| Retail Price: | $159.95 |
| Number of cases: | 4 |
| Hardware included: | 2-56, 4-40, 6-32, 8-32, #0, #2, #4, #6, #8 |
| Accessories included: | Telescoping magnetic pick-up tool, 4 adjustable organizers w/ 18 compartments each. |
| Available from: | RTL Fasteners, 1-800-239-6010 |
It's a sad fact that most modelers' "bolt bins" consist of a small container with various nuts, screws, and washers from recently re-kitted aircraft. I'll be the first to say that I amassed a hefty supply of bolts over the years; I was proud of my collection and if you gave me 10 minutes, I could probably find the correct screw for the job, or at least get close. But after discovering the RTL Fasteners' Master Builder Assortment, I've already put those long fastener-hunting safaris behind me.
In this review we'll take a look at RTL Fasteners' Master Builder Assortment, a kit containing 2,124 pieces of hobby-appropriate hardware. We'll also look at their Miniature Wood Screw Assortment, and their new Bonded Washers (both available separately).
RTL Fasteners has included in the Master Builder Assortment a sampling of the most common types of fasteners used in the radio controlled hobby. Whether you're a fixed wing afficionado or you prefer the company of hovering aircraft, this kit won't discriminate. Even the surface crowd (vehicles and boats) will benefit from the diverse assortment of nuts, bolts, and screws found within.
The assortment comes unassembled, with all fasteners individually packaged and labeled by type. The easiest way to assemble the kit is to cut out the included diagrams and tape them to the inside of the plastic cases, then fill the compartments accordingly; we'll cover that in the assembly section below. Lets take a look at everything that's included.
The 2-56 hardware collection includes 308 total pieces. This hardware is grouped with #0 and #2 hardware (shown below) in the organizer. The 2-56 hardware includes:
The 4-40 hardware collection includes 356 total pieces. This hardware is grouped with the #4 hardware (shown below) in the organizer. The 4-40 hardware includes:
The 6-32 hardware collection includes 332 total pieces. This hardware is grouped with the #6 hardware (shown below) in the organizer. The 6-32 hardware includes:
The 8-32 hardware collection includes 160 total pieces. This hardware is grouped with the #8 hardware (shown below) in the organizer. The 8-32 hardware includes:
The #0 hardware is located in the 2-56 organizer, and contains:
The #2 hardware is located in the 2-56 organizer, and contains:
The #4 hardware is located in the 2-56 organizer, and contains:
The #6 hardware is located in the 6-32 organizer, and contains:
The #8 hardware is located in the 8-32 organizer, and contains:
| Retail Price: | $36.75 |
| Number of cases: | 1 |
| Hardware included: | 0x1/4", 0x3/8", 1x1/4", 1x3/8", 1x1/2", 2x3/8", 2x1/2" |
| Accessories included: | adjustable organizer w/ 18 compartments |
| Manufacturer: | RTL Fasteners |
Available separately from the Master Builder Assortment, the Miniature Wood Screw Assortment contains 350 brass pan Phillips wood screws and an organizer. This assortment has all the hard to find small screws you'll need for almost any job. The Miniature Wood Screw Assortment consists of:
The bonded washers feature a steel washer with a neoprene rubber backing. These little guys provide some vibration dampening and are great for engine mounts and plastic or fiberglass canopies. They also act as lock washers, preventing screws from vibrating out. The come in #4, #6, #8, and #10 sizes.
The assortment is easy to put together, but does take some time; there's alot of hardware to sort through. Start by cutting out each one of the four printed diagrams and taping them to the inside lid of each container. Next, cut apart the plastic dividers that make up the separate compartments. Place the dividers according to the diagrams and fill each compartment with it's respective hardware. If you fill the compartment with the wrong hardware (it can happen after 30 minutes of reading labels and looking for bags) then just use the included magnetic pick-up tool to remove it... assuming it's not aluminum or brass.
The Master Builder Assortment is a must have for any modeler. Whether you're into cars, boats, helis, or airplanes, this diverse assortment of fasteners will keep you out of the hardware store and on the field where you belong. Speaking of the field, the locking cases are perfect for bringing along with you, without worrying about spilling anything.
If you're on the fence about spending money on boxes of nuts and bolts, just think about all the time you've spent sifting through your collection of hardware only to not find what you needed. Or the times you've used the wrong size and "made it fit." Do yourself and your model a favor; make the investment in a quality hardware collection that will last for years.
Pluses
Minuses
| Thread Tools |
Value is subjective. I personally think its worth it to have almost every fastener you would need for building or repairs, labeled and easily accessible, that will last you for years (assuming you arent running an aircraft building service).
Matt |
Latest blog entry: Aerial Mapping UAV
Nice review. Pricey though.
A great alternative is Trimcraft Aviation RC. They have stainless steel fasteners in metric and standard SAE sizes. Lots of other things too. The quality of the fasteners is amazing for the price. For example, twenty-five (25) 4-40 x 3/4" stainless steel socket head are only 50 cents! Their shipping is only $2.99 in the USA for any size order. Check them out. I have purchased just about every socket head (my favorite) fastener they have. I now have a fantastic variety of hard-to-find 2mm and 2-56 sizes, as well as all the larger sizes, washers, blind-nuts, wow. It is terrific to have almost every size on hand. I am not affiliated with Trimcraft, I am just a very satisfied customer, and I wanted to pass on this info to others in the hobby. Service is fast, and Gino is very helpful and responds to emails quickly. Check it out! Nick |
I bought this assortment last year and it's worked out well so far. Could use some more Phillips head screws,but the hex drive is really better as you get no cam outs.
Latest blog entry: 1940 Megow Models Super Quaker
Joined Dec 2011
Years ago, When the babies were babies, I started washing out the little jars and keeping hardware in them.
And then I found a 3 drawer, metal box... each drawer held 24 jars! As I build a model, or touch up finished models (changing servos, or power systems), all the unused hardware or left overs go into a small margarine tub. Every now and then, I spend 20 minutes sorting out the bits and putting them into their proper jars. When I notice I am running low on an item, I take the time to check all the jars, put together a list, and order what I need. The items in my collection very much parallel what the "set" has. |
never thought I would read an entire review on hardware
LOL. This sure would make my life easier; I tend to have 3-4 projects going on at a time and there are always bits of hardware that halt my progress to go to the LHS...very nice.I particularly like those rubber backed washers; perfect for cowls. |
Latest blog entry: Burned Retina Shorts
| Thread Tools | |
| Article ScreamingFoam.com's Super Phoenix TB 10mm ARF Pusher Jet Review | 78dave | High Performance | 64 | Mar 22, 2011 02:02 PM |
| Article Model Airplane Engineering's Jinx, the Evil Twin ARF, The Works Complete Package Style, Review | wahrhaftig | Electric Plane Talk | 6 | Mar 26, 2009 11:02 AM |
| Found Hurry to 3DXhobbies.com for awsome sale on Aifoilz (New Full Fuse)fomies! | KatanaMD | Aircraft - Electric - Micro & Indoor Airplanes | 0 | Oct 03, 2008 11:09 AM |
| Yippee! Sale at 3DXHobbies.com | Cessna 182 | Hot Online Deals | 0 | Jun 14, 2007 06:01 PM |
| 3dxhobbies.com | furyflyer2 | Vendor Talk | 0 | Oct 20, 2005 10:14 PM |
