Old Jul 19, 2012, 05:17 PM
Windependence is offline
Find More Posts by Windependence
The King Moonracer of balsa.
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
Very early on I had given a lot of thought to making my Raven look very similar to that. I even went so far as to test stain vs dye for the coloring. But as my build came along I realized that my woodworking finesse was not up to the standards necessary for that type of finish on the fuselage. So for now the fuselage will be covered and this set of wings will have that translucent white on the open wing areas and something opaque on the sheeted areas. I am going to take what I learned during the poly wing construction and hopefully the gull wing will be up to the standards necessary for a natural wood finish.
Which leads me back to the color quandary. Based on a translucent white open wing area I don't think the fuselage should also be primarily white, too much white. So the fuselage needs some color but what color will work well with a translucent white wing and possibly a natural wood finish wing? Green, black and red seem to be the obvious choices. Thinking outside the standard box, a copperish color might work. Decisions, decisions, decisions.
Wayne
Windependence is offline Find More Posts by Windependence
Old Jul 22, 2012, 05:04 PM
USA, MN, Rochester
Joined Mar 2008
Update
I have made a little more progress on the Raven. I have finished the rudder, mounted the plywood shoulder pieces and bent one of the wing joiners. The wire bender really makes short order of bending 1/4 inch piano wire. I practiced a few times with 1/4 inch aluminum rod and then moved to the strong stuff. I also came to the conclusion that I can make really nice stainless steel tow hooks with it too.
So now I'm getting ready to do some final sanding and then it's on to mounting servos and routing the wing wiring.
Wayne
Old Jul 22, 2012, 06:03 PM
Bob Cook is offline
Find More Posts by Bob Cook
The Lone Blue Plaid Flyer
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Wayne,
That rudder sure looks good. Your coming down the home stretch now.
Bob in Seattle
Bob Cook is offline Find More Posts by Bob Cook
Old Aug 15, 2012, 04:41 PM
USA, MN, Rochester
Joined Mar 2008
Hello Everyone,
Just a quick update on the Raven build. I took a little break from the Raven to complete some repairs on another plane I have. My ALES plane, a 2 meter Pulsar, went into a bean field last year and has been needing a few repairs. I have those repairs all completed now so I have time to once again get back to the Raven build. I have mounted the servos and battery and connected the elevator linkages. Next it is on to the pull pull rudder linkage and last but not least the spoiler setup. I'm slowly getting there.
I also have just received delivery of my new OneWinch. I plan on using this to launch the Raven and all my other string launch planes. I had an opportunity to try one a few months ago and I really liked it. No pictures for the moment but I will keep updating the thread with my progress.
Wayne
Old Aug 15, 2012, 11:09 PM
Captain Canardly is offline
Find More Posts by Captain Canardly
who has rabbit ears down
Captain Canardly's Avatar
United States, MN, Buffalo
Joined Jan 2007
Go Wayne Go!
Stay on target Stay on Target--
Captain Canardly is offline Find More Posts by Captain Canardly
Latest blog entry: Have a laugh on me!
Old Oct 08, 2012, 09:58 PM
USA, MN, Rochester
Joined Mar 2008
Raven update
Final fuselage sanding is complete, servos are in, rudder hinges are in and the rudder horn has been epoxied in place. Covering has been purchased and is sitting on the shop workbench. I still need to glue the tow hook reinforcement plate in place but that is easy. Covering on the fuselage will commence this week starting with the rudder.
I am still waiting on one half of the multiplex connectors for the wing wiring connections, back-ordered, and I still need to pick up a tow hook. I am going to rework the wing tips a little more as I want them to look a little different. Nothing major, just a little bit more tapered out at the tip. Then it will be on to running the spoiler servo wires into the wing and some wing covering. The only thing remaining on the poly wing is making spoiler covers. No predictions on a maiden flight day but it is getting close now. I have the battery and Rx already to go. It is finally coming together and I am already looking forward to the gull wing build.
Wayne
Old Oct 08, 2012, 10:08 PM
Joined Jan 2007
Glad to hear that life got itself in order! I can't wait for another belly laughin' session!
Johnny
Old Oct 09, 2012, 07:12 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Go Wayne Go !!!!
Bob in Seattle
Old Oct 09, 2012, 07:22 PM
USA, MN, Rochester
Joined Mar 2008
I am going to get an outdoor picture of it fully assembled before I start covering it. Tonight was rainy so I couldn't do it, tomorrow looks promising so hopefully right after work I can get some pictures. Then its on to the covering.
Wayne
Old Oct 23, 2012, 10:06 AM
USA, MN, Rochester
Joined Mar 2008
Well the covering is going on and each day sees a little progress. Covering the Raven fuselage has proven to be a little tricky. All those nice curved lines makes for some difficult covering situations. I am getting through it but if I were to do it again I would give some more thought to painting it. Maybe next time. My multiplex connectors finally came in after being back ordered so now I can also work on wiring up the spoiler servos. I installed the plywood tow hook reinforcement plate but I am going to hold off on drilling the tow hook hole until after final assembly. No need to have a lot of extra holes in the fuselage.
I am going to finish covering the fuselage then it is onto the wings. Those should be a lot easier to cover.
Wayne
Old Oct 23, 2012, 07:27 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Go man Go..........
Bob in Seattle
Old Oct 24, 2012, 08:52 AM
dwells is offline
Find More Posts by dwells
≡LSF8067≡
dwells's Avatar
Bedford, TX
Joined Oct 2007
Wayne
Hi Wayne,
Yup, that beautiful curvy fuse looks like some fun covering challenges. What kind of film are you using? I think from now on I'm going with painted fuses as well. It took me 3 evenings just to get the nose on my O3 recovered without any wrinkles. Lots of pulling and stretching and cussing .
Don
dwells is offline Find More Posts by dwells
Old Oct 24, 2012, 11:19 AM
USA, MN, Rochester
Joined Mar 2008
Hi Don,
Thanks for staying tuned through my long build. I decided to use Ultracote lite on the fuselage. It is more stretchy than Monokote and it seems to handle the compound curves well but it is a lot of work. We'll see how well it holds up over time to the grass landings around here. How have things been progressing with your Oly III repairs?
Wayne
Old Oct 24, 2012, 01:25 PM
dwells is offline
≡LSF8067≡
dwells's Avatar
Bedford, TX
Joined Oct 2007
Hi Don,
Wayne
I understand the long build, no harm no foul in my eyes, the Raven is looking great and should be an awsome plane with all your detail work.
MonoKote is all I've ever used and it's a bear on the compounds. I do like the super glossy finish though of a filmed fuse but it just takes too much time. Maybe I'll try Ultracote on a fuse before I proclaim painting as the way to go.
Slow go on the Oly, the wings were completely destroyed so I'm laying up the inner panels at this time....again . The fuse and feathers are good to go though. All the gear seems to be in good order and function like new.....well....they are new with total air time of about 15 minutes .
Old Oct 24, 2012, 03:18 PM
SHVentus is offline
Find More Posts by SHVentus
Hawaii
Joined Feb 2009
Don,
Are you going with flaps or spoilers on yout O3?
SHVentus is offline Find More Posts by SHVentus
Discussion "Official" BH/LX B-2 Stealth "Spirit" 2x64mm EDF, Build/Mods Thread! RemE Foamy EDFs 1528 Yesterday 07:30 PM
Rave Official HK250 and HK250GT Thread (with build log and review at start) Hal_The_Hacker Micro Helis 9755 Nov 21, 2015 11:40 AM
Build Log Golden Age Modelworks RYAN ST-A Official Build Thread wingspan100 Parkflyers 231 Oct 22, 2014 04:43 PM
Build Log VERTIGO B-26 "Widow Maker" Official Build Thread AirShowRC.com wingspan100 Electric Warbirds 129 Feb 25, 2014 06:01 AM
Discussion ***OFFICIAL*** Gee Bee R3 Build Thread appflyer Scale ARF/RTF 28 Dec 04, 2009 11:57 PM
