Okay, this sounds really odd, but I use the glue stick method (there's a new one out that's labeled post-it, works GREAT and no residue) I roughly cut out around the paper part you want (on a copy, not the original)....then I put a little glue stick on the back of it and stick it to a piece of balsa. Next I head down to my disk sander and sand away all the excess....usually makes for near perfect parts so far. But witht eh glue stick, the paper sands away as well, so just sand it how you want, peel off the paper, and voila! If I'm cutting out 2 or more of the same part, I'll use tiny pieces of double sided tape (very tiny, 1/4" wide) to hold a stack of balsa together and have a paper template on th every top. This method still hasn't let me down....
Missouri
Joined Jul 2002
This is not exactly the process you were asking about, but it is one I have used long before we had access to copiers and printers in our homes.
I just lay the item on the plan that I want to transfer over the wood. Using straight pin I poke holes thru the wood of the outline. Then just play connect the dots with the hobby knife. On curves the holes are spaced closely and on straight lines I just put one on each end and use a straight edge. Since I have been doing it this way for so long it seems like I can outline a part quicker this way than going thru the copying process. Of course it's best to make one copy of the plan. One to build on and the other to outline parts with. Dale |
I trace mine by putting plain printer paper over the plan and tracing it through. If its a plane I may want to make more than one of I then cut the paper out and trace it to thin poster board so I have some good stiff templates that I can fold and put in a folder file and file in my box of plans.
heres how i did it...
Take an old pen, with no ink if you can find one and lay the plan over the wood, than, useing medum pressure, press down int he pen and trace the out line onto the wood, after youhave traced the out line, take the paper off the wood and you will dee a dented out line, fill in this outline with a good pen and cut it out, easy and works suprbe for me. Thomas |
Some more very good ideas!
genebond; I thought about the full sheet size lables but thought they would stick too much. Still a good idea for small parts and we are talking parkflyers here. calmair; I have used this method with the pins on a limited basis. Works very well with straight lines. Thanks guys. I think this should keep me busy and out of trouble! John WBR |
Alberta, Canada
Joined Sep 2001
For the 3m-77 spraymount spray, spray it on the paper, let the paper "dry" then apply to the wood to cut. Leaves no or virtually no glue on the wood. This glue dries to a sticky note consistency. Use the spray sparingly.
This is still more work than the ironing method although with good, thin wood I've had problems with the head causing warps and the images not transferring quite right. |
| Thread Tools | |
| Advice wanted on building airplanes from plans | engineer | The Builders Workshop | 3 | Dec 16, 2004 02:01 PM |
| How to transfer plans to wood? | War Bird Radio | The Builders Workshop | 5 | Jun 26, 2003 02:38 PM |
| Building from plans - Best way to transfer? | Phoenix-IT | Electric Plane Talk | 8 | Mar 10, 2003 12:02 AM |
| building from plans | jester_ao | Electric Plane Talk | 18 | Oct 06, 2002 09:11 PM |
