Old Jul 02, 2010, 11:18 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
New Product
Elektro Rookie from Graupner
Finally an Elektro Rookie kit arrived today. I had already mentioned the model in the EasyStar thread as a serious competitor:
http://www.rcgroups.com/forums/showp...postcount=2041
While the new Elektro-UHU with 1200mm wingspan already outperformed the EasyStar, its nose may have been its weakness for beginners.
Everything is different now with the new Elektro-Rookie S(olidpor). It is bigger and it comes with many interesting features at a competitive price:
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jul 02, 2010, 01:20 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Looking forward to your report on it.
Would you have a link on where to purchase?
2500GENE is offline Find More Posts by 2500GENE
Old Jul 02, 2010, 01:49 PM
Joined Sep 2000
I usually buy Graupner products from Höllein:
http://www.hoelleinshop.de/e-vendo.p...n_e&SessionId=
Search for Rookie.
Jürgen
Old Jul 02, 2010, 05:33 PM
Joined Sep 2000
Individual component weights
Fuselage R/H L/H: 68.6g / 68.6g
CRP tube fuselage: 11.6g
Canopy: 13.4g
Horizontal Stab: 23g
Plastic mounting plate: 4.5g
Wing R/H L/H: 100.7g / 100.7g
CRP wing spar: 25.4g
Drive set (motor, ESC, cables and connectors): 70g
Motor mount plus M3 screws: 5.8g
Jürgen
Old Jul 02, 2010, 05:44 PM
Ben D Wing is online now
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Not yet in stock, but will be available here in the UK......http://www.gliders.uk.com/prodinfo.asp?number=G4218
Also as Ready To Run......http://www.gliders.uk.com/prodinfo.a...er=G4218%2E100
Ben D Wing is online now Find More Posts by Ben D Wing
Old Jul 02, 2010, 05:54 PM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Why do they supply 2 different size props? One is 6" x 3" and the other is 6.3" x 3".
Old Jul 02, 2010, 06:10 PM
Joined Sep 2000
It is all mentioned in the instruction manual :
The 6.3x3" SF prop is for 2s, the Cam Slim 6x3" is for 3s.
Jürgen
Old Jul 03, 2010, 09:20 AM
Joined Sep 2000
Maiden flight and more pictures ...
You really can get this model airborne within 2 hours, but I took a bit longer as I was not in a hurry.
This model is even easier to fly than the famous EasyStar. Straight from the "build board", i.e. living room table, no trim changes were required during the maiden flight. CG at 80mm from the leading edge worked fine.
The model has no tendency at all to spiral dive - even with continuous full rudder and full elevator applied. It is also very tough. I intentionally stalled the model approx. 10ft above the ground and kept full-up elevator. The model took the nose down to pick up speed and hit the ground at an angle of approx. 30° - no damage.
Unfortunately the recommended 2s/2500mAh battery was not available right now, so I had to use the 2s/1500mAh from the Elektro-UHU plus 60g of ballast.
All up weight at the maiden flight was 530.1g, plus 89g battery, plus 60g ballast. I guess the model will weigh approx. 700g with the decor added.
Great model for beginners!
Jürgen
Old Jul 03, 2010, 09:59 AM
aero_k is offline
Find More Posts by aero_k
Canada, QC, Montreal
Joined Apr 2009
Pretty cool. It least Graupner made it look a little different from the Easystar, unlike the Sky Surfer which is basically an exact clone. I like how it comes with a brushless motoe and CF spars. I'm not sure whether that justifies the $25 (US)price higher than the Easystar kit price. I guess it depends on which brushless motor you upgrade the EZ with.
Having the high T tail makes things a little trickier for connecting a servo to the elevator, but it puts the elevator right in the prop wash, which is good for control at lower speeds.
I'm not sure if I like the internal servos or not. They are nice you have inside where you can't see them, but they take up a bit of space inside which a lot of people use for other things. They also look a little tricky to install. Other than that it looks good. I like the shape of the nose and canopy.
I'd love to see some video...
aero_k is offline Find More Posts by aero_k
Old Jul 03, 2010, 10:39 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Ronan vliegt zijn Graupner Elektro Rookie S (2 min 22 sec)
And there's more if you do a youtube search.
Old Jul 03, 2010, 06:29 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Jurgen, you always seem to find the coolest little models around
Xpress.. is offline Find More Posts by Xpress..
Old Jul 03, 2010, 11:42 PM
kevinhines is offline
Find More Posts by kevinhines
Robot, RC Pilot & Builder :-)
kevinhines's Avatar
Roanoke, VA, USA
Joined Jul 2006
Jürgen, thanks for making the rest of us aware of this nice model.
I look forward to learning more about it.
Kevin
kevinhines is offline Find More Posts by kevinhines
Old Jul 04, 2010, 02:24 AM
EvgenUA is offline
Find More Posts by EvgenUA
Ukraine
Joined Mar 2010
can it pull a pretty big and heavy camera like HD Hero?
EvgenUA is offline Find More Posts by EvgenUA
Old Jul 04, 2010, 02:29 AM
Joined Sep 2000
Well, I would not mount an HD Hero at the wing tip (as shown on their website), but I am sure the Elektro-Rookie can carry about the same loads as an EasyStar.
Jürgen
Old Jul 04, 2010, 02:35 AM
EvgenUA is offline
Ukraine
Joined Mar 2010
not on the wing of course
i'm asking because, looking at your pics, seems like it has a bit narrower fuselage than easy star have
or not?
Discussion Likely FPV Candidate Elektro Rookie S by Graupner Neo360 FPV Talk 26 Sep 24, 2010 10:06 AM
Sold Graupner Elektro Junior S Twinkletoze Aircraft - Sailplanes (FS/W) 2 Apr 01, 2010 02:09 PM
Sold Local Pickup Only - Graupner Elektro UHU mt_100 Aircraft - Electric - Airplanes (FS/W) 4 Sep 10, 2009 11:30 PM
Video New Elektro-UHU from Graupner Jurgen Heilig Electric Plane Talk 1 Jan 09, 2007 09:43 PM
