Jul 05, 2010, 09:40 PM
New Bedford, Ma. USA
Joined May 2001
The pulse I've seen used as a second plane but landing is a little nerve wracking for someone not used to it, If you do really well with the trainer you may do fine but you will have to be on your toes a little more and you'll have a bit more of the pucker factor. With the pulse just keep your throws lower and it won't get too out of control but when you get bored with that crank the throws up some and that plane will really tear up the sky. So if your uneasy I would go with the 4-star BUT if your doing really well and are bored with the trainer then the Pulse might be just the plane to move up to. As for the Extra, NOT a good idea even if it says semi symmetrical airfoil. That is a serious acrobatic aircraft and won't have a long life in the hands of a newer pilot. A third plane it should be ok and will help you move up in skills. But like I said if your doing well, then the Pulse may be a great second plane that will last a bit longer on getting your skills up than some of the other great 2nd planes. It's all up to you and your flying skills.
Dauntae
