Old Jun 19, 2003, 08:15 PM
AirChopper is offline
Find More Posts by AirChopper
Joined Feb 2003
15L & Phoenix 10 programming question
Hey guys,
Heres my setup:
9.1 Cutoff voltage = 4v
9.2 Current limiting = disabled
9.3 Brake type = disabled
9.4 Throttle type = Govoner mode (low rpm)
9.5 Electronic timing advance =5-10 deg
9.6 Cutoff type = Soft cutoff
When I bring the rpms up it tends to "hunt" up and down and doesn't really give any power. Before I setup the esc I spooled the heli up and it was very powerful, what I expect from a 15L.
AirChopper is offline Find More Posts by AirChopper
Old Jun 20, 2003, 01:07 AM
skirtz is offline
Find More Posts by skirtz
Joined Sep 2002
You may have the old version firmware. Bump your throttle ATV to 140% and try bumping up your throttle curve until desired head speed. I have one of the earlier versions and even at 140 the power is not there. You may send it to CC for software upgrade.
skirtz is offline Find More Posts by skirtz
Old Jun 20, 2003, 01:57 PM
Joined Feb 2003
I tried upping the ATV to 140 and still seems about the same. Only things I can think of is to take it out of govoner mode and try messing with the timing....otherwise I guess it'll have to go back to cc
Old Jun 20, 2003, 07:51 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
Why do you have your governor mode in low rpm?
Toshi
TMorita is offline Find More Posts by TMorita
Old Jun 20, 2003, 08:23 PM
Joined Feb 2003
They say it holds RPM better...maybe I should go into high?
Old Jun 21, 2003, 03:26 AM
TMorita is offline
Joined May 2002
The low RPM governor mode is for when you're running mostly at low throttle. It has more "steps" at low throttle so you have better control over the motor speed.
For a helicopter, you should be running the motor mostly at a high RPM, so the high RPM governor mode should be more appropriate.
Toshi
Tsunami 10 programming question wildpalms Power Systems 0 Feb 21, 2004 05:57 AM
PHoenix 10 and Programming aplphabandaid Castle Creations 3 Feb 13, 2004 06:00 PM
Corsair w/Phoenix 10 TP2100 Question Bonez Parkflyers 6 Jan 03, 2004 07:17 PM
Phoenix 45 programming question tigroot Castle Creations 1 Sep 24, 2003 10:35 AM
Phoenix 10 programming petn7 Micro Helis 1 Dec 26, 2002 01:41 PM
