Old Jul 03, 2010, 05:55 PM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
United States, OH, Cleveland
Joined Dec 2006
Build Log
Cox Corsair with AR6400L 3d receiver and dual Aileron L servos with Video
I decided to finally build this plane. It will be with a AR6400L receiver and will be as light weight as possible. I already did a P-47 with a AR6400 and that worked well and now I will be trying the AR6400L. The AR6400L is a long throw version of the AR6400 and the one I'm using comes from a UM 4-Site. The UM 4-site is still in 1 piece but I will soon be removing its radio gear for this plane.
Edit..I will install a AR6400L with dual AS2000L aileron servos and it will the first Cox plane with this setup but first I'm gonna try a few other things I have been wanting to try to see if there is an equivalent setup in weight and price to the AR6400L. The AR6400L is back-ordered at this time so you can't buy it just now so the only way to get one is from a 4-Site.
edit... The AR6400L finally gets installed here http://www.rcgroups.com/forums/showp...6&postcount=51
Flight video added 7-22-10 http://www.rcgroups.com/forums/showp...7&postcount=72
modfly is offline Find More Posts by modfly
Old Jul 03, 2010, 07:08 PM
56S is online now
56S
Find More Posts by 56S
56S
Certified Balsa Breaker
56S's Avatar
Joined Nov 2006
Are you using the 10gr 1811?
56S is online now Find More Posts by 56S
Old Jul 03, 2010, 09:24 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
I think so. I also have the 5 gram HK BL motor and I'm thinking about it. I know what your thinking, 5g motor is not enough but if the plane is light enough it will work. I'm running a 5 g motor in my Cox MW P-40 and it works good even though that particular plane is a bit portly.
Old Jul 04, 2010, 06:56 AM
56S is online now
56S
56S
56S's Avatar
Joined Nov 2006
I've used both in a Guillows sub 3oz Champ and settled on the 5gr. Just thinking of what my Dad used to say back in our glow days..." If you need to add nose weight, make it in cubic inches."
Old Jul 04, 2010, 11:02 AM
modfly is offline
modfly's Avatar
Joined Dec 2006
Yea, And if your doing an electric plane and need nose weight, make it a bigger lipo
Old Jul 04, 2010, 11:18 AM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Subscribed!
giuseppi is offline Find More Posts by giuseppi
Old Jul 04, 2010, 03:19 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
Landing gear mains
Originally Posted by giuseppi View Post
Subscribed!
Cool
I got the mains installed. You will notice that they are well forward of the CG point which will help prevent nose overs. This gear worked good on the Venom plane despite being foam type wheels, I'm hoping they work as well on this corsair.
Old Jul 04, 2010, 03:22 PM
darksiede is offline
Find More Posts by darksiede
Foaming at the mouth..
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Subscribed here as well... I have an upcoming AR6400L project myself, just debating on what its actually going to be! :P
~Kev
darksiede is offline Find More Posts by darksiede
Old Jul 04, 2010, 05:53 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
5 g outrunner
~Kev
Yep, so many choices. but for me its easy, warbirds rule!
I decided to go with the smaller outrunner. Its 5 grams but with the motor mount and prop its more like 10 g.
The 10g outrunner could be swapped in if needed.
Now I need to locate a very small 2s BL ESC.
Old Jul 04, 2010, 06:35 PM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Looking good Modfly. What is the diameter of the wheels on the landing gear? It looks to be around 18 - 20 mm, looks pretty scale. Also what prop is that you are using for test fitting? I guess it just presses into the spinner then presses on the motor shaft? Nice setup.
Eagle34 is offline Find More Posts by Eagle34
Old Jul 04, 2010, 08:48 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
That little 5g motor fits the hole in the nose perfectly. Would you have to enlarge the opening for the 10g?
Old Jul 04, 2010, 10:00 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
why does my cox corsair look a little different ? it's the only 1 left to mod and assembly btw. I will post some pictures of the box.. I hope it'snot a cox replica...
pavcon is offline Find More Posts by pavcon
Old Jul 04, 2010, 11:04 PM
giuseppi is offline
CV-15 VB-16
giuseppi's Avatar
Joined Jul 2007
Happy Independence Day
I'd like to wish everyone in the USA a Happy 4th of July.
Old Jul 04, 2010, 11:08 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
Wheels size plus Prop and Spinner
I use the GWS props\spinners for most of my planes.
Old Jul 04, 2010, 11:27 PM
modfly is offline
modfly's Avatar
Joined Dec 2006
Spinning Dummy Radial mod with 5g outrunner
Yes, The 10g motor is larger and heavier of course. Right at the last minute I made a radial spinner mod. Cool eh?
Idea LVC problem on AR6400-AR6400L can be eliminated with upgraded Brushed ESC modfly Micro Ready-to-Fly 136 Oct 31, 2010 11:29 AM
Sold well this may be a good electric conv. vintage cox cessna skylane 182 w/ cox radio rcrick10 Aircraft - Electric - Airplanes (FS/W) 3 Apr 03, 2010 01:24 AM
Sold vintage cox cessna skylane w cox radio rcrick10 Aircraft - Fuel - Airplanes (FS/W) 0 Mar 30, 2010 10:14 PM
Sold cox/sanwa radio with reciever and servo kcomqg Aircraft - General - Radio Equipment (FS/W) 0 Jan 13, 2010 08:22 PM
Sold Cox Micro F4U Corsair RTF w/radio etc. Twmaster Aircraft - Electric - Airplanes (FS/W) 2 Feb 08, 2009 08:49 PM
