1700, CP2400, or HR-SC2600.
Good luck and welcome to the E-Zone!
Greg Covey is online now Find More Posts by Greg Covey
Old Jun 21, 2003, 04:45 PM
jmbig is offline
Find More Posts by jmbig
North Highland,ca
Joined Dec 2002
Take a look at building your own just test it 200 times
on nicads voltage above the others.
http://www.national.com/catalog/AnalogRegulators.html
jmbig is offline Find More Posts by jmbig
Old Jun 21, 2003, 05:39 PM
Kidknight is offline
Find More Posts by Kidknight
Addicted to Feigao...
Kidknight's Avatar
Lakewood, CA
Joined Sep 2001
I'm suprised nobody has mentioned the HR-4/5FAUP cells yet. You can get them atedogfight. They are supposed to be very good cells, even the pylon guys are using these things. They say that they break them in at 70amps, weeding out the bad apples(not my words, just some other guys). Most people think 40amps is the limit to these guys.
Like everyone else said, get yourself an Astro Wattmeter. The best 60 bucks I have spent yet.
Kidknight is offline Find More Posts by Kidknight
Old Jun 21, 2003, 06:07 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
I'm running my Endo on a 2.8:1 gearbox (pretty close to 3:1) and 8x2400 cells. A brief test with an Aeronaut 10x8 folder gave 45A static, so IMO a 12x8 would be way too much. I fly with a 10x6, that pulls 37A.
Bill Glover is offline Find More Posts by Bill Glover
Newbie with problem, help me!!! montu Beginner Training Area (Aircraft-Electric) 21 Dec 13, 2002 05:31 PM
timing my motor with amp meter ,need help? Marcos Power Systems 1 Nov 27, 2002 05:36 PM
What to do with my new geared Endoplasma motor? JStory Electric Plane Talk 7 Jul 02, 2002 08:17 AM
i am having a very hard time with my ZAGI 400X, please help!! compuatic Foamies (Kits) 22 Jun 13, 2002 07:45 PM
Total Newbie (Watch My progress with 0 Experience First Heli and Beginner) blt4ice Electric Heli Talk 11 Jul 29, 2001 11:45 AM
