Old Jul 04, 2010, 03:57 PM
Windependence is offline
Find More Posts by Windependence
The King Moonracer of balsa.
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
Build Log
The Official Raven 3M build thread has begun.
Welcome, this thread will be a build log and discussion area for the Raven 3M, a 3 meter TD plane designed by Mike Smart. Starting this October I, and some of you, will be building this wonderful woodie. I am starting the thread now because I have been getting questions about the plane in other threads and I want to get the information in one central location. I am certainly not the first person to build one of these and if you look around RCGroups you can find a couple of build threads that were started but never finished.
So what is a Raven 3M? Well in this case it is the largest in a family of TD planes created by the English designer, Mike Smart, during the 1980's. The Raven 3m is also the newest in the series and has the most build variations. It is only available as plans so this will be a scratch build. A unique design aspect of this plane is that Mike has included different wing options to suite most any flyer. It can be built with the gull wing as a aileron, elevator, rudder, pictured below, or it can be built with straight dihedral wings for ailerons, elevator, rudder, or it can be built with poly-dihedral for rudder, elevator, spoiler. Flaps can easily be added to any of the optional wings styles if so desired. Additionally it can be built with a foam core, balsa sheeted wing. You bagged wing guys could very easily bag this wing with FG or carbon. Multiple wing sets can be used with the same fuselage giving you many flying options.
I have had the opportunity to talk with Mike, via email, and he is planning to join this thread to answer any build or technical question that might arise. As of now there are three of us planning to build it this fall/winter. I am certain that the other builders will chime in here as soon as they see the thread. I am planning to build mine as a traditional glider and at least one of the builders is going to electrify his. I am planning to build the wing using carbon to cap the spar to make it a little stronger to better withstand those winch launches. It can still be flown as a woodie this way. This plane does not qualify for NOS events as it was designed in 1986.
I will do my best to answer any questions that arise and any that I cannot answer can be fielded by Mike. I hope some of you will join us in building it this fall and please feel free to ask questions. I have included a couple of pictures so you can see what it looks like.
Wayne
Windependence is offline Find More Posts by Windependence
Old Jul 04, 2010, 04:01 PM
USA, MN, Rochester
Joined Mar 2008
Reserved for links and pictures of completed builds
Laser cut rib sets are available for the 3 meter Raven from Aero-Werkes. The price, as of summer 2012 is $35. Contact Dave for for details and ordering information.
email = DPCMODELS@aol.com
Website = www.aerowerkes.com
Additional information about the Raven:
Mike Smart designs website: here
Article in the August 1990 RC Soaring Digest magazine: here
Previous Raven 3M threads:
Current list of people participating in the build:
  • Windependence
  • Bob
  • Foam Crusher
  • Rabidrue1
  • KickAce
  • BDOG1
  • 3SportBob
The actual build starts on page 15
Old Jul 05, 2010, 10:24 AM
Bob Cook is offline
Find More Posts by Bob Cook
The Lone Blue Plaid Flyer
Bob Cook's Avatar
Seattle
Joined Jan 2003
Thank you Wayne, for kicking off the offical thread on this fun project. I have a list of materials that is fairly complete for the fuse and wing. I'm going with the D box version, and the Gull wing option. I also have a source for laser cut ribs, if any of you need them. I certainly do. Mine will be electric of course.
Bob in Seattle
Bob Cook is offline Find More Posts by Bob Cook
Old Jul 06, 2010, 08:49 AM
USA, MN, Rochester
Joined Mar 2008
Hi Bob,
Thanks for mentioning the materials list. Bob and I are going to be putting together a material list for the build. This should make things easier for any of you who decide to take on this build. Once we get it put together I will post it as a pdf flie. As Bob has already mentioned, we do have a source for laser cut ribs for the wing and tail. Bob has already ordered and received a set so he can comment on the details. I saw a picture of them and they do look very nice. The person doing the laser cutting was familiar with the plane and that is always a nice plus.
I will also be updating post #2 with links to sources for the various materials needed. Some of you have nice fully stocked local hobby shops but some of you do not so Bob and I will be doing the leg work finding online sources for materials.
Wayne
Old Jul 06, 2010, 10:01 AM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
I appear to be the third person doing the build. The plans arrived Friday (only 3 days from England!) and using Bob's preliminary materials list I am going over the plan and my wood pile to see what I need to order.
Mine will be an aileron gull-wing electric, probably with a fully sheeted wing since I have not built one of those before. It is windy here most of the summer flying season, so a little extra weight in place of ballast is fine. Power will be from a 400W in-runner with a planetary gearbox turning a 16 x8 folder powered by 3S2P 2100 mAh twinned 2100 20C lipos. I have a similar set up in an Oly 3 at about the same AUW that gives 45 degree or better climb outs to winch height in under 30 seconds, so it makes for a nice sport plane.
An October start works great for me as we have just moved and I need some time to get my shop put together.
Now for what will probably be the first of many questions: The plan shows flaps but does not mention spoilers. I have both on the Oly3 and wonder about the need/desirability of adding them. Comments?
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Jul 06, 2010, 10:45 AM
USA, MN, Rochester
Joined Mar 2008
Hi FC,
Thanks for stopping in. I believe we are up to 4 builders now. Rabidrue1 is in for the build also. As to your spoiler and flap question, I would think that one or the other would be sufficient to give you glide path control. In my "opinion" I would think that flaps would slow down the plane better than spoilers would and that might make those less than perfect landings a little more forgiving.
Wayne
Old Jul 06, 2010, 11:25 AM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi Steve,
Glad you got the wood list. It's only a partial list. I'm going with an electric set up too. I like spoilers a lot. I haven't had good luck with flaps. I'm just going to build them into the wing. I'm going with the gull wing. Mine will be D box sheeted only. I had the laser guy cut my ribs for that option. Power wise, I'm just going with an outrunner, 2820/ 12, 40 amp speed control, and a 12/6 prop. A 3S 2200 LiPo. This is my usual basic power line up. This is similar to my Riser 112. The color scheam will be the hard part.
Bob in Seattle
Old Jul 06, 2010, 02:06 PM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
DT56 is offline Find More Posts by DT56
Old Jul 06, 2010, 02:13 PM
alstrahm is offline
Find More Posts by alstrahm
AMA 3959
alstrahm's Avatar
United States, CA, San Jose
Joined Oct 2002
Kool, this should be a fun build, Bob how much to get the ribs cut?
alstrahm is offline Find More Posts by alstrahm
Old Jul 06, 2010, 03:11 PM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Subscribed Out of interest, I found the plans to the wooden predecessor of the middle Raven in the picture of 3 above, which is the Raven SC20. This had a GRP fuselage and foam wings, but the prototype was all wood construction. I have had these scanned and plan to trace them in CAD so I can offer an alternative Raven 2m plan.
Mike Smart is offline Find More Posts by Mike Smart
Old Jul 06, 2010, 08:43 PM
USA, MN, Rochester
Joined Mar 2008
Hi Mike,
Thanks for stopping in. If my introduction in post 1 is inaccurate please let me know. As to the SC20, was it designed and/or kitted prior to Jan 1, 1980? If so it would qualify as a nostalgia class plane and those nostalgia guys are always looking for new designs. Foam and fiberglass are allowed in nostalgia
Wayne
Old Jul 07, 2010, 06:22 AM
rabidrue1 is offline
Find More Posts by rabidrue1
Blueplaidcanard flyer
sdy. ny
Joined May 2007
I have to get a new bandsaw blade then get the wood on the way,so an October start sounds like a winner.I'm not a contest type so I have no need to spot land the bird and I might just pass on spoilers or flaps and save an once or so.
rabidrue1 is offline Find More Posts by rabidrue1
Old Jul 07, 2010, 08:05 AM
Mike Smart's Avatar
Joined Jan 2000
Originally Posted by Windependence View Post
Hi Mike,
Wayne
Wayne, your introduction is fine thanks. The SC20 was designed/kitted after that date, around 87/88 I think.
However the Raven 76m was designed and published as a plan in 1976. I will post a picture later if I can find one.
Old Jul 07, 2010, 09:12 AM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi alstrahm.
They are about $70, and worth every penny of it. But you need to tell him if your going to do full sheeting or D box only. His program now is for D box only.
Bob in Seattle
Old Jul 07, 2010, 12:33 PM
USA, MN, Rochester
Joined Mar 2008
Hi Bob,
Do you think that Tony might be open to lowering his price for the laser cutting if we placed a group order for the ribs? We could wait until late summer and anybody who wants ribs cut could all order at the same time similar to the Chrysalis group build kit purchases. What do you think? Would you be willing ask him?
Wayne
Discussion "Official" BH/LX B-2 Stealth "Spirit" 2x64mm EDF, Build/Mods Thread! RemE Foamy EDFs 1484 Apr 13, 2016 12:00 AM
Rave Official HK250 and HK250GT Thread (with build log and review at start) Hal_The_Hacker Micro Helis 9755 Nov 21, 2015 11:40 AM
Build Log Golden Age Modelworks RYAN ST-A Official Build Thread wingspan100 Parkflyers 231 Oct 22, 2014 04:43 PM
Build Log VERTIGO B-26 "Widow Maker" Official Build Thread AirShowRC.com wingspan100 Electric Warbirds 129 Feb 25, 2014 06:01 AM
Discussion ***OFFICIAL*** Gee Bee R3 Build Thread appflyer Scale ARF/RTF 28 Dec 04, 2009 11:57 PM
