Old Feb 26, 2012, 01:13 PM
Bob Cook is offline
Find More Posts by Bob Cook
The Lone Blue Plaid Flyer
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
I am now gluing the boom to the pylon section. This is really scarry stuff. If I have forgotten anything, it's to late now. See photos. Now the wait for the epoxy to dry. Stay tuned.
Bob in Seattle
Bob Cook is offline Find More Posts by Bob Cook
Old Feb 26, 2012, 03:36 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
I'm now gluing the push rods through the pylon area. I have a stick holding the rod against the side of the fuse. See photo. The one you can see is not the one that is being glued. I mixed up some 15 minurte epoxy and covered a 2 inch area. See photo. Once we are past this area, it will be smooth sailing on into the pod area. Stay tuned.
Bob in Seattle
Old Feb 26, 2012, 06:09 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
I got the speed control soldered in and located. See photo. The motor turns the right way. I checked first. Now I have to glue the other push rod, on the other side. Stat tuned.
Bob in Seattle
Old Feb 26, 2012, 06:52 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
I got the other push rod epoxied into place. That about does it for today. Foxy says it's time for salmon and Pinot Gris. Stay tuned.
Bob in Seattle
Old Mar 03, 2012, 01:32 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
I'm all fired up and going strong after some C4 Krank. Todays challenge is to figure out how to get all these wires stuffed into the fuse and still have room for the battery. See photo. This is going to be a trile and error process. Stay tuned.
Bob in Seattle
Old Mar 03, 2012, 02:41 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
I tied up some of the wires and got the wing wires out the top of the pylon. See photo. The battery isn't going as far back as it needs to go for the CG to work out. See photo. This means that I will have to add some lead to the tail. I'm going to do a wt & bal now and try and see how much I'll have to add. I'll let you know. Stay tuned.
Bob in Seattle
Old Mar 03, 2012, 03:51 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
After setting up the ballencer on the dinning room table, it looks like I'll need just under 3/4 of an oz of lead. See photos. Considering the total weight of the plane, that's not very much.
Stay tuned.
Bob in Seattle
Old Mar 03, 2012, 06:03 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
I'm going to epoxy the last section of the fuse together. See photo. If I have forgotten anything, it's going to be to late now. Stay tuned.
Bob in Seattle
Old Mar 03, 2012, 08:35 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
Foxy says, it's time for salmon and Pinot Gris. See you in the morning.
Bob in Seattle
Old Mar 03, 2012, 09:37 PM
Windependence is offline
Find More Posts by Windependence
The King Moonracer of balsa.
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
Hi Bob,
Looking good indeed. I really like the fully assembled pictures. Do you have a ball park weight of your finished plane? Curious minds want to know. The plans call for a finished flying weight right around 64 oz.
Wayne
Windependence is offline Find More Posts by Windependence
Old Mar 03, 2012, 09:39 PM
doc993 is offline
Find More Posts by doc993
doc993's Avatar
United States, WI, Stoddard
Joined Dec 2009
Awesome job Bob! Wayne will get a lot of inspiration from those pics.
doc993 is offline Find More Posts by doc993
Old Mar 04, 2012, 03:13 AM
tinkrerpilot is offline
Find More Posts by tinkrerpilot
tinkrerpilot's Avatar
Puyallup, WA
Joined Nov 2001
Hey Bob,
Checking in with you guys. Looking very nice. Looking forward to first flight on this one.
tinkrerpilot is offline Find More Posts by tinkrerpilot
Old Mar 04, 2012, 08:51 AM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Wayne,
I weighed everything this morning and it came up to 58 oz. , NOT counting the battery. I think it came out that way because I used the C/F fuse.
Thanks Doc, I'm going to hook up the push rods today and start doing control throws.
Good to hear from you Lyle. I WILL have more than one photographer shooting pics when the maiden happens. Stay tuned.
Bob in Seattle
Old Mar 04, 2012, 06:05 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
I've been doing control throws. I leveled the fuse. I got out my Robarts meter and got the stab set at zero. See photo. I found that the rudder only has 24 MM of throw. I need 30 MM. See photo. I'm going to move the clevis inboard and see if it helps. Stay tuuned. Can't up load the photos. I'll try later.
Bob in Seattle
Old Mar 04, 2012, 06:31 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
I moved it in about 1/8 of an inch. That did it. I've got 30 MM of throw now. Don't know wht I can't up load photos. I'll try again. Stay tuned. Still not working for me. I get error #500 message.
Bob in Seattle
Discussion "Official" BH/LX B-2 Stealth "Spirit" 2x64mm EDF, Build/Mods Thread! RemE Foamy EDFs 1553 Sep 07, 2016 11:12 PM
Rave Official HK250 and HK250GT Thread (with build log and review at start) Hal_The_Hacker Micro Helis 9757 Aug 29, 2016 02:20 PM
Build Log Golden Age Modelworks RYAN ST-A Official Build Thread wingspan100 Parkflyers 231 Oct 22, 2014 04:43 PM
Build Log VERTIGO B-26 "Widow Maker" Official Build Thread AirShowRC.com wingspan100 Electric Warbirds 129 Feb 25, 2014 06:01 AM
Discussion ***OFFICIAL*** Gee Bee R3 Build Thread appflyer Scale ARF/RTF 28 Dec 04, 2009 11:57 PM
