Old Jul 07, 2010, 08:11 AM
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
Runathing - A Flyer inspired runabout
Hi all.
Well... Ed Crowell got me into starting this thread but after seeing some of the runabouts around here (his Speedster, GPR's thunderbird, etc...) I'm a bit embarassed to show my work.
Although I'm basically a sailing guy I've always loved runabouts, so about a year and a half ago I decided to (scratch)build one.
Since I couldn't decide which boat to build I decided to mix a few things...
The hull was based on Svenson's Flyer, slightly lenghtened to around 70cm at 1:8th on Delftship.
this is what I came up with:
The deck will have a "step" like the Nedcraft silverback and a paint scheme like this gorgeous Rocket scratchbuilt by a friend of mine here in Portugal.
I'll be showing some of the progress so far in the next few posts.
Cheers,
Tiago
pjesus is offline Find More Posts by pjesus
Old Jul 07, 2010, 08:14 AM
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
The first step was to cut the frames (by hand ), and assemble frames and stringers on the keel.
First (of many) mistakes:
Although I was aware of the need to use a building jig the excitment made me start right away.
Result: I had to correct some misalignments afterwords...
I went on with some more stringers, both on the sides and floor:
Old Jul 07, 2010, 08:17 AM
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
Went on to laying the bottom...
And bought the electronics (sailing boats are cheaper )
Old Jul 07, 2010, 08:21 AM
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
One more mistake (which, again, I was already aware of - man, I'm dumb):
I should have opened the hole for the propeller shaft in advance.
It took me some time but with care I managed to do it right:
You can also see the boards I glued to the sides, they will hold the electronics (ESC, servo bat) with velcro.
Some more interior details:
1. "Hooks" that will take the velcro that holds the battery
2. the aforementioned boards to hold the electronics
3. steering servo mount
4. holes for the antenna tube
Gotta go to lunch now...
Old Jul 07, 2010, 08:59 AM
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
After a couple of months with the boat on the shelf, I got back to it...
Motor mount... nothing fancy, I'll see later if it needs cooling.
The engine is a 3.500KV 40Amps outrunner brushless which I will feed with 8,4V.
Will do more than enough for a scale speed.
Gluing the side panels, after careful drawing and fine tuning...
You can see that the stern was rebuilt. That was because given the exterme curvature at that point the stringers just kept breaking.
At this time I really didn't know what to do on the bow and stern.
More on that later..
Old Jul 07, 2010, 09:03 AM
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
Next I wanted to do something different with the engine hatch.
I imagined it opening like a car hood instead of two hatches opening sideways like it's common on these boats.
The hardest part was that the hull is so rounded that a regular hinge wouldn't work.
So I had to engineer custom parts:
I hope to do those parts in brass later but for now they're plywood.
Closed:
Open:
At this stage I had decided to keep the stern closed on the bottom (unlike PunyV's Flyer - thanks a lot for your help, Kjell ) and built a platform to strenghten the stern and take the steering servo arm:
Old Jul 07, 2010, 09:05 AM
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
Next step... epoxy coating and paiting the interior:
You can see the tube I installed for laying the antenna.
Old Jul 07, 2010, 09:17 AM
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
Next... laying the deck.
Once again, given the complexity of the hull form, I was a bit affraid to start.
I eventually decided to use balsa instead of plywood.
Yet another mistake: I didn't lay the planks all the way fore to aft so I ended up with a flat spot fore of the engine hatch, which I had to fill.
No big deal since the deck will have another layer, but made for a really ugly work
Building the stern and stem with balsa...
It's probably a bit of cheating but I couldn't see a better way of doing the boat's edges...
This brings me to the current stage...
Well, that's not totally true, since I've started laying the final deck.
It will have a red stripe on the sheers and mahogany planking in the middle.
I'm hoping to do it an engine cover as well.
Hope you guys like it and I'd love to hear your advice on this project.
Cheers,
Tiago
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
PS: it's been in the water already, everything looked ok.
Old Jul 07, 2010, 09:31 AM
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
A stunning build Pjesus.. It looks incredible on the water!...
More progress please!
toesup is offline Find More Posts by toesup
Old Jul 07, 2010, 09:35 AM
So broke I can't pay attention
Naples FL USA
Joined Mar 2009
That looks pretty amazing, good job!
caymin last is offline Find More Posts by caymin last
Old Jul 07, 2010, 10:43 AM
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
Thanks for the comments, guys.
I forgot to say that in the last couple of pictures the hull had already been fiberglassed.
"More progress" will come as I go, but I must say I'm a very slow builder and I have several ongoing projects...
Cheers!
Old Jul 07, 2010, 11:51 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
^ He's embarrassed? ^
I wish my stuff was that embarrassing!
Awesome looking scratch build PJ!
Kmot is offline Find More Posts by Kmot
Old Jul 07, 2010, 03:20 PM
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
A very nice scratch build!
Jerome Morris is offline Find More Posts by Jerome Morris
Old Jul 07, 2010, 09:24 PM
Madison, MS
Nice work there, good progress. Hmm, 70 cm.; a bit over 27 inches or so?
jeepers1940 is offline Find More Posts by jeepers1940
Discussion F4 phantom, from J Morgan inspired. candane Pusher Prop Jet Models 12 Oct 28, 2009 10:20 AM
Build Log 2flat4u's runabout ski boat 2flat4u Dock Talk 3 Oct 25, 2009 06:35 PM
Build Log Eurovector....Eurofighter inspired jet 3DMON Foamies (Scratchbuilt) 10 Oct 16, 2009 06:25 AM
Sold Dumas 1930 Chris Craft Mahogany Runabout keenyoung Boats (FS/W) 4 Oct 05, 2009 03:28 PM
Discussion My first EPP scratch design: Golden Era Racer inspired park flyer iceburg47 Foamies (Scratchbuilt) 25 May 19, 2008 08:53 PM
