Jul 28, 2011, 10:03 PM
USA, MN, Rochester
Joined Mar 2008
Two steps forward, one step back
I have been continuing to work on the fuselage. I spent a fair amount of time getting the 1/4 inch sheet on the forward, bottom section of the fuselage. The fuselage doesn't look too curvy until you try to attach some 1/4 inch sheet too it. Boiling water, clamps and time were what it took to get it on there. I have also attached the nose block and the top sheeting forward of the hatch area.
I was very proud of myself. I did the initial rough shaping of the nose and then started to get ready to put on the remaining bottom sheeting, ohh but what did I see.... a fuselage that was not straight. Somehow when I was attaching and clamping the bottom sheeting I got something out of alignment. No amount of persuasion was enough to get the fuselage lined back up. So out came the knife, off came the bottom sheeting and I will try it again. This time I am not going to try to do it in one piece, but will instead sheet it in pieces placed on the fuselage at 90 degrees. The sheet material is naturally more forgiving in that orientation anyway when it comes to following the curves.
I will report back when I get the new bottom sheeting on.
Wayne
