Old Jul 07, 2010, 05:01 AM
HeavyCruser9 is offline
Find More Posts by HeavyCruser9
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
G'day Gill,
Those 975 motor's look nice what the spec's on them ie: no poles, size,Price!, etc and where can you get them mate?
Cheers from OZ, Bruce
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Old Jul 07, 2010, 08:21 AM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
1st the forward windows are typical on this tug as is the stairs. They also can produce a lowered deck version, but as I was told it is a rare beast. most are sold with the flush deck. Bunks or storage could be installed on ether side of the stairs. The bottom step is just above water line and has a drain. The engine size in this tug was up to the customer and runs from twin 6 cyl. 250 hp to twin 875's
Sorry I listed the wrong number for the motors.
They are 987 Nichibo motors:
18 volt
2.6 amp no load
24,500 rpm @ 18v
7 pole with fan
6mm shaft
51.9mm dia.
69mm can length
102mm o/a length
I will be running these at 6 volts. That will give me 8,166 rpm, I have tried them with the 50mm 5 blade prop. At full speed, under static load (6 volts, prop in water) I had 7,812 rpm and it drew 7.3 amps. The thrust was unreal.
Sorry these motors were samples with in the industry. To buy them they are available in quantities of 1,000 pc.
There are others rated at 12 volts 1@ 13,000 rpm and the 2nd at 3,000 rpm They are the same size and have massive torque.
Shafts arrived yesterday and I hope to install tonight.
GILL RC is offline Find More Posts by GILL RC
Old Jul 07, 2010, 09:28 AM
Adelaide,Australia
Joined Dec 2009
BUGGA !! Oh well I'm thinking of getting a pair of 900's for my 1m big AHST tug (1/72 of course!) or use the pair of geared (5.9:1)pittman's I scored off a mate.
Cheers Bruce
Old Jul 07, 2010, 09:37 AM
toesup is offline
Find More Posts by toesup
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
Originally Posted by Aerominded View Post
Might want to re-think those front windows on the lower cabin... (and stairway from the foredeck to engine room?)
Knowing how push tug's (and Springer's) tend to bury their bow's under the water at anything other than 'slow ahead', having an opening in the fore deck is asking for trouble.
The 'drain' you have, is it overboard?... and a large diameter?
toesup is offline Find More Posts by toesup
Old Jul 07, 2010, 09:46 AM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
I would think so. Heres the spec sheet for this style tug. Right off thier site.
This fully equipped new Truckable Steel Construction Push boat can have an optional cabin with bunk beds, shower, head and sink. She has a 14 foot eye level and two 9 foot Push Knees with Johnson rubber on 1/2 inch plate. work will surpass your expectations.
They are very capable of performing other marine construction of vessels so let us know if you need something else for your fleet including longer work tugs, barges etc.
Price: U.S. $ 320,000.00
DIMENSIONS
Feet
Meters
Length
25'6
7.77
Width
12
3.65
Depth
5
1.527
1.PARTICULARS
Flag US
Year Built NEW CONSTRUCTION
Navigation Perko Running Lights
Location Arkansas
Class No
Construction Hull - 1/4" A36 Steel
Hull in way of Prop 5/15 A36
Super Structure - 3/16" A36
Shipping Weight 44,500 LBS.
Power
Main Engines TWIN
(Standard) John Deere 6081 @ 330 HP Each New
(Options for Standard) Remanufactured CAT 3126 @ 350 t0 385 HP each)
(Additional Cost Options)
Cummins QSL9 @ 405 HP Each Medium Continuous Duty Detroit 60 Series @ 400 HP Each
Transmission (Standard) Twin Disc. 5075SC @ 2.88:1 or equivalent on request
The Larger engines will require different size transmissions Twin Disc. 5095 or ZF 325 with ratios up to 5:1
Propeller Two - 34" 18" Pitch
Shafts 3" Stainless with Cutless Bearings
Helm Manual Hydraulic or Power
Engine Room Stand up/walk around 7' High
Electric 12 Volt System
Winch 2 - Win Tek or BB
Generator No
Fuel Capacity 700 - 850 Gallons
Other Specifications
Deck Anti-Skid
Voids Epoxy painted with 18" access
Rub Rail Schedule 40 Halfpipe
Bulwarks 12" high
Frames 18" spacing
Button Chocks 2
Cabin Size Height: 7'
Width: 6.5'
Length: 7'
Pilot House Size Height: 7'
Width: 4'
Length: 4.5'
Old Jul 07, 2010, 01:29 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Interesting! for very protected waters only then!
Aerominded is offline Find More Posts by Aerominded
Old Jul 07, 2010, 04:12 PM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
The little truckable push tugs are normaly in back bays and rivers.
Old Jul 07, 2010, 08:48 PM
Tugboat Andy is offline
Find More Posts by Tugboat Andy
Joined Apr 2007
Hey Gill. What esc are you using? Build looks great.
Tugboat Andy is offline Find More Posts by Tugboat Andy
Old Jul 07, 2010, 08:59 PM
Joined Feb 2004
emphasis on very!
Old Jul 08, 2010, 10:45 AM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
Well the drive shafts came in yesterday. They are now temp-mounted and run true. The perminate mounting will be when the hull is poly coated. I have also painted and mounted the radio plate. The rudder lay out is finnished. I hope that to night I can start making the rudders and kort nozzels.
I am using 2 PRO-100 POLK ESC's $ 10.00
Rated at 5-9.6 volt 100 amp. DIm: 1x1x5/8 They do have a 10 sec time limit in reverse. if you need more time just go to stop and back down.
I have used these in a number of models. When Polks was closing them out I purchased a couple of boxs of them. There are 15 in a box. Yes I do work for Polks.
Old Jul 09, 2010, 07:50 AM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
Drive shafts are mounted, radio tray is painted, rudders are laid out, and rudder servos are mounted. I did another component layout with the batteries.
2 - 6volt 4 ah gel cells 1 for each motor. 2 - 7.2, 2200ma packs in series for 14.4 volts for lighting, sound, and smoke. The 4 inch speaker will be mounted under the front deck, facing up, the bow will be made into a sound chamber for the speaker.
It's a busy week end so no work on any of the models. Saturday the Mt Olive boat show. Sunday one in Philidelphia.
Old Jul 09, 2010, 11:59 AM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Very tidy installation, looks great!
Kmot is offline Find More Posts by Kmot
Old Jul 09, 2010, 03:32 PM
laser110 is offline
Find More Posts by laser110
Just Limin'
laser110's Avatar
United States, NJ, East Brunswick
Joined Nov 2008
Will we see this one next Sunday at S. Orange?
Scott
laser110 is offline Find More Posts by laser110
Old Jul 09, 2010, 04:13 PM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
No I won't be there next Sunday. But I will have it at the Mt Olive run. I'll be doing the sanding there. Maybe poly coating it too.
Old Jul 13, 2010, 01:42 PM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
I did bring it to the Mt Olive run. Great day, Sat postponed, but Sun was fantastic. The had poly coated the inside the day before. I sanded the conners at the run.
Discussion Tow/push tug GILL RC Scale Boats 4 May 18, 2016 01:37 AM
Help! Tug Propellor(Atlantic Tug) cpd32 Dock Talk 3 Jun 08, 2012 03:08 PM
Discussion Push Tug Build Michael Pardy Scale Boats 7 Oct 17, 2008 01:41 PM
Question Rotor Tug, Regular Ole' Tug, Harbor Tug. What Is A Tractor Tug? boat_builder Dock Talk 45 Apr 17, 2008 07:48 PM
Push-E-Cat to Push-E-Cam L Jenkins Aerial Photography 12 May 09, 2004 10:32 PM
