Old Jul 23, 2010, 01:22 PM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Airfoil Selection?
Based on Mike Smart's recollection that the airfoil was probably an E-193, and not being familiar with that foil, I started doing a little Internet research on it. My thought was that since the plane does not qualify for NOS, the laser cutter will make the ribs with any foil section we choose, and a lot has happened in the understanding of TD plane wing design since the 1980's when Mike selected the E-193, would there be a better shape to use now?
From what I have read, it is relatively simple to select the top 5 or so choices based upon the intended performance envelope, but after that it is person preference defended by a great deal of ego.
If the build group is interested and since we will not be sending out the rib cutting instructions for a little while, can we have a discussion about the relative merits of building original versus using a different foil section? We probably all have very different flying conditions and building experience and therefore different needs, and the price break on the laser cutting probably applies to having all the sets cut to the same foil, so if this idea is too far out, I understand. However, since we all will be investing considerable resources in the build, I thought the idea is at least worthy of discussion. Perhaps Mike can offer his opinion about which one he would use now with the perspective of 25+ years.
Other candidates for foils could be a Clark Y, MH 32, S 3014 (a favorite of Skybench Aero's Ray Hayes) and the familiar SD 7037. A bit more complex build could use Mark Drela's combinations of AG series used on the Allegro and Bubble Dancer http://www.charlesriverrc.org/articl...t-airfoils.htm. I offer this link http://www.gliders.dk/clark_y.htm as an interesting reference source for one person's opinion regarding a few comparisons.
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Jul 23, 2010, 02:43 PM
Windependence is offline
Find More Posts by Windependence
Quando Omni Flunkus Moritati
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
Hi FC,
I asked Mike this same question in an email earlier this year. I believe I said something like, "If you were to design the Raven 3M today what airfoil would you use?" his reply to me was that he really liked the overall performance of the original airfoil but..... that he may use the SD 7037 today.
Now that being said I will state that, without a doubt, I am the last person in the world you want to get airfoil advise from. Any airfoil will have its pluses and minuses. Perhaps the more knowledgeable members out there can offer us some insight. The design specs are listed earlier in this thread so, given that information, let the airfoil discussion/debate/argument begin. My only opinion is this, the Drela airfoils are very fine airfoils but I think they may add significant complexity to the build. Carbon caps, kevlar wraps and solid shear webs seem the norm when they are used. That level of complexity may push some builders away from the project.
Wayne
Windependence is offline Find More Posts by Windependence
Old Jul 23, 2010, 03:23 PM
KickAce is offline
Find More Posts by KickAce
KickAce's Avatar
Watertown, WI 53098
Joined Aug 2007
Originally Posted by Windependence View Post
Hi FC,
Wayne
I'd go with the original, but that is me...
I'd say let the ones that would like a different airfoil to make them on their own... But hey, that is me and will have to live with what ever you all argue about... I've hear/seen arguments over airfoils before and will look away until I get notified as to when to send in the funds for the order... The rest of you enjoy the debate...
KickAce is offline Find More Posts by KickAce
Old Jul 23, 2010, 03:28 PM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
I would probably use the SD 7037 or MH-32, I'm not a fan of the Clark Y. However, I believe the SD 7037 & MH-32 work best with camber changing flaps & ailerons, so flap-less the E193 may still be a reasonable performer.
Mike Smart is offline Find More Posts by Mike Smart
Old Jul 23, 2010, 05:41 PM
USA, MN, Rochester
Joined Mar 2008
Ah... Mike brings up an interesting point. The newer airfoils are designed with camber changing in mind. So here is a question for all of us to ponder. If I am not going to ever implement flight modes, what are the benefits of the newer airfoils? It is one thing to deploy flaps for landing purposes, it is quite another to configure trailing edge settings for thermal, launch, and cruise.
I'm not taking sides here just asking the question.
Wayne
Old Jul 23, 2010, 11:04 PM
alstrahm is offline
Find More Posts by alstrahm
AMA 3959
alstrahm's Avatar
United States, CA, San Jose
Joined Oct 2002
I am leaning toward getting in on this build as you guys are getting the balsa dust in my old veins going. Now as far as airfoils, hhmm, I think it has to do with how you are going to build the Raven, I currently fly a Sagitta 900 in woodie class with like, I belive an eppler foil, on it works great. I also have an Artemis moldie with the 7037 and it really works great due to the camber adjustments I can make. So basically I guess I am saying the airfoil best to use is how you are going to build it, I am leaning toward the gull wing RES version so the stock airfoil would work for me. But anybody thinking of a full house version would want the 7037. just my 2 cents worth.
Al
p.s were do I get the plans? Mike? OHH no I may be hooked
alstrahm is offline Find More Posts by alstrahm
Old Jul 24, 2010, 12:23 AM
USA, MN, Rochester
Joined Mar 2008
So let's try this, I will contact Bob and ask him to contact Tony, the laser cutter guy, with this request. Would it be possible to have a choice of laser cut airfoils for this plane? Either the original one or one suited for full house camber. The worst he can say is "no", the best he can say is "no problem builders choice"
Lets give some discussion to what the second airfoil option should be. It may be fun to have both airfoils and make two sets of wings, one for full house and a second poly wing for RES, both fitted to the same fuselage.
Wayne
Old Jul 24, 2010, 05:50 AM
Mike Smart's Avatar
Joined Jan 2000
Al
PM sent,
Old Jul 24, 2010, 10:22 AM
rabidrue1 is offline
Find More Posts by rabidrue1
Blueplaidcanard flyer
sdy. ny
Joined May 2007
Except for sticking a motor in the nose I think I'll just build it stock.If I had room to set up the highstart I might even skip the motor.
rabidrue1 is offline Find More Posts by rabidrue1
Old Jul 24, 2010, 10:38 AM
mhodgson is offline
Find More Posts by mhodgson
mhodgson's Avatar
UK, Coventry
Joined Aug 2005
You could look at the SD6080. I had a 100s model with it that flew a treat. One desciption I heard for it was 'like an updated E193', which is why I chose it. On an unflapped wing I would definitely consider it again.
Martin H
mhodgson is offline Find More Posts by mhodgson
Old Jul 24, 2010, 10:53 AM
KickAce is offline
KickAce's Avatar
Watertown, WI 53098
Joined Aug 2007
Plans Arrived...
The plans arrived...
Total cost was $17.19 US Dollars...
Comes with an Instruction Manual... (5 pages - text only - no pictures)
There is also an option on the plans for Foam Wing Construction...
KA
Old Jul 24, 2010, 11:36 AM
Bob Cook is offline
Find More Posts by Bob Cook
The Lone Blue Plaid Flyer
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
I'll get a hold of Tony the lazer guy, and ask him about doing the wing in other air foils. I tend to think he will do it but there may be some charge for that. The program he has now in his computer, is for a D box sheeting only on the wing. If your going to do something other than D box sheeting you need to tell him so he can change the program. I'll write him and let you know what he says.
Bob in Seattle
Bob Cook is offline Find More Posts by Bob Cook
Old Jul 24, 2010, 05:16 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Guys,
I wrote Tony and will let you know as soon as I hear from him. He does travel and so there might be a bit of a time lag.
Bob in Seattle
Old Jul 24, 2010, 05:23 PM
USA, MN, Rochester
Joined Mar 2008
Hi Bob, Thanks for getting in contact with Tony about this. It never hurts to ask.
Wayne
Old Jul 24, 2010, 05:30 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
I really don't think it will be a problem, as long as folks are willing to pay for his service. If I ever build one of my own design, I'll have him do the ribs for it. It's a small price to pay for accuracy where it's really needed.
Bob in Seattle
Discussion "Official" BH/LX B-2 Stealth "Spirit" 2x64mm EDF, Build/Mods Thread! RemE Foamy EDFs 1453 Feb 01, 2016 12:26 PM
Rave Official HK250 and HK250GT Thread (with build log and review at start) Hal_The_Hacker Micro Helis 9755 Nov 21, 2015 12:40 PM
Build Log Golden Age Modelworks RYAN ST-A Official Build Thread wingspan100 Parkflyers 231 Oct 22, 2014 05:43 PM
Build Log VERTIGO B-26 "Widow Maker" Official Build Thread AirShowRC.com wingspan100 Electric Warbirds 129 Feb 25, 2014 07:01 AM
Discussion ***OFFICIAL*** Gee Bee R3 Build Thread appflyer Scale ARF/RTF 28 Dec 05, 2009 12:57 AM
